Software Tuning Discuss all software tuning topics. |
05-30-2019, 01:53 AM | #1 |
Drives: Boosted
Buckling concerns on turbo
Hey everyone. I have a jdl turbo that was installed about a month ago tuned by James @ HRI(I believe he's on vacation or something). Anyhow, at around 4k rpm it feels like theres intermittent fuel cutting cruising at that rpm / 80mph. It does this on occassion accelerating as well. I took a log of it if anybody wants to chime in.
Parts: 1050x injectors dw265lph fuel pump delicious flex fuel kit+ with upgrade 2867r turbo w/ upgraded intercooler from jdl jdl catchcan 3" overpipe / frontpipe from jdl w/ stock catback https://ufile.io/5qdf04nn Is the .csv file I sent him the log already but he hasn't gotten back to me yet so just wanted to see if anyone wants to chime in. |
05-30-2019, 05:01 AM | #2 |
Drives: brz 2017 hksv2
cna you upload logs to datazap
that link opened like 40 popups in my phone and had to reboot it to make it usable again |
05-30-2019, 05:18 AM | #3 | |
Drives: Boosted
05-30-2019, 05:28 AM | #4 |
maybe intake leak since you have a crazy -30 fuel trims
05-30-2019, 05:41 AM | #5 |
Drives: Boosted
05-30-2019, 06:05 AM | #6 |
something is off anyway, can t believe James left you with those trims
05-30-2019, 06:13 AM | #7 | |
Drives: Boosted
https://jdlautodesign.net/shop/ft86-...turbo-system/# If we take a look at the tube, it has a nipple on it. Does that need to be covered? |
05-30-2019, 06:17 AM | #8 |
Drives: FT86
Fueling seems strange 15% accelerator and target afr 15. Fuel trims like tom brz said seem off up to -30.
If your sure no leaks, check no oil on maf sensor. Manifold pressurecseems strange as well assume its absolute . Reads below 14 psi atmospheric so its producing no boost at 4000 rpm with 15-20% accelerator. Check your di computer is bolted up tight all three bolts Check map sensor Difficuult to tell as we dont know if tune is maf or speed density or hybrid |
05-30-2019, 06:19 AM | #9 | |
Drives: Boosted
05-30-2019, 06:23 AM | #10 |
Drives: FT86
05-30-2019, 06:30 AM | #11 | |
Drives: Boosted
All of this is at idle currently. |
05-30-2019, 06:46 AM | #12 | |
Drives: Boosted
heres idle, also just went outside to check for any leaks. No leaks. MAF sensor bolted on properly. Could the catchcan be the issue? Sorry, what's a di computer? |
05-30-2019, 07:23 AM | #13 |
Drives: Boosted
05-30-2019, 09:32 AM | #14 |
Rust bucket enthusiast
Where is that hose coming from? If that's a pcv catchcan, your feed from the engine should be going to the top port.
Did you clamp down the hoses UNDER the intake manifold? Here's a glimpse of mine in the middle, you can see a worm clamp on one of the 3 hoses. |
Similar Threads | ||||
2017 T86 concerns | GTspeedster | Issues | Warranty | Recalls / TSB | 12 | 03-29-2018 08:34 AM |
OFT Observation and concerns | Kayysonie | Software Tuning | 30 | 12-07-2016 12:55 AM |
e85 concerns | Lantana frs | Engine, Exhaust, Transmission | 6 | 06-29-2016 03:02 AM |
Some Concerns?? | KevinYeh | BRZ First-Gen (2012+) -- General Topics | 14 | 06-30-2014 04:03 PM |
K&N air filter .... any concerns ..?? | humfrz | Engine, Exhaust, Transmission | 3 | 11-26-2013 01:25 AM |
