| CANADA Canada |
Drives: BRZ WRB Sport-tech
Trunk release failure - BRZ
Interior trunk release switch under the steering wheel has no effect. Exterior switch on the trunk lid has no effect. Button on remote doesn't work.
Mechanical key does work. Valet trunk disable is NOT engaged. Tried it both on and off. Has anyone else encountered this issue? A search on this forum didn't show any others. I've had the car 2 weeks, 1350kms. All methods of opening the trunk worked fine until today. Thanks! Stephanie |
#2 |
Kuruma Otaku
Because titanium. |
#3 | |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
#4 |
Drives: BRZ WRB LTD MAN
I have had this happen when I really load up the trunk. Once I take all the stuff out it is fine again.
#5 |
hmm, never had more than 2 bags of groceries in it. Probably just a simple electrical fault. Time to test out Docksteader's famous service department.
#6 | |
FT86Club Vancouver
Hopefully the service manager sees this as a common problem and start thinking about what to do.
#7 |
Drives: Brz black
I just had a problem with trunk. The car was unlocked and the internal trunk release button and the physical trunk handle both failed to open the trunk. However, the trunk opener on the remote control key fob worked. Once the trunk was opened, i haven't seen the issue again.
#8 |
short asian guy
Drives: ZN6, VZN185
is there an electronic trunk release lock button on the left side of the trunk liek there is on an FRS?
VZN185 - 32" BFG AT, OME suspension, ARB bumper, lightforce lights, TRD trans cooler, TRD exhaust, budbuilt plates... ZN6 - stock with HIDs and LEDs... fng@regencyauto.com |
#9 |
Drives: Brz black
There is.
#10 | |
There's no way to get into the trunk from the interior without taking the back seat apart, so the glow in the dark emergency release isn't so helpful in this case.
#11 |
short asian guy
Drives: ZN6, VZN185
the OP can use her key to open the trunk... but no electronic trunk release function works... which leads me to have her check the button first...
as for wparsons/newguyottawa, you would have to open the trunk once to figure out why your latch isn't working... usually the key cylinder will work regardless of wiring/electronic issues... only problems would be if it's been apart before and not reassembled properly... or the latch or key cylinder are hooped...
#12 |
Drives: 13 Scion FRS
fix for mine.
I was reading this thread then walked out to the car after calling the dealership...I was told that we have a small key port under the edge of the lid that was for our key...I had no idea it was even there. But I opened it up just to find that the oil jug i had in the trunk had hit the trunk cancel button not allowing me to open it up. Pushed the button back in and no more problems opening it up. My mistake. I'm an idiot. I guess I should stop taking hard turns with stuff in the trunk lol.
Add me on IG @CNastySon
Mishimoto..."Do Yo Temps Stay Low, With the Throttle To Da Flo!!! |
#13 |
Drives: 2014 BRZ Limited (World Rally Blue)
This happened to me before. It doesn't stop your key from working, although I thought it did too. You have have to turn it harder which I was afraid of doing because I didn't want to break anything.
I turned harder using both hands and it opened. Then I released the oddly placed trunk lock feature on the left side.
#14 |
Drives: 2003 S2000, 2008 Fit
It doesn't help that the key is a tiny little nub that is hard to apply force to...
If the key turns but the trunk doesn't open, then it might not be the valet-disable switch... |
| Raven down! Mechanical failure :( | rasec29 | Issues | Warranty | Recalls / TSB | 151 | 10-08-2013 12:25 PM |
| BC Coilover failure in the past | phenom86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 10-25-2012 06:07 PM |
| BRZ Limited Electronic Trunk Release | diirk | Electronics | Audio | NAV | Infotainment | 4 | 09-17-2012 12:42 PM |
| Ringland Failure? | iLuveKetchup | BRZ First-Gen (2012+) — General Topics | 9 | 01-30-2012 01:25 PM |
| A pessimist's take on sales success / failure | Mess11 | Scion FR-S / Toyota 86 GT86 General Forum | 137 | 11-24-2011 02:10 PM |
