Old 06-30-2021, 08:56 PM   #127
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
DIY: Track Mode on 2013-2016 cars
Originally Posted by nextcar View Post
Other than going out and trying to slide... is there a quick way to verify the new functionality is operating correctly? I may get a chance to do the swap this weekend - would be nice to know it is all working correctly after I am done but before I really need it!
Track mode (sport button) should take a long press to activate now, instead of instant press.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
nextcar (06-30-2021)
Old 06-30-2021, 09:22 PM   #128
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Perfect! Thank you. Now I REALLY can't wait for UPS to deliver...
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
Old 07-03-2021, 11:52 AM   #129
nextcar
Wooo Hooo! Another successful swap. A couple notes:
Got a 2017 Unit for $99. On the aluminum the part revision was 030.. and a date code of Feb 2017.
The control unit has two date codes, one was Dec 2016 and the second was Jan 2017.
My car is a 2013 MT, from opening the hood to repin done was 30 min. Total time about 45 minutes.
NO ABS warning light when I started up. Works great!
One final question... Now that I have "mode 4" with trc off, vdc off, and brake-lsd off, is there any reason to do the pedal dance?
Or put another way, is the new mode 4 the same as the pedal dance used to be?
Pull out
Old 07-03-2021, 01:22 PM   #130
Yoshoobaroo
TRACKBREAD
Pedal dance turns EBD off too IIRC, so you can rotate while trail braking. Not sure if this car has much of a tendency to rotate under braking though.
Old 07-08-2021, 03:59 PM   #131
slockin
slockin's Avatar
Drives: '13 BRZ 6MT WRB
Just wanted to share my experience with the swap.
Successfully swapped a 2017 MT ABS unit (27536CA030) into a 2013 MT. I have a scan tool that I plugged into the car before firing it up and the ABS module had a ton of fault codes. I cleared them using the scan tool and all was well. Took a short test drive around the block to confirm the swap was a success. IIRC, the repin for was for the VSC sport button and a wheel sensor and confirmed that both looked good during the test drive.
One issue that I had that others hadn't mentioned was that if you don't slide the pin lock back correctly, you will not be able to plug the harness back into the module. After some messing around, I figured out that I wasn't able to slide the pin lock because the pins weren't pressed in far enough. So, if you are having issues there, please don't try to force anything.
slockin is offline   Reply With Quote
The Following 2 Users Say Thank You to slockin For This Useful Post:
nextcar (07-08-2021), Yoshoobaroo (08-22-2021)
Old 08-22-2021, 05:23 PM   #132
RedReplicant
Drives: None
Does anyone know if the 2020 model ABS units (27536CA070) will also work?
RedReplicant is offline   Reply With Quote
Old 09-02-2021, 09:22 AM   #133
Yoshoobaroo
TRACKBREAD
Probably, no way to know for sure until someone tries it though.
Old 09-14-2021, 12:24 AM   #134
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I picked up a 2020 070 off eBay, wish me luck? It was $140 including shipping.
Mine is the first batch of 2015 model, Blue series, build date is around 2014 April.
Hopefully I don’t need to repin the connector? How would I know if I need to repin or not…?
Old 09-14-2021, 02:03 AM   #135
Yoshoobaroo
TRACKBREAD
Nice, good luck!
If you get a code for the FL wheel speed sensor, and the VSC sport button doesn’t do anything, then you need to repin. Being a 2015 if should be plug and play though. Let us know how it goes, if it goes well I’ll add the 070 to the list as compatible.
chaoskaze (09-14-2021)
Old 09-15-2021, 07:31 PM   #136
RedReplicant
Drives: None
Man, nice catch. What search terms were you using?
Old 09-15-2021, 07:55 PM   #137
Yoshoobaroo
TRACKBREAD
Best terms are BRZ ABS pump and 86 ABS pump.
417motoring usually has a decent selection: https://ebay.com/usr/417motoring
Old 09-21-2021, 06:24 PM   #138
nextcar
Update: I now have 4 HPDE days since performing this upgrade. I love the new track mode - the pedal dance may be better for some, but I find track mode just about perfect for me.
The first time you either forget to do the pedal dance before starting, or go off track and stall out you will kick yourself for not doing this sooner! It was so awesome when I realized during the warmup lap that VSC was still engaged and I could just reach down and enter track mode while in motion!
Pull out
The Following 3 Users Say Thank You to nextcar For This Useful Post:
Jdmjunkie (09-21-2021), solidONE (09-23-2021), Yoshoobaroo (09-21-2021)
Old 09-22-2021, 06:00 PM   #139
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Nice, good luck!
So i Did it last night, no light what so ever. Just like that & boom ABS doesn't make u feel like hitting something on the road anymore.
100% Plug & Play even with 2021 070 unit, 20 min job cause I dropped the 4mm socket.
The Following 3 Users Say Thank You to chaoskaze For This Useful Post:
bcj (09-23-2021), solidONE (09-23-2021), Yoshoobaroo (09-24-2021)
Old 09-24-2021, 09:04 PM   #140
Yoshoobaroo
TRACKBREAD
Excellent! Updated the compatibility list.
Search this Thread:
Advanced Search
Review of "Track Mode" on the MY17+ cars trippinbillies40 Tracking / Autocross / HPDE / Drifting 85 02-22-2021 09:27 PM
FS: Nameless muffled track pipe 2013-2016 Dave-ROR Engine, Exhaust, Bolt-Ons 4 05-20-2020 11:27 PM
Track mode vs. VSC sport alex87f Scion FR-S / Toyota 86 GT86 General Forum 9 10-30-2018 10:47 PM
2017 Track mode on older model Bobster Engine, Exhaust, Transmission 17 12-03-2017 10:34 PM
