Forced Induction Turbo, Supercharger, Methanol, Nitrous |
Drives: 2019 86 TRD
Sprintex s5-210 install question
For the sprintex s5-210 kit.. where do you plug in the water pump? The instructions aren't very clear. Thanks in advance
#2 |
Drives: 2017 toyota 86
36. Connect fuel supply line
Connect the water pump loom via the adapter connectors to one of the fuel injector connectors. it piggy backs off one of the fuel injector connections with the supplied adapter cable. I found the instructions to be pretty well detailed and thorough, just need to slowly go through each step one by one, make sure you read everything and complete everything before moving onto the next step. I also advise to read the entire install manual cover to cover before even starting, then going back from the beginning so you have an idea of whats going on. If you do you should have a good install. but it is easy to skip around or assume you know what to do or where something goes, or start not reading thoroughly and miss something. That's when people start having issues after install. Also you can read and reference this http://www.ft86club.com/forums/showthread.php?t=42754 for any other questions. I think the manual was updated to be much more clear since he wrote this, but some of it may help you still. |
#3 |
Drives: 2019 86 TRD
K, that's what I thought. Thank you
#4 |
Drives: 2019 86 TRD
Got the kit installed.. went well. But I can't figure out where to mount my catch can?? Anybody out there have pics of where/how you mounted your catch can. I have the Mishimoto large universal catch can.
Question about Valenti install | Phuviano | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 06-03-2019 04:17 PM |
Sub install question | drz400dude | Electronics | Audio | NAV | Infotainment | 10 | 12-18-2016 01:17 AM |
Amp/Sub Install question | Nathan0726 | Electronics | Audio | NAV | Infotainment | 5 | 08-30-2014 06:02 AM |
Frs lip install question | Kai Uhl | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 07-21-2014 10:39 PM |
Fog install question | Cooper911 | DIY (Do-It-Yourself) Guides | 4 | 11-17-2013 02:43 PM |
