Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB > Technical Topics > Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Old 07-20-2021, 11:23 PM   #1
Stomachbuzz
Drives: 2013 FRS
Insane knocking in front
I've got a crazy knocking in my front suspension that has successfully driven me crazy.
I now realize it first started showing signs around 10,000 miles ago, at 44k.
At that time, when braking hard, there was a very subtle knocking from the front. It seemed to me like I had a warped rotor.
At that time, it was intermittent, so I felt my rotors were not actually warped and didn't think much of it.
A bit later, the car starts developing a very sharp pitched knocking in the front left strut tower area when I hit a sharp bump or pothole.
I jacked it up, yanked on a bunch of stuff. Couldn't find anything.
Keep driving it, noise gets slowly worse.
Jack it up again, look more thoroughly. Even get a pry bar out to lever up against the bottom of my tires to try to check for ball joint play.
Doing 6/12 test, 3/9 test. Yanking on everything. Cannot find anything suspect.
I tried using the pry bar to lever against different suspension arms in any way I could. I couldn't find anything odd.
Keeps getting worse. At this point, it's just knocking around all the time, and is shuddering aggressively/concerningly under moderate braking.
Replace front sway bar and put on new end links.
No change.
Replace factory struts with Tein coilovers.
No change, despite finding noticeable play in the strut tower bearing (which I really thought was my "a-ha!" moment ).
I even unhooked my sway bar entirely and drove it shortly. No change.
At this point, it's gotten so bad, it shudders heavily even under gentle braking. Just the noise, not the car shaking.
It sounds like my steering column is loose. Usually, I would heavily suspect the steering rack by now, but the car still steers and handles tightly.
Any ideas?
Stomachbuzz is offline   Reply With Quote
Old 07-20-2021, 11:33 PM   #2
whataboutbob
AutoX-10/10ths every run
whataboutbob's Avatar
Did you check your front brake caliper mounting bolts?
Old 07-21-2021, 12:45 AM   #3
soundman98
threadwrecker
soundman98's Avatar
Drives: '14 brz limited
Could it be the EPS coupler noise others have had?
my '14 brz limited "the return to normal" (or is it?)
led mods-10%(planning/designing/sitting on hands)audio mods-99%(done is never done)
hidplanet build log
NoHaveMSG (07-21-2021)
Old 07-21-2021, 01:01 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
If problem is under braking, naive question - have you checked everything brakes related?
Old 07-21-2021, 11:28 AM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Do you have an aftermarket lockdown kit for the steering rack?
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
norcalpb (07-21-2021), Ultramaroon (07-22-2021)
Old 07-21-2021, 03:26 PM   #6
Stomachbuzz
Drives: 2013 FRS
What is this ESP coupler?
It is not exclusive to braking. Braking is just an event that causes it to knock around.
But I haven't checked my brakes specifically. I'll go ahead and do that today.
Everything is stock on the steering rack.
I was under it last night yanking around on the rack, tie rods, steering shaft (both in the driver footwell and under the car), nothing.
Old 07-21-2021, 04:02 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Likely this as @soundman98 said then.
https://www.ft86club.com/forums/showthread.php?t=133606
Old 07-21-2021, 04:51 PM   #8
Stomachbuzz
Drives: 2013 FRS
Likely this as soundman98 said then.
WOW...
That thread was amazing. Almost certain that's what it is now.
Thanks so much. Gonna go tear my car apart and let you know what I find
Old 07-21-2021, 11:58 PM   #9
radroach
Drives: 13 BRZ
I don't know why they use a Hyundai coupler in the fix rather than a Subaru part. It's not like Hyundai doesn't have issues with their EPS couplers breaking down too.
Old 07-22-2021, 12:38 AM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
Maybe subaru doesn't list one separately for brz w/o whole EPS assembly, just like toyota didn't for gt86/fr-s. (thread lists also very similar part by toyota, that doesn't require trimming unlike huyndai's, but IIRC it was found from parts listed for corolla, not for gt86/fr-s). As for why hyundie's .. probably that's what thread creator had found quickest/easiest by whatever means (probably googling) from similar parts at time when he was doing that mod. Only later on extra nfo on toyota/corolla part was added in.
Obviously that all is revelant IF your issue is this. From initial post with description how issue started, i'm not yet 100% convinced.
Old 07-22-2021, 12:46 PM   #11
norcalpb
norcalpb's Avatar
Drives: '13 DGM BRZ Limted
The Hyundai coupler is way beefier. You can see the OEM Toyota coupler has different colored layers (black, then green, then black again). These different layers actually move independently of each other, almost like a plant or something.
The Following User Says Thank You to norcalpb For This Useful Post:
NoHaveMSG (07-22-2021)
Old 07-23-2021, 11:12 PM   #12
Stomachbuzz
Drives: 2013 FRS
I, too, was curious how Hyundai popped up in 'How to Fix' thread lol
Old 07-24-2021, 01:58 AM   #13
jflogerzi
jflogerzi's Avatar
Keeping this i the back of mind.
2013 Series 10 FRS #553
RCE SS-1s, SPC LCAs -3/2.3 camber
JDL 4-2-1 EL, MXP-SP, Tuned by Zach@CSG on e85
ARC-8 17x9 Satin Black ET35 SX2 GTs 245/40/17
Old 07-25-2021, 01:15 PM   #14
norcalpb
norcalpb's Avatar
Any updates OP?
PROOF that the BRZ/FRS is an insane value... GrantedTaken BRZ First-Gen (2012+) -- General Topics 2 12-31-2018 10:17 AM
Tapping/Knocking Sound from Front Coilovers Trefoil Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-19-2017 10:25 PM
Installed Invidia Overpipe? Bad knocking in the front? Jtbirchfield Engine, Exhaust, Transmission 19 10-07-2015 12:08 PM
Front KNocking Noie and Gear Lever rattle Naughty AFRICA 17 10-26-2013 02:56 PM
Copyright ©2000 - 2021, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
