Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
02-24-2021, 02:38 PM | #1 |
Drives: 2019 Subaru BRZ - JDL Turbo Kit
Single vs. dual resonated front pipe
Hi all,
I wanted to get some opinions before ordering a new front pipe. I'm going with the JDL front pipe but I'm deciding between just a single resonated front pipe vs dual resonated My current setup: JDL Catless UEL Stock Front Pipe 2.5" resonated Perrin catback I love the tone right now but want something slightly louder but not raspy or drony. The cat in my front pipe at the moment is kinda going so I figured might as well just for a nicer quality pipe. Will nuking the cat in the front pipe make the car significantly louder? Is there a huge difference between single vs dual resonated? the perrin exhaust is already resonated |
02-24-2021, 02:50 PM | #2 |
Drives: 2018 Subaru BRZ
I'd go double resonated. There isn't much difference between single and dual, but a double would be better reducing the drone and rasp. Either that, or a FP with a High Flow Cat.
The Following User Says Thank You to spcmafia For This Useful Post: | DoubleAKash (02-24-2021) |
02-24-2021, 03:14 PM | #3 |
thank you, I figured there wasn't that big of a difference I think I'm just going to order the dual resonated pipe
02-24-2021, 06:13 PM | #4 |
Drives: 2017 toyota 86
I had hks double res FP it eventually cracked at a weld, then I took oem front pipe and a a crowbar and smashed the cat out. They did sound slightly different. Both sounded great. Neither droned or rasped. In the end I think smashing out cats on oem is the way to go. It’s free after all, sounds great, and nets 100% of the gains to be had.
02-24-2021, 06:43 PM | #5 |
Drives: Bone stock
Definitely dual resonated!
Sent from my SM-N960U using Tapatalk |
02-25-2021, 02:29 AM | #6 |
Drives: BRZ 2018
Dual HKS last version with new type welds here (first version welds failed), almost OEM noise but did a difference in the torque curve
The Following User Says Thank You to JIM THEO For This Useful Post: | Thefalls (02-25-2021) |
02-25-2021, 02:50 AM | #7 |
Drives: brz 2017 hksv2
dual hks is quieter also because is smaller with 60,5 mm
02-26-2021, 02:14 AM | #8 |
Drives: 2017 PP BRZ
My HKS resonated FP cracked at the welds. I am looking into JDL Dual resonated FP!
02-27-2021, 06:33 PM | #9 |
Drives: Bone stock
03-03-2021, 12:12 AM | #10 |
Drives: 2017 PP BRZ
06-04-2021, 01:03 AM | #11 |
Drives: 2012 Subaru BRZ
At the moment I am running Tomei UEL catless header, stock overpipe, front pipe and HKS Hi-power Spec L catback with titanium tip. Idk about other people but it drones like hell from 2k-5k rpm especially under load (e.g. holding ur accelerator while going uphill) . I was looking into the hks dual resonated front pipe, just wondering how different did you find it vs oem front pipe in terms of volume and drone? And if your hks front pipe cracked at all? (saw a lot of people complaining of that issue) Thanks!
06-04-2021, 10:22 AM | #12 | |
I'm running a Spec L also, and I'll have to tell you, your issue has to do with hangers. This is where it gets fun. Check out this thread https://www.ft86club.com/forums/showthread.php?t=143514 It basically discusses how JDM hangers (BECAUSE JDM BRO) are way better at reducing cabin vibrations and drone. I bought all 5 from Nengun and the vibration/Drone was reduced by 80% or so. This is while running a full exhaust with catted UEL headers and Double Res FP rom HKS. The older versions of HKS products do tend to crack, but it was fixed on the newer generations. I haven't had any issues with any of my HKS products so far. The thing about those hangers, is that now their lead times are about two months, I think we depleted the hanger stock in Japan. Get on the line now before the news of those hangers make their way to social media and people do really start going nuts. I know it sucks because it is a nice sounding exhaust, it does drone like hell at lower rpms or going uphill, but those hangers do work.
06-04-2021, 07:21 PM | #13 | |
06-04-2021, 07:31 PM | #14 | |
I want to say its just Subaru Japan thing. But that is interesting, you car might already have them, I would check. When I got them it was $6 each. But if you can find them cheaper, same part number, go for that. Some people are going Blackhawk. Sent from my iPhone using Tapatalk
Similar Threads | ||||
Looking for HKS dual resonated front pipe! | Raframi | Want-To-Buy Requests | 0 | 09-29-2020 10:57 PM |
FS: HKS Dual Resonated Front Pipe | carsebuco | Engine, Exhaust, Bolt-Ons | 11 | 01-11-2019 11:54 PM |
WTB HKS dual resonated front pipe | IceMeister | Want-To-Buy Requests | 4 | 10-31-2018 08:21 AM |
WTB Dual Resonated HKS Front Pipe | carsebuco | Want-To-Buy Requests | 2 | 08-18-2018 08:50 PM |
Catted UEL Header and Catless resonated/dual resonated front pipe? | deuncos | Engine, Exhaust, Transmission | 3 | 04-23-2016 01:30 PM |
