05-06-2021, 07:26 PM | #77421 |
1st86 Driver!
Hmm, that may explain why I've gained 35-70 lbs since I bought it....trying to keep up with later models to keep it fair....yea that's it.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following 4 Users Say Thank You to Dadhawk For This Useful Post: |
05-06-2021, 07:27 PM | #77422 |
Site Moderator
Drives: ichi 86 Project
I buy lighter parts, so I can gain weight lmao
05-06-2021, 07:35 PM | #77423 |
Site Moderator
Psssh and you say you're in the lower end area. Only pool I got is this.
The Following 2 Users Say Thank You to ichitaka05 For This Useful Post: | soundman98 (05-06-2021), Tcoat (05-06-2021) |
05-06-2021, 07:46 PM | #77424 |
Persona Non Grata
Drives: '15 BRZ (WRB)
I don't worry about lighter parts because, while I could lose weight, I almost certainly won't and all the money would be wasted.
Slow is smooth, and smooth is fast
The Following 5 Users Say Thank You to Capt Spaulding For This Useful Post: | Dadhawk (05-06-2021), ichitaka05 (05-06-2021), soundman98 (05-06-2021), Spuds (05-06-2021), Ultramaroon (05-06-2021) |
05-06-2021, 08:06 PM | #77425 |
Well the pool is probably as old as you are so it isn't a good indication of wealth!
The Following User Says Thank You to Tcoat For This Useful Post: | ichitaka05 (05-06-2021) |
05-06-2021, 09:59 PM | #77426 | |
Sent from my SM-G975U using Tapatalk |
The Following 2 Users Say Thank You to p1l0t For This Useful Post: | ichitaka05 (05-06-2021), soundman98 (05-06-2021) |
05-06-2021, 10:38 PM | #77427 |
¯\_(ツ)_/¯
Drives: '15 ultramarine
The wife just dropped a 6lb container of popcorn kernels, shattering it on the kitchen floor. We will be finding kernels for decades.
The Following 8 Users Say Thank You to Sapphireho For This Useful Post: | ichitaka05 (05-06-2021), MICHAEL450f (05-06-2021), NoHaveMSG (05-06-2021), p1l0t (05-07-2021), soundman98 (05-06-2021), Spuds (05-06-2021), Ultramaroon (05-06-2021), wolffbite (05-07-2021) |
05-06-2021, 11:56 PM | #77428 | ||
ProCrastinationConsultant
but your panel looks very clean and well put together. no double wires under single screws, the original installer took the time to keep everything clean. though that a/c wire install is a little hacky-- if it's a normal residential a/c unit, that's only a 2-wire and a ground connection, they were likely using the white as the ground-- would need to check the disconnect on the side of the house to confirm. but there are plenty of people that still believe that the ground is 'optional' everywhere. causes major issues later on... lol. normal 2x4's used to be about $2 each. they're now $15. it'd be at least $300 in materials!
The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
05-07-2021, 12:05 AM | #77429 | |
05-07-2021, 12:08 AM | #77430 | |
義理チョコ
My entire life has been a lie.
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (05-07-2021), soundman98 (05-07-2021) |
05-07-2021, 12:11 AM | #77431 |
¯\_(ツ)_/¯
The Following 4 Users Say Thank You to Sapphireho For This Useful Post: |
05-07-2021, 12:55 AM | #77432 | |
義理チョコ
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post: |
05-07-2021, 01:15 AM | #77433 |
The Following User Says Thank You to humfrz For This Useful Post: | p1l0t (05-07-2021) |
05-07-2021, 06:52 AM | #77434 | |
Here is a listing of the projects in London. Keep in mind that the rents in most cases are 30% of whatever you earn so they are filled with multigenerational welfare recipients. https://london.ca/sites/default/file...%20Booklet.pdf
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | NoHaveMSG (05-07-2021), Ultramaroon (05-07-2021) |
Similar Threads | ||||
Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 10:31 AM |
Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
