Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
07-08-2021, 12:43 PM | #1 |
Drives: 2015 Scion FR-S Firestorm
Dusty fusebox
I happened to open the fusebox in the engine bay and found it was little bit dusty. I’ve looked up if there were any other people experiencing the same, but I don’t see many posts mentioning this.
I know it’s not alarming as is, but makes me wonder if I’m missing a rubber seal or something. Given the car is about 6 yrs old, it’s not too bad, but any idea I can clean it safely, preferably without disconnecting the battery? |
07-08-2021, 01:09 PM | #2 |
TRACKBREAD
A clean paint brush and/or compressed air
The Following User Says Thank You to Yoshoobaroo For This Useful Post: | suppjc (07-08-2021) |
07-08-2021, 03:05 PM | #3 |
Master Collaborator
Dusty Fusebox......
Great porn name. |
The Following 5 Users Say Thank You to FR-S2GT86 For This Useful Post: | Capt Spaulding (07-09-2021), Cephas (07-22-2021), NoHaveMSG (07-08-2021), Overdrive (07-08-2021), suppjc (07-08-2021) |
07-08-2021, 10:33 PM | #4 |
07-08-2021, 10:38 PM | #5 |
The Following User Says Thank You to suppjc For This Useful Post: | Ultramaroon (07-09-2021) |
07-08-2021, 11:14 PM | #6 | |
義理チョコ
No need to disconnect the battery.
The Following User Says Thank You to Ultramaroon For This Useful Post: | suppjc (07-09-2021) |
07-09-2021, 12:26 AM | #7 | |
07-09-2021, 12:49 AM | #8 |
義理チョコ
Dust-off + paint brush = profit
07-21-2021, 04:56 PM | #9 |
I opened up my box to steal the spare 15amp and was appalled to see the crap in there! I was too shocked to take a picture but let's just say the OP's is spotless compared to what I found. Since I don't believe a fuse block is a great place to build sand castles I am going to see if I can find some thin foam weather-stripping to put between the top and the base. I do not want to even imagine the results if I got any dampness up in with all that sand and dust.
The Following User Says Thank You to Tcoat For This Useful Post: | bcj (07-21-2021) |
07-21-2021, 08:46 PM | #10 |
Drives: 2020 86GT
DustOff? To blow everything even deeper into every recess? This is a job for a brush and vacuum cleaner.
The Following User Says Thank You to QHawk For This Useful Post: | Tcoat (07-22-2021) |
07-21-2021, 09:05 PM | #11 |
義理チョコ
meh
07-22-2021, 07:05 AM | #12 | |
The location of the fuse box means that not only was it filled up with dust but also actual sand get's pushed up in there. This may not be an issue for cars that are only summer driven or where they don't sand and salt roads but for many of us the potential of forcing that dust/sand/salt even deeper with Dustoff is just asking for trouble down the road. I used a shopvac with a brush attachment and that got it cleaned up like new and didn't push everything down under the fuses and relays. I actually pulled a couple to check. Simulation of my cleaning it
The Following User Says Thank You to Tcoat For This Useful Post: | bcj (07-22-2021) |
07-22-2021, 11:35 AM | #13 |
義理チョコ
What isn't seen is that the bottom of that box is all open. Nothing magical going on below the surface. Big fat wire bundle with bare terminals clipping into the receptacles. You could blast it with a hose to clean it.
07-22-2021, 11:46 AM | #14 |
I am more concerned about the crap that was down between the prongs of each fuse and relay.
Tags |
tcoat's dusty box |
Similar Threads | ||||
Dusty fuse box | msaikhan | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 07-26-2019 01:09 PM |
Interior fusebox - can someone confirm? | 1Cor10:23 | DIY (Do-It-Yourself) Guides | 6 | 04-16-2015 07:10 PM |
Super dusty pads. HELP!!! | omegared19 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 09-12-2014 01:04 AM |
BRZ Fusebox | BRZfan | BRZ First-Gen (2012+) -- General Topics | 0 | 10-17-2013 07:44 PM |
WTB: ABS, Fusebox, AC condenser | mariolefty1 | Engine, Exhaust, Bolt-Ons | 0 | 05-06-2013 04:46 PM |
