07-19-2020, 09:21 PM | #10851 | |
Drives: 2017 toyota 86
Have you tested them spooling yet? Just undo at TB make sure the Y pipe and everything is working. |
07-19-2020, 09:30 PM | #10852 | |
Sent from my GM1915 using Tapatalk |
07-19-2020, 09:37 PM | #10853 | |
I would assume he would load a premade base map probably a modification of your current tune but pulling out maybe 3 degrees of timing and adding 15% more fuel. And then slowly add more timing / lean out fuel each run to get closer to the limits. Could ask him to send you the base tune map so you can safely double check it’s all working correctly. Don’t want to find/troubleshoot issues while on the dyno and waste dyno time. Or since you have OFT could modify it yourself or hit up steve99 or wayno to help with base tune. |
07-25-2020, 03:57 PM | #10854 | |
Now just to bring the cost down I've decided to go with an E tune from OFT. Once I get the the E tune completed. I will do another VDyno and compare it with my last one. To see the improvement between the two. Sent from my GM1915 using Tapatalk |
07-25-2020, 04:16 PM | #10855 | |
Did you add additional batteries to the setup and have each esc have it’s own dedicated battery system? Could try running both but bypassing one, having one just blow into engine bay, to see if it has to do with battery draw on the system can’t keep up Could also try running in tandem instead of compound possibly the 2nd ESC isn’t strong enough to compress the pressurized air from the 1st esc properly. Are you positive the Y pipe is fully closing and not bleeding off some of the boost? Could try to cap it off or just bypass it to test. .3 drop is a lot better than I thought. Did you get a IAT before and after to see how much heat it’s reducing? Could try testing the batteries maybe getting old? |
07-25-2020, 04:26 PM | #10856 | |
As for the bypass valve jelke from torqamp assured me that it was tested before sending them out. I'm not sure under how much pressure they test them but he said it should be able to hold the boost no problem. I could try the y pipe but the y pipe was not recommend since the amount of mad air flow would double it could cause the engine to surge. I could also try switching the turbos around maybe one is pushing more than the other. And I might have the one pushing harder first. Sent from my GM1915 using Tapatalk |
07-25-2020, 09:04 PM | #10857 | |
07-25-2020, 09:17 PM | #10858 | |
07-25-2020, 09:23 PM | #10859 |
I haven't hit redline since the car isn't tuned I'm kinda scared to. I was going full throttle 3rd gear from 3500rpm to about 5500rpm and I would hit 5.3psi. and I assume that rather than before where it would taper down to 2psi it'll only taper down to 3psi
07-25-2020, 09:31 PM | #10860 | |
Or running an aftermarket boost gauge? |
07-25-2020, 09:33 PM | #10861 |
07-25-2020, 09:44 PM | #10862 | |
Stock map sensor only reads to 5.6psi. Looking at your intercooler setup I thought it would create a good 1-1.5psi drop. I bet you are making closer to 7psi when bypassing it. You have OFT so you could datalog this. With intercooler you peaked 5.3psi what did it drop to by 5.5k?. Did it hold onto that 5.6psi when bypassing it for a lot higher rpm? If say 3.5k rpm intercooler peaks 5.3psi but by 5.5k drops to 4Psi. If non intercooler 5.6psi peak at 3.5k but it holds onto it till 5.5k, or maybe makes 5.5psi at 5.5k rpm you can see the real difference. Or just get an aftermarket market map sensor, or install boost gauge. |
07-25-2020, 09:48 PM | #10863 | |
07-25-2020, 10:00 PM | #10864 |
Interesting. I know ecutek it only reads 19.9 total psi with stock map, which minus 14.7psi ambient is 5.2 psi. With my scangauge it’ll read to 5.6psi. My mechanical gauge however says i am at 12.5psi. I don’t remember what OFT map reads. I know stock sensor is very limited though. I would stop doing pulls until you get a new MAP sensor or at least boost gauge to see real numbers. Maybe you are really making about 7psi. It would be surprising to me at least with bypassing intercooler if you didn’t. But that intercooler should have a 1-1.5 psi drop.
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
