Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-29-2020, 11:52 PM | #29 |
ProCrastinationConsultant
you've got some explaining to do!
07-30-2020, 01:53 AM | #30 |
Drives: 2017 toyota 86
07-30-2020, 05:38 AM | #31 |
Drives: '15 BRZ RA
Anyway, here is an opinion from a person who has tried this mod. I tried a lightweight pulley kit and I noticed a small difference, BUT it was a kit meaning that I had to change additionally the alternator pulley and the water pulley. Overall, a lightweight crank pulley won't help much alone. You need a kit with different pulley diameters to under drive the peripherals. Does it worth the effort and the cost? It depends. If it is your daily driver, then I wouldn't bother to change them.
07-30-2020, 08:16 AM | #32 |
Drives: brz
07-30-2020, 08:55 AM | #33 | |
07-30-2020, 09:21 AM | #34 |
pessimistic skeptic
The Following User Says Thank You to mrg666 For This Useful Post: | soundman98 (07-30-2020) |
07-30-2020, 09:26 AM | #35 |
pessimistic skeptic
When people cannot prove any power improvement, they claim throttle response since it is not measurable. Either someone posts a legitimate dyno or 0-60 test or we call the bs. Light-weight crank pulley is bs. That is the fact.
The Following User Says Thank You to mrg666 For This Useful Post: | ddevl_86 (03-30-2021) |
07-30-2020, 10:04 AM | #36 |
Drives: 2016 Toyota 86
I think light weight pulleys only make sense if you already have light weight flywheel, carbon drive shaft, lighter wheels, and 2-piece brake rotors. I'm certain you would be able to feel the difference when you have removed that much rotational mass from the drivetrain.
07-30-2020, 10:09 AM | #37 | |
Drives: Crapcan
07-30-2020, 10:12 AM | #38 |
07-30-2020, 10:16 AM | #39 | |
Drives: brz
If hp is the same and you reduce mass you get less time or more distance. Simple physics. Does it take more power to spin a 10lb disc than it does a 1lb disc to 7400rpms from 750? And not only that but you also have to accelerate the extra 9 lbs with the car. So you get less centrifugal mass plus less overall mass. The lighweight pulley works two different ways on acceleration. Last edited by solidsnake11; 07-30-2020 at 10:47 AM. |
07-30-2020, 11:02 AM | #40 | |
pessimistic skeptic
The Following User Says Thank You to mrg666 For This Useful Post: | Subsonic (07-30-2020) |
07-30-2020, 11:49 AM | #41 | |
Drives: brz
07-30-2020, 12:34 PM | #42 |
Drives: '15 BRZ RA
Similar Threads | ||||
[GA] FS: NEW Grimmspeed Lightweight Crank Pulley (NIB) + OEM Crank Pulley Bolt | reeves | Engine, Exhaust, Bolt-Ons | 0 | 08-22-2018 07:01 PM |
FS: OEM CRANK PULLEY SET | gt86ser | Engine, Exhaust, Bolt-Ons | 0 | 07-10-2018 01:45 PM |
What is best crank pulley? | Mixlplix | Engine, Exhaust, Transmission | 49 | 10-28-2017 05:44 PM |
Perrin crank pulley / Beatrush alternator pulley | Krimlin | Engine, Exhaust, Bolt-Ons | 7 | 08-26-2013 10:12 AM |
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley | ANREX | Engine, Exhaust, Transmission | 10 | 10-25-2012 07:45 PM |
