Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
06-13-2019, 05:21 PM | #15 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Sport mode 80% of the time on the streets. Manual mode otherwise and in the canyons using the paddles only.
D mode shifts at too low rpms for my liking. I never use the stick to change gears. All nannies on at all times, unless I'm fooling around somewhere I can't hit anything or anyone.
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
06-13-2019, 06:42 PM | #16 |
Everything off when you want to go slow. Sport mode when you want to go slower. Normal mode if you are scared of your shadow.
The Following User Says Thank You to Grady For This Useful Post: | Lantanafrs2 (06-14-2019) |
06-14-2019, 12:43 PM | #17 |
Drives: BRZ limited
First of all thanks for the topic. I just got my baby 2 months ago and experience the modes from time to time.
Since I got the car I am driving every week between NYC and Boston. I have already 4500 miles and 90% am on the D. I generally Use the the paddles. Never used the snow mode just the sport mode a few times. Actually I liked the shifting point being higher but don’t like people looking at me (due to the little increased sound) So got a lot of info from you guys. Thanks to all of you. Meanwhile, is it possible That we came across with some of you guys on the highway between NYC and Boston ? Thanks Sent from my iPhone using Tapatalk |
The Following User Says Thank You to Busybee For This Useful Post: | korhun (06-19-2019) |
06-14-2019, 04:06 PM | #18 | |
Are you sure the Snow/Sport modes actually do anything, and aren't just the center block replaced with the buttons? I've never seen a manual with them, which means the ECU wouldn't be doing anything, and the harness probably doesn't even have the pigtails for them. As for VSC press-hold... it's holding the TC button (left one) for ~3 seconds that turns everything off, there's no difference between just quickly pressing or pressing and holding the VSC Sport button.
06-14-2019, 08:36 PM | #19 | |
ProCrastinationConsultant
but a few wires and an arduino is going to change that!
06-15-2019, 04:15 PM | #20 |
Drives: 2016 Steel AT FRS
100% manual mode. It allows me to get the best sound out of my exhaust.
The Following User Says Thank You to Weigaldo For This Useful Post: | korhun (06-19-2019) |
06-15-2019, 05:38 PM | #21 |
Financial Distress
Drives: 2017 GT86 325WHP
What's the difference between normal mode and sport modes?
06-15-2019, 06:01 PM | #22 |
Drives: Halo 86, '19
I'm not sure how in depth of an answer you're looking for but here's the short and slightly longer.
Short answer: Sport mode shifts later, allows car to actually rev out engine to redline. Normal mode shifts far sooner, and because of how fluid coupling works, lets you drive the car at RPMs lower than any MT vehicle without lugging or overtly straining the engine. Slushbox mode, basically. Longer answer: Sport mode makes the car lock up the torque converter as much as possible without stalling, making the drivetrain behave like an manual transmission (in the sense that there's a direct 1 to 1 connection to the wheels like an MT car). It cruises from roughly 2000 RPM to 2.5K RPM, much like you would in a manual car. Normal mode uses a fluid coupling as much as possible at low speeds (on highways where travel and velocity is much more consistent it will lock up the torque converter) which means there's no 1 to 1 connection with the drive train, but allows it to operate and drive at very low RPM (1-2K), RPMs that under a normal MT or locked up torque converter would cause lugging and stalling. |
06-15-2019, 06:37 PM | #23 | |
Financial Distress
06-16-2019, 12:22 AM | #24 |
Honestly I don't feel any difference, and I've driven extensively with it on and off in MT mode. I've heard it slightly tones down nanny interference by itself but no clue on how it interacts with traction off or VSC off/track mode.
06-16-2019, 07:59 AM | #25 | |
The Following User Says Thank You to Grady For This Useful Post: | soundman98 (06-16-2019) |
06-18-2019, 04:46 PM | #26 |
Damn that's crazy...
Drives: 2015 BRZ
I keep it in D mode when I'm tired coming home from school/work or in heavy traffic, but for the most part it's in manual mode. If I'm cruising in manual mode, I'll put it in sport mode. I don't really feel a difference, but I like how the word looks lmao I use VSC when no one is around. I never take traction all the way off as I have no thread left on my tires and there's really no need for it when daily driving. No need for snow mode in Houston.
Similar Threads | ||||
Questions for AT owners about Sport mode | stlgrym3 | Engine, Exhaust, Transmission | 11 | 04-03-2018 10:34 PM |
Auto transmission jumping into manual mode on its own? | palanza87 | Issues | Warranty | Recalls / TSB | 6 | 11-10-2017 09:25 AM |
Automatic not downshifting in manual mode | VegaX77 | Issues | Warranty | Recalls / TSB | 7 | 02-15-2016 10:48 AM |
Automatic FRS Surge in Manual Mode | N1rve | Issues | Warranty | Recalls / TSB | 5 | 02-08-2014 12:28 PM |
topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) -- General Topics | 51 | 05-04-2012 07:54 PM |
