Old 08-03-2015, 06:57 PM   #1457
swarb
@JellyForSale Why did you go for such a big sidewall and a staggered setup? Do you know your speedo is being thrown off by a lot? It seems so wrong in so many ways.
Old 08-03-2015, 07:13 PM   #1458
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Agreed it looks odd. Compared to the jeep in the back the car looks pretty high up.
Old 08-03-2015, 07:33 PM   #1459
JellyForSale
That Striped FRS
JellyForSale's Avatar
Drives: 2013 Ultramarine FR-S 6MT
It's a rwd car, so I wanted the max width I could get out of front/rear without any rubbing on stock suspension. Sidewall is because of Pennsylvania pot holes. It looks monter truck because it's still on stock suspension and height and the sidewall is 45 as opposed to more common 35 I will admit that I feel the sidewalk is too much but it's a learning experience. For now it's very race car. Next is coilovers to alleviate the new growth spurt it just took. Either way I'm still in love with the car and my build so far. Always evolving.
JellyForSale is offline   Reply With Quote
Old 08-03-2015, 08:03 PM   #1460
swarb
Do you know your side wall/diameter is too big and it is throwing off your speedo by a good 10%? YES 10%. People buy 4.56 final drives to replace the stock 4.10 gears, which is about 10% difference. You went the opposite way and made your gears 10% longer!
Width and height are two different things. You could have put a 255/35 or even a 245/40 and it would have fit much better. If you wan't pot hole protection, you would get 17's or 16's.
Your setup is wrong in so many ways, I don't know what to think so I will leave this here.
Old 08-03-2015, 08:33 PM   #1461
JellyForSale
That Striped FRS
Im building to to own standards, not yours. As a build in progress nothing is wrong with that I have going on. Is it tall? Yes. Is the speedo now wrong? Yes. I dont know why you once again stated that. I own the jeep in the back ground that is lifted and larger tires. I understand how a speedometer works. Yes I did probably mix up the words height/width in my post but I understand the difference. And if i want pot hole protection WHILE keeping my 18s I will get taller side wall to cushion. I don't understand why you're talking down over the fact that my tires are x/45/18 opposed to x/35/18.
Old 08-03-2015, 09:16 PM   #1462
swarb
I stated it twice because it was a question that was not answered.
You mixed up height/width, not me.
Im talking you "down" because you stated width not height. You made the mistake, stop trying to be defensive about it.
Go ahead and build it to your own standards. But when you post it on a forum, expect responses.
Nothing is wrong? Good one!
Do you have a profile pic?
Old 08-03-2015, 09:30 PM   #1463
JellyForSale
That Striped FRS
@swarb
I did say I knew the speedo was now off in my second reply to you. So your first line is wrong.
I also admitted that I used the wrong words. So your second line is wrong. I never said you did.
Same as above. Not being defensive, just wondering if you read where I admitted that I used the wrong word.
I expected responses. See how @ZOMFGAARON stated his opinion but didn't act like a know it all? Hence why I didn't reply, I am genuinely happy he gave his opinion.
Im fairly certain you can see my profile picture on here. I am really not sure what your last question is getting at.
Old 08-03-2015, 09:32 PM   #1464
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
I'm interested in seeing when you lower it. Are you worried about rubbing? Any fender work in the future?
Different strokes for different folks, one thing that seems to be forgotten on this forum quite often.
The Following User Says Thank You to ZOMFGAARON For This Useful Post:
JellyForSale (08-03-2015)
Old 08-03-2015, 09:33 PM   #1465
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Both of you shut the hell up and post pics of meaty tires.
- The Ancient BRZ Sacrament
by Zaku
The Following 5 Users Say Thank You to Guff For This Useful Post:
civicdrivr (08-04-2015), drewbot (08-13-2015), kch (08-04-2015), Porcupint (08-11-2015), WHITE (08-09-2015)
Old 08-03-2015, 09:51 PM   #1466
JellyForSale
That Striped FRS
Rear has 255/45/18. @swarb Best shot I have but you can see ever so slight rake. Coilovers will be used to fix it.
Im definitely concerned with the rear. If I had to guess, I'll be worried about that spot where the fender meets the bumper in the rear, and I'll be lowering the front to match the height of the rear Not going to the slammed look. Just lower to I lose my monster truck status
The Following User Says Thank You to JellyForSale For This Useful Post:
Hicklinc (02-25-2018)
Old 08-03-2015, 10:00 PM   #1467
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I personally think it looks good, and it'll look better once dropped a little bit.
The only thing I want to know is if your traction control kicks in because of the front/rear difference in height.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Old 08-09-2015, 03:12 AM   #1468
manualmotive
manualmotive's Avatar
Drives: '14 BRZ Todoroki/OriginLabo
manualmotive is offline   Reply With Quote
The Following 4 Users Say Thank You to manualmotive For This Useful Post:
Hicklinc (02-25-2018), Jdogg88 (08-11-2015), nima314 (06-12-2016), WHITE (08-09-2015)
Old 08-10-2015, 02:04 PM   #1469
Mindsucker
Mindsucker's Avatar
Drives: Honda Civic Type-R FK2
Finally got the new wheels on the car!
Rays TE37SL 18x9.5
Michelin Pilot sport cup 2 265/35 R18
Dropped about an inch all around on KW V3 coilovers
Mindsucker is offline   Reply With Quote
The Following 3 Users Say Thank You to Mindsucker For This Useful Post:
DuMa (08-11-2015), Guff (08-11-2015), Hicklinc (02-25-2018)
Old 08-11-2015, 12:17 AM   #1470
c4lvinnn
Drives: Toyobaruion
c4lvinnn is offline   Reply With Quote
The Following 4 Users Say Thank You to c4lvinnn For This Useful Post:
6-Shift (09-14-2015), DuMa (08-11-2015), Guff (08-11-2015), NyC Zn6 (08-11-2015)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
