86SPEED
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Old 05-28-2019, 09:12 PM   #15
Rybot
Rybot's Avatar
Drives: Subaru BRZ Series.Blue
My Bad
I'd check the preload collars on the coil overs too. They like to work loose, especially the fronts. I have to check mine fairly regularly.
I have to keep the coilovers from spinning to fully tighten that top hate nut, right?
Rybot is offline   Reply With Quote
Old 05-28-2019, 11:01 PM   #16
NoHaveMSG
NoHaveMSG's Avatar
Drives: 13' BRZ
Yes.
I am talking about the pre load collars which tighten the spring though. If there is not enough tension on the spring it could becoming slightly unseated when it comes unloaded and it will make a pop. A quick way to check it is to jack up the car and pull of the wheels, and grab the spring and shake it.
NoHaveMSG is online now   Reply With Quote
Old 06-11-2019, 12:16 AM   #17
df.dima
Drives: FR-S and Mazda 3 Sky
I have similar pop/creak as at the beginning of video when you turn into garage, but more so when I do low speed/parked steering wheel cranking left and right. Its in the exact same spot every time. I dont believe its happening over bumps going straight over, maybe slightly.
I went to my alignement shop and the mechanic checked everything, coilovers, endlinks, suspicion for subframe bolts... He recommended I visit dealership for alternative opinion, he suspects the noise comes from steering rack/column and it "echoes"/vibrates the vibration into an area closer to wheels, that's why it sounds a bit "misleading", in my case I was damn sure its in driver side footwell/wheel area.
Last year, I had a "clunk" over bumps, so mecanic confirmed my bearings are shot,so we replaced stock ones out with STI Group N rubber ones, just barely 5k ago.
That's all I got for now. I tried searching forums, but its a bit hard finding threads about this particular issue via word search. Not everyone posts videos. I can try shoot my video to share for reference.
Here is what I think is same noise as yours and mine:
https://www.ft86club.com/forums/showthread.php?t=124420
- the guy says ended up being bad strut mount, so replaced his strut???
Unconfirmed sound, because video is dead:
https://www.ft86club.com/forums/showthread.php?t=107615
- "a loose/faulty link in the steering column"
Found no-video/audio thread where TS replaced strut.
While another person in same threa confirmed his case was sway-bar bushing...
Fun
df.dima is offline   Reply With Quote
The Following User Says Thank You to df.dima For This Useful Post:
Rybot (06-11-2019)
WTB: OEM suspension components Agent_D Want-To-Buy Requests 0 03-20-2018 05:31 PM
Groan and Creaky Front Suspension??? jadewbj Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-30-2017 12:52 PM
FS: AVO suspension components Avo1789 Brakes, Suspension, Chassis 7 01-15-2016 07:25 AM
Rear Suspension Components jgardner Want-To-Buy Requests 4 07-28-2014 10:55 PM
Koni Suspension Components dale.m Suspension | Chassis | Brakes -- Sponsored by 949 Racing 76 06-20-2013 09:00 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
