Tracking / Autocross / HPDE / Drifting What these cars were built for! |
Would 245/40R17 A052 fit on 17' BRZ with OEM struts?
Hi,
I am seeking for advice on Yoko A052 tire fitment. My BRZ is on OEM springs/struts with Verus camber plates/APC camber bolts in front and rear lower adjustable control arms. I know that 235/45/17 A052 would fit without clearance issue. This tire is so wide. I don't know if 245/40R17 would fit without rolling the fenders. No plan to upgrade to coilover for this seaon. 245 is not available here in Canada. I plan to order a set from the State. But I want to find out if it would fit. I really appreciate from someone can confirm the fitment. Thanks. |
#2 |
Drives: 2017 BRZ series.yellow
Need to know wheel offset.
I don't see any reason why they wouldn't fit with the right wheel offset. |
#3 |
Purist
Drives: 2013 FRS - Hot Lava
Offsets between +35 to +42 will fit a bone stock car without issue. Thats with a 17x9 wheel.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
#4 |
#5 |
Drives: '17 BRZ PP
Yeah, I'ma say +35, and NO camber from bolts, all from camber plates. +42 isn't gonna clear I don't think... I had to run 3mm spacers with my 17x9 +40 wheels to have clearance for 225/40-17 Hoosiers which are 9.6" or 244mm wide. And 245 A052s are a bit wider at 9.9" or 251mm.
The Following User Says Thank You to ZDan For This Useful Post: | RToyo86 (01-15-2021) |
#6 | |
Purist
+40 should be perfect on a stock car with +35 being able to run camber bolts.
#7 |
Drives: Too fast
I run 17x9 +35 w 245 40 17 Hankook RS4 on stock struts and springs with maxed camber bolt and maxed crash bolt in lower hole and it does not rub on struts without spacers. I run 3mm spacer though for wider track and safety as it can get closer than I want under track load as lower pressures.
Enjoy ! |
#8 |
Drives: Crapcan
OP has camber bolts which incline the hub towards the strut.
#9 |
Thank you all for your inputs.
I will install camber plates this season. It will give me -3 degrees from it. Another ~0.6 will be from the bolts. I hope that it would good enough clearance for any rubbing. For your reference, a friend of mine ran RS4 (245/40R17) on 17x9+35 rim on his FRS. It was fine. He has to add a 3mm spacer in front to clear the A052 235/45R17 on the same wheels. That made me worry about rubbing going to A052 245. Last edited by Samba; 01-15-2021 at 01:22 PM. |
#10 |
It'll depend on your chosen wheel.
You're gonna need a very low offset, which I don't recommend. |
#11 |
Drives: Too fast
I prefer going against what you recommend than slashing a tire and potentially harming myself and others.
#12 |
Custom User Title
Listen to Mike on this or you'll cut a 4mm deep line across your sidewall after just 20 feet of driving.
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
17x8 +40 Konig Dekagrams (black) with 215/45/17 A052 (ONE heat cycle) | pcs | Wheels and Tires | 1 | 03-10-2020 09:10 PM |
Advan a052 or other suggestions? | 2Wavy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 07-15-2019 05:51 PM |
Yokohama Advan A052 review | nikitopo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 12-06-2018 09:18 AM |
Airlift performance air struts (only struts) | RavenFR-Sowner | Brakes, Suspension, Chassis | 1 | 11-01-2015 04:51 PM |
Hankook Ventus Evo V12 K110 - 245/40R17 and 255/40R17 $40 rebate, wholesale | Gruppe-s | Wheels and Tires | 7 | 10-21-2014 02:11 PM |
