Old 08-31-2017, 01:10 PM   #281
CSPTK
Drives: 2014 FR-S
5th gear is 1:1. So you want to do your dyno pulls in 5th.
CSPTK is offline   Reply With Quote
Old 08-31-2017, 02:05 PM   #282
JermMX5
Drives: 2017 Toyota 86
Originally Posted by sean.yao View Post
I think it was in 4th on dyno dynamic. not sure about it. was shocked at that point.
Ya on my dyno day he did it in 4th first and it did like 168ish then 5th got my the 177 consistently.
But still that doesn't make sense why your bolted on would be so low
2017 Toyota 86 - Whiteline 20mm Front Bar | Crash Bolts | 235/45/17 RE-71R | 17x7.5 OZ Omnia | OFT Stage 1 For Street Driving | Trackpipe for AutoX | Not enough camber.
JermMX5 is offline   Reply With Quote
Old 08-31-2017, 02:26 PM   #283
nunonuna
nunonuna's Avatar
Simple obvious reason..
Dynojet vs Dyno Dynamics
나의 SM-G935V 의 Tapatalk에서 보냄
nunonuna is offline   Reply With Quote
Old 08-31-2017, 02:33 PM   #284
sean.yao
Drives: 2015 BRZ
Yes, but no. I think ptuning has their dyno set up to read higher that regular one. That's why some stock car with only a cat-back can do over 170whp or even 180+. Compare to that my dyno number seems to be wired though.
sean.yao is offline   Reply With Quote
Old 08-31-2017, 02:49 PM   #285
nunonuna
nunonuna's Avatar
Sorry, I read your comment again & I missed that you and other stock car were done on same day, same dyno. Yeah, that seems strange
Old 08-31-2017, 02:53 PM   #286
Nobunnyhere.86
Drives: Scion FRS
http://www.datazap.me/u/nobunnyhere8...l?log=0&data=1
Here is a new run with the 3.0 Stage 2+ 91 tune from my 2016 scion frs. Currently running catless EL headers and catless front pipe. If i am not mistaken i am reading some knocks? i could be wrong. I sen tthis in to shiv aswell so i am waiting on a reply from him. Also if anyone possibly has a new 3.0 E85 tune for the "40C bin" 2016 models ? i want tto do some testing on that tune aswell. Thanks Everyone!
Nobunnyhere.86 is offline   Reply With Quote
Old 08-31-2017, 04:11 PM   #287
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Did you ask Shiv if that tune was ok for EL headers? I was under the impression the Stage 2+ was for UEL headers. Unless there are 2 different tunes with the same file name?
smg1138 is offline   Reply With Quote
The Following User Says Thank You to smg1138 For This Useful Post:
Nobunnyhere.86 (08-31-2017)
Old 08-31-2017, 05:18 PM   #288
sIowbrz
Drives: 2015 brz
did a pull in 3rd w/ v3.0 uel tune.
http://datazap.me/u/seanyao/v3-93-3r...2-8-9-10-11-14
a little bit better in afr, from 11.25 to 11.4+ @WOT, others look fine. No sure how much will this get.
Also interested in v3.01 tune? Heard someone has already got them. I wanna try as well.
i believe the v3.01 is for 2017 and the v3.0 is for 2013-2016 model
sIowbrz is offline   Reply With Quote
Old 08-31-2017, 05:20 PM   #289
Nobunnyhere.86
Drives: Scion FRS
"Tune files attached. For a car with a stock header, please; use the Stage 1 tune. For a catted header, the Stage 2 tune and for a catless header, the Stage 2+ tune
UPLOADING TUNE FILES
To upload these files to your OFT, please download and install OpenFlash Manager from our website. You will need to a use a Windows-based PC. Then using the supplied USB cable, connect your OFT to your PC. Once it makes connection, it may apply updates through your internet connection. This may take a minute or two. Once complete, go to UPLOAD DATA and load the attached files into any empty memory slots for Modified tune files. To load, just click on the little folder icon to the right of the memory slot. If there are no unused memory slots, you will need to delete the exiting file(s) by clicking on the red X button to the right of the slot. Once all the desired files are loaded, press START. One this process is complete (it can take a couple minutes), you can disconnect from your PC and connect to your vehicle. Go to TUNING, then WRITE, select the desired file and then follow prompts from there. If you have any questions, please let me know.
Best Regards,
Shiv Pathak
OpenFlash Performance
www.openflashperformance.com"
This is a part of the email i have received from Shiv. So yes i belive i am running the correct tune being catless EL.
Old 08-31-2017, 05:37 PM   #290
sIowbrz
Drives: 2015 brz
uel and el is the same tune. just catted and non catted
Old 08-31-2017, 06:06 PM   #291
invaliduser
Drives: 2017 86
Correct
Sent from my Pixel XL using Tapatalk
invaliduser is offline   Reply With Quote
Old 08-31-2017, 06:24 PM   #292
-Willis-86touge
Drives: Stock
So the version 3.0 tune is it on the website now, cause it still shows the tunes haven't been updated. Or can you only get it sent to you?
-Willis-86touge is offline   Reply With Quote
Old 08-31-2017, 06:29 PM   #293
My Key
My Key's Avatar
Drives: 2017 Toyota 86 - Raven
So far by email, either from Shiv (if he's answering emails at the moment) or from other member's that have them.
My Key is offline   Reply With Quote
Old 08-31-2017, 06:39 PM   #294
Nobunnyhere.86
Drives: Scion FRS
Does anyone by chance have the 3.0 E85 tune for "40C bin" 2016 model? i seriously miss the cornjuice haha
OpenFlash Tablet: Multiple Data Log files! Shiv@Openflash Software Tuning 95 11-09-2017 08:40 AM
OpenFlash Tablet: OTS v2.0 Beta (132 new maps, 12 new XMLs) Available for Download Shiv@Openflash Software Tuning 1062 08-13-2017 04:13 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet v1.55b: BIN files added! Shiv@Openflash Software Tuning 525 04-09-2014 09:42 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
