04-08-2021, 11:58 PM | #2017 | |
Drives: brz 2017 hksv2
if LTFY is positive it means it runs lean and the exu corrects in this case the trims learning is a bit erratic, but anyway we do not have the afr target in the log, we dont really know yet yes need a maf scaling and definitely a timing reduction PM for help if you want Last edited by tomm.brz; 04-09-2021 at 12:19 AM. |
04-09-2021, 02:03 AM | #2018 | |
Drives: Toyota 86 GTS
Give it more time to learn LTFT in closed loop, then maybe switch to a richer version as it looks like it'll be lean once ltft settles. Pulling timing or ****ing with the anything else in the tune based on a half-arsed cursory glance before ltft has settled is sure to waste your time, like what happens to most who post in here now days.
04-09-2021, 05:28 AM | #2019 | |
Barred
Drives: My18 wrxsti My19 brzts
I may be wrong, his intake may have some influence, you never know
Wait until my Flex capacitor hits 88
04-09-2021, 05:47 AM | #2020 | |
the rich afr is a result of incorrect applied positive ltft Also, oft "afr actual" has ALWAYS been bugged, since forever it gives richer than OBD afr actual value Wayne says about this in his website, but no one remembers it You need to log afr command to help seeing it better, and remember of the offset caused by the bug It is a more vast topic, so that you actually are allowed to not care if the 11.6 AFR it gives, is a real 11.6 or a 11.8.... Also because the lambda scaling is SUBJECTIVE to the tuner Wayne tune's measured 12 AFR is different from my tune's measured 12 AFR... but you have to keep in mind the bug anyway wayne gave good advice to try personally i prefer to spend time and do custom tuning and disable ltft in open loop but to each his own. |
04-09-2021, 07:16 AM | #2021 |
Barred
BUGALUGS
04-09-2021, 09:28 AM | #2022 |
Drives: 2017 BRZ blue
Hi Wayno
What do you mean by "give it time to learn". I have been driving around 3000 km since i flashed the -2% tune. BTW My intake is standard apart from a K&N insert. |
04-10-2021, 12:34 AM | #2023 |
Barred
Wayno has taken my money and locked me out of my files
04-10-2021, 01:12 AM | #2024 |
Then wait for him to unlock them? where s the problem
04-10-2021, 08:12 AM | #2025 |
That's incorrect. You have the files you paid for. I know this because
1. I have a log of every file downloaded, 2. You constantly bitch and moan about them, and 3. You posted parts of them on this forum which the site kindly asks not to. |
04-10-2021, 08:20 AM | #2026 |
I will message you. I've not found anyone with MY17+ willing to do any real testing since shortly after the refresh.
04-10-2021, 09:07 AM | #2027 | |
anyway the guy has TD headers, they need different timing they aren t good as ace and they are very different from short EL Also adv timing i think they are too high for 20% PI at high rpm 100 ron fuel , at least in Italy is not so good, it s just a little better than 91 oct of course you can ignore this |
04-10-2021, 11:53 AM | #2028 |
Barred
Well excise me I don`t have any of the files on my pc any more and certainly not V164. So your saying I have To pay again? Seems a bit Unfair.
04-12-2021, 04:58 AM | #2029 |
Barred
So your tunes are untested? WTF. So you need Crash Test Dummies for your WAYNO GOOD TUNES
04-12-2021, 05:25 AM | #2030 |
Drives: Orange GTS
Hi all, I just logged a 3rd and 4th gear pull, Wayne's V163 AT A01I. A fair bit of knock in 4th gear. Was thinking changing Eng load @ 3800 1.15 to 1.05 to help the rich dip and pull some timing up top and. Comments appreciated. Cheers https://datazap.me/u/vk3xhm/v163-mod...=1-3-6-8-10-11
Similar Threads | ||||
RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
