#6693 |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
MAF intake, MAP intake manifold, correct.
The Following User Says Thank You to Dustin For This Useful Post: | whataboutbob (11-23-2015) |
#6694 |
Twin Screw You
Can you take a picture or something? Lol
#6695 |
Drives: 2013 DGM BRZ
As soon as it stops raining outside sure
"Don't ask me...I just work here"
#6696 |
Ok so I am a tard. Forgot to take the map sensor off. So what do I do with the MAF sensor and what does this hose go to?
![]() Sent from my SM-G900V using Tapatalk
#6697 |
Drives: UK GT86
MAF sensor goes back where it started, on the intake.
Can't be of help with the pipe.... it's all in the instructions though.
.: Stealth 86 :.
#6698 |
Ok so the MAF goes back into the stock air box which I have already replaced with a Grimmspeed box. So custom mount them.
#6699 |
Drives: Subaru Brz
hey where did you get the metal intake pipe?
#6700 |
Good news: I have the SC fully installed and correct.
Bad news: My tune from Delicious Tuning was for an automatic, I drive a manual ![]() Sent from my SM-G900V using Tapatalk
#6701 |
AutoX-10/10ths every run
Center input on rear of blower.
[ Delicioustuning | Blue Moon Performance | Winmax | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] |
#6702 |
Got her all set up and the tune on. Now i just need to work with Delicious Tuning to fix the tune so she does sputter and stall like she is doing.
#6703 |
Twin Screw You
What version of his tune are you running? When you first start it up, you will need to drive it for a little bit for the computer to learn everything.
#6704 |
Driving it is the last thing I want to do right now since the AFR is sitting around 20.
#6705 |
Drives: Smells like tires when I drive
#6706 |
At idle. Figured out it was two of the bolts on the throttle body had stripped out and weren't forming a seal. Fixing it as I type sort of.
^Not the issue. I still hear air bypass the system. Ive tried to find it with leak detector, cigar smoke and soapy water. Nothing. There is a vacuum leak some where in the system that is causing my car to sputter due to a high ARF. Does anyone have any ideas how to fix this? Sent from my SM-G900V using Tapatalk
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
