Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
07-01-2020, 09:43 AM | #1 |
Drives: 2016 Toyota 86
How was fitment on your 3DCarbon rear spoiler?
I have been having some issues getting a 3DCarbon spoiler installed on my car. I have had 2 of these spoilers now. About 2 weeks after I got the first one installed, both ends of the spoiler lifted up. I ended up getting a second one and had it installed at a different shop. When I went to pick it up the spoiler was already lifting up in some spots!
How difficult is it to get 3M tape to hold one of these things down? Everything I read says it should be easily strong enough to permanently attach a spoiler. But after going to 2 different body shops and having the tape lift up, I am at a loss. Last edited by Mike_ZN6; 07-01-2020 at 06:48 PM. |
07-01-2020, 10:13 AM | #2 | |
1st86 Driver!
If the tape is separating cleanly, then the area probably wasn't prepped correctly. It doesn't have to be perfect, but it does have to be done per the instructions. If it's the paint that's lifting with the tape, then there's your problem. (Not saying it is, it's just that came to mind when reading this)
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
07-01-2020, 10:20 AM | #3 | |
It looks like in some spots the tape is seperating from the spoiler and staying attached to the trunk. In other spots, it seems the tape is staying attached to the spoiler but lifting off the trunk. Last edited by Mike_ZN6; 07-01-2020 at 10:31 AM. |
The Following User Says Thank You to Mike_ZN6 For This Useful Post: | Dadhawk (07-01-2020) |
07-01-2020, 08:47 PM | #4 |
Drives: 2014 FR-S
The ends of mine are lifting after 14 months. Might have to reinstall. Maybe use heat gun to bend the ends in the opposite direction before reinstalling.
IMO the best-looking lip/spoiler for the twins... |
07-01-2020, 09:18 PM | #5 |
Drives: 2016 BRZ
Remove the spoiler and clean the areas where the 3m tape makes contact.
Before applying it again use this. I've used this before and it definitely helps. Now if the spoiler is warped bad enough that's another story but that adhesion promoter is cheap enough to give a shot. |
The Following 2 Users Say Thank You to Joon525 For This Useful Post: | Mike_ZN6 (07-10-2020), thatfilipinoguy (07-10-2020) |
07-01-2020, 09:54 PM | #6 |
ProCrastinationConsultant
are you sure it's genuine 3m tape?
if in doubt, replace the tape with some store-bought real stuff https://www.amazon.com/3M-Scotch-Ext.../dp/B005SRECEU
The Following User Says Thank You to soundman98 For This Useful Post: | Mike_ZN6 (07-10-2020) |
07-10-2020, 12:23 PM | #7 | |
07-10-2020, 12:28 PM | #8 | |
I am going to reinstall soon and hopefully it stays this time. |
07-10-2020, 12:30 PM | #9 |
07-19-2020, 04:35 PM | #10 |
Drives: 2014 FR-S
I suspect these were manufactured a long time ago, and where you find "new" items for sale, they are leftover stock. May be best to replace all tape with new 3M in addition to a meticulous prep.
The Following User Says Thank You to tarzan_nojane For This Useful Post: | Mike_ZN6 (07-20-2020) |
07-20-2020, 09:52 PM | #11 |
Does anyone know are you supposed to use the 3m adhesive promoter on the spoiler before you apply the tape to it? Or just use it on the trunk?
07-21-2020, 12:38 PM | #12 | |
Drives: 2013 Firestorm FR-S AT
I purchased a pre-painted FIVE:AD rear spoiler back in 2015. The 3M tape was pre-applied to the spoiler and it came with 3 tubes of 3M adhesive promoter. Followed the installation instructions and it looks as good as the day I installed it. The ends have not lifted. |
08-04-2020, 11:10 PM | #13 |
Drives: '23 BRZ Limited 6MT; '13 FR-S 6MT
Does this 3DCarbon spoiler cover up all of the holes from the OEM FRS spoiler??
2023 Subaru BRZ Limited - 6MT (weekend)
2013 Scion FR-S - 6MT (daily) |
08-04-2020, 11:18 PM | #14 |
no.
The Following User Says Thank You to soundman98 For This Useful Post: | DriveDriftDogfight86 (08-05-2020) |
Similar Threads | ||||
Specifically which kind of 3m tape to attach spoiler/fender garnishes? | Infinity | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 10-15-2019 12:48 AM |
Real TRD trunk lip spoiler, K1X, no damage. Gasket intact, roll of 3m tape | Joesurf79 | Exterior Parts (Aero, Lighting, Etc.) | 4 | 05-13-2019 10:14 PM |
Efficient method of removing double sided tape from back from spoiler? | brillo | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 08-21-2017 10:14 AM |
5AD style duckbill spoiler, unpainted with tape | bfrank1972 | Exterior Parts (Aero, Lighting, Etc.) | 13 | 11-09-2015 01:23 PM |
Has anyone ever used loctite tape for a spoiler? | MileHighBRZ | BRZ First-Gen (2012+) -- General Topics | 13 | 06-01-2015 01:25 PM |
