Old 05-02-2016, 03:17 AM   #29
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by IgnitionGundam View Post
So what you're saying is if i use the RESISTOR to turn off the airbag light, those airbags will not deploy?
Well Im thinking of when you use a resistor on a seat that doesnt have airbags you plug it in to the body end of the harness to turn the light off and for the rest of the airbags to function normally. I have no idea what would happen if you plugged one into the seat itself as well
Old 05-02-2016, 08:02 AM   #30
Wpomp
Drives: Asphalt FRS
Originally Posted by that_guy View Post
Were you ever able to resolve this? I have the same issue in my car. Would love to just reset this and go but every time I do the car just throws the code again anyways.
I was never able to get it functioning as stock, just with the airbag always on needing the belt to be buckled (to stop the chime). Sorry I can't be more help. Wish I had a solution for you!
Wpomp is offline   Reply With Quote
Old 05-02-2016, 05:25 PM   #31
that_guy
Dances with Cones
that_guy's Avatar
Drives: 2013 Scion FR-S Raven
I'm using Techstream on mine tomorrow. I wonder if the occupancy sensor needs to be cleared of its codes. It's independent of the main ECU.
I was able to get it to partially work by swapping the sensor and buckle from my FR-S seat to the BRZ seat, but the occupancy sensor seems to need calibration as it's way too sensitive.
I'll know more tomorrow and will post up here if I find a resolution.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD
that_guy is offline   Reply With Quote
Old 10-11-2016, 04:32 PM   #32
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
So I assume that there is no solution so far?
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 10-14-2016, 05:36 PM   #33
Figo
Figo's Avatar
I have a guess.
Is it because some BRZ seats do not have the sensor in it?
This one.
I know people take it out and install under floor mat when installing aftermarket seats.
So if you but a pair of seats missing the sensor on passenger side, you will have the airbag issue.
If the seat is 100% oem, should not have such a issue?
Old 10-25-2017, 02:34 AM   #34
jorgerendonjr
Drives: Frs
Bump?
jorgerendonjr is offline   Reply With Quote
Old 02-14-2021, 12:18 PM   #35
Damseldunbar
Damseldunbar's Avatar
Drives: 2013 GTS Toyota 86
Curious, is it legal to remove the passenger seat and just leave it out?
Damseldunbar is offline   Reply With Quote
Old 02-14-2021, 01:24 PM   #36
soundman98
ProCrastinationConsultant
soundman98's Avatar
there's no law i'm aware of that demands that a vehicle has a specific number of seats. just laws requiring safety restraints for the occupants within. so as long as there's no one attempting to ride on a bucket or folding chair, i believe it's legal.
Old 02-14-2021, 09:16 PM   #37
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm .. i'd check that though. After hearing story from my colleague, who needed every year for his motorcycle MOT to change spacer back to passenger seat (both are "OE" bits, just because his motorcycle was initially registered as two seater) .. i'd expect all kind of idiocy in some local rules. And while there are no rules, what specific part needs to be, very possible, that there are rules, that one cannot legally modify any OE safety equipment.
The Following User Says Thank You to churchx For This Useful Post:
soundman98 (02-15-2021)
Old 02-15-2021, 02:08 AM   #38
soundman98
soundman98's Avatar
It might very well be one of those grey areas that no law explicitly says, but the wording of the laws implies that a certain number of seats and restraints are always present in the vehicle.
Old 03-23-2021, 12:39 AM   #39
finch1750
finch1750's Avatar
So anyone else have experience with this? It seems like swapping the FRS sensor over keeps the dash light off but triggers the always on?
I have the chime disabled so that would be OK in the end for me.
Old 03-27-2021, 03:07 PM   #40
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
On most things like this you need to swap the module under the seat AND the seat belt latch assembly. After doing so your going to have to re-calibrate the OCS weight sensors. Of which you'll need some weights and a higher-end scan tool to do it.
The Following User Says Thank You to Kiske For This Useful Post:
finch1750 (01-05-2022)
Airbag light trick for racing seats. Ricepuddin DIY (Do-It-Yourself) Guides 111 03-18-2024 08:05 AM
Bucket seats - airbag issue smudge Cosmetic Modification (Interior/Exterior/Lighting) 18 03-04-2017 10:45 PM
86 Airbag installed! Trojan_SC Cosmetic Modification (Interior/Exterior/Lighting) 218 02-09-2015 03:45 AM
Airbag and Fog lights installed! Kitty Southwest 3 10-24-2013 04:01 PM
Airbag light norcal_brz Issues | Warranty | Recalls / TSB 6 03-27-2013 02:59 PM
