Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) -- General Topics
BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ
Old 01-23-2022, 09:55 AM   #85
C R
Drives: 22 BRZ
Something I haven't seen mentioned is the sun visor leaving a gap between the A-pillar when being used. Pretty annoying and I've found myself driving a little crooked to avoid the sun. It's even more useless when swung towards the window; not being able to extend, it leaves another big gap where the sun can hit the side of the face.
C R is offline   Reply With Quote
Old 01-23-2022, 12:01 PM   #86
azndavepgh
Drives: 2022 BRZ
I noticed the rev limit is set to 4500 RPM when the engine is cold and then changes to your setting after the engine is warm.
azndavepgh is offline   Reply With Quote
The Following User Says Thank You to azndavepgh For This Useful Post:
PhatFreshPrince (01-23-2022)
Old 01-23-2022, 02:10 PM   #87
Lelandjt
Drives: '04 STi, '12 Mazda 3 Hatch
Aftermarket sun visors is an untapped industry. Seriously. Most cars I'm in have this problem.
Lelandjt is offline   Reply With Quote
Old 01-23-2022, 02:20 PM   #88
Lelandjt
Originally Posted by tenderization View Post
Just noticed the gauge cluster announcing the "two hours from ignition on," apparently a carryover from 1st gen.
Is this a drowsy driver warning?
Old 01-23-2022, 07:16 PM   #89
PhatFreshPrince
PhatFreshPrince's Avatar
Drives: 2022 BRZ Limited SBP
Originally Posted by jvincent View Post
@Scargod and @PhatFreshPrince I too am looking for a good place to mount a phone.
You can see what car phone mount I went with at this post. I am going to see if it will stay stuck to the dash. It seems promising.
PhatFreshPrince is offline   Reply With Quote
The Following User Says Thank You to PhatFreshPrince For This Useful Post:
jvincent (01-23-2022)
Old 01-23-2022, 07:19 PM   #90
Scargod
Track Day Junkie
Scargod's Avatar
Cell phone holder placement
EDIT: This is not where I put mine:
Name:  cellphone holder.jpg
I put the mount at the 10 o'clock position relative to the "AUTO" text. It has worked out fine in that spot and seldom interferes with the controls.
Last edited by Scargod; 01-06-2023 at 04:11 PM. Reason: Edited my comment to revise it.
Scargod is offline   Reply With Quote
Old 01-23-2022, 07:39 PM   #91
Monroetwin
Drives: 2022 GR 86 Premium
Only nit to pick so far is that there is no “good” place to lift/close the trunk. You can grab the lower edge to raise, but have no “good” place to use to push it closed. The top of the duck tail is the most convenient, but I am careful to not scuff/scratch the paint. Very minor, but is the only “bad” thing I have found so far.
Monroetwin is offline   Reply With Quote
Old 01-23-2022, 07:41 PM   #92
jvincent
jvincent's Avatar
Thanks. I was looking at the same mount/location.
Old 01-23-2022, 07:45 PM   #93
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I just grab one of the side rubbers, and pull it down.
dragoontwo is offline   Reply With Quote
Old 01-23-2022, 07:47 PM   #94
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I push down on the badge.
Maybe Perrin will make another handle?
https://www.perrin.com/shop/interior...RoCLf0QAvD_BwE
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Midnightsky (01-23-2022)
Old 01-23-2022, 08:42 PM   #95
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
hmmm that's a really good idea actually. I wonder if those are cross gen compatible too lol.
Midnightsky is offline   Reply With Quote
Old 01-23-2022, 09:10 PM   #96
diga
Drives: 2022 Subaru BRZ Limited 6MT
I've noticed the high pitch chirp that occurs after car reaches full warmup (mostly noticeable while idling) is greatly reduced/eliminated by disconnecting the active sound.
diga is offline   Reply With Quote
The Following User Says Thank You to diga For This Useful Post:
Interceptor777 (01-24-2022)
Old 01-24-2022, 12:29 PM   #97
Interceptor777
Interceptor777's Avatar
Drives: 2022 BRZ, 1999 "touge-spec" Miata
I thought I was going crazy over this noise or that I fucked up the car somehow. I also really need to disconnect active sound.
Any clue why active sound contributes to the chirp?
Interceptor777 is offline   Reply With Quote
Old 01-24-2022, 03:35 PM   #98
otter
Drives: 22 BRZ
Originally Posted by Interceptor777 View Post
Check out the MTEC clutch spring from the previous-gen twins. It greatly improved the clutch feel and made it a bit stiffer for me. I was struggling to consistently drive the car smoothly but now it's extremely easy with the spring, it's very predictable and consistent with great feel.
If there's a clutch assist spring on the clutch pedal then I recommend doing what I've done on every past car I've owned with one of these - throw it in the trash and don't replace it. Hate them so much; they're totally unnecessary and make it such a pain to operate the clutch smoothly and predictably.
otter is offline   Reply With Quote
BRAINDUMP - FT86 Quirks, common fixes and when things need upgrading Aztec Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 08-28-2015 05:44 PM
Magazine features crouchy35 AUSTRALIA 1 06-03-2013 05:59 PM
Interesting features on the FR-S... Senzai Scion FR-S / Toyota 86 GT86 General Forum 59 05-08-2013 04:41 PM
Strange Quirks Aznek Scion FR-S / Toyota 86 GT86 General Forum 30 08-15-2012 09:40 AM
FR-S Standard Features zAnSh1n Scion FR-S / Toyota 86 GT86 General Forum 182 04-04-2012 04:23 PM
