Old 09-18-2018, 04:46 PM   #715
mhiscott
Drives: 2013 FRS
How spendy was the new dss CV? I recently ordered two of just the boots (with their weird metal rings) from the lads, and when they arrived I found my boot ripped because of an issue with the inner star race on the CV you replaced.
Interested in selling the old CV? I think the part that's bad in mine might be good on your old one.
mhiscott is offline   Reply With Quote
Old 09-19-2018, 11:13 AM   #716
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
$130ish? Shipped I am pretty sure. I had two different quotes and I can't find my invoice at the moment. I changed it out as mine was ran with a ripped boot and dead grease for longer than I care to admit, it was a contributing factor to my vibration, so I am going to assume it was worn out. I will clean it up and see if it might be worth sending out if you are still interested.
Exhaust is doing okay, but it needs some cleaning up and moving a few of the pipes. Might be able to just adjust the hangers a tad. I am going to have to figure out a new trans mount that allows more clearance for 3" pipe. I am not even sure the oval tubing will work with how tight everything is. I also need to raise the car a tad, scraped the oil pan a few times.
You can also see oil on the muffler from the transmission leak. Tried to find where it was coming from again yesterday. It's coming from the passenger side, but up far enough I can't see where.
Old 09-19-2018, 06:23 PM   #717
mhiscott
Drives: 2013 FRS
The only part I need is the inner star race which is the bit that slides onto the axle shaft and retained by a circlip. The one I have has the splines chewed up and it won't engage fully onto the axle shaft so I can get the c clip on.
Old 09-19-2018, 07:37 PM   #718
.Kyle
Drives: it's grey
https://www.pelicanparts.com/catalog...SUSAXL_pg2.htm
.Kyle is offline   Reply With Quote
The Following User Says Thank You to .Kyle For This Useful Post:
DustinS (09-21-2018)
Old 09-25-2018, 02:20 PM   #719
DustinS
DustinS's Avatar
New headlights built over the weekend. Bodyshop cleaned and cleared the lens, and paint matched the inside. I also installed some Halos. I love how it came out.
Putting all the wiring sucked after cleaning up most of the wiring. Need to do it all over again at some point.
Paint match is pretty subtle. I was expecting it to pop out more, and wasn't sure I was going to like it. I am loving it so far.
I also raised the car 1/4 in the front. I think I am going to raise it up another 1/2 all around to make it nicer to drive with how low the exhaust is.
The Following 3 Users Say Thank You to DustinS For This Useful Post:
Cockatoo (01-02-2019), jflogerzi (12-16-2018), Zer0 (09-28-2018)
Old 09-25-2018, 06:54 PM   #720
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Always loved your headlights lol now they're even cooler.
Great build.
Sent from my SM-G900V using Tapatalk
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
The Following User Says Thank You to Phantobe For This Useful Post:
DustinS (09-26-2018)
Old 10-18-2018, 02:08 PM   #721
DustinS
DustinS's Avatar
Old 12-06-2018, 06:05 PM   #722
Rival073
IG: @c1_zn6
Rival073's Avatar
Drives: '13 Ultramarine FRS
I have a friend thats always pressuring me to swap an LS into my 86.
Your build thread has me looking at some motors now haha.
Anyways, this turned out great so far man. sounds and looks awesome!
Rival073 is offline   Reply With Quote
The Following User Says Thank You to Rival073 For This Useful Post:
DustinS (12-10-2018)
Old 12-06-2018, 06:25 PM   #723
Lantanafrs2
Drives: 2013 frs red
Your car is beautiful
Lantanafrs2 is offline   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Old 12-10-2018, 11:18 AM   #724
DustinS
DustinS's Avatar
AWD Swap/parts are starting to be acquired. Going to be a long journey, I don't plan on starting it till possibly next winter if I can get my garage cleaned up and organized enough.
Old 12-16-2018, 09:56 AM   #725
jflogerzi
jflogerzi's Avatar
It just looks mean and sick from those pictures. Great job
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
DustinS (12-17-2018)
Old 12-18-2018, 07:24 PM   #726
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
Absolutely in love with the build and the progress! Great job on the engine swap!
eastendraceshop is offline   Reply With Quote
The Following User Says Thank You to eastendraceshop For This Useful Post:
DustinS (12-20-2018)
Old 12-31-2018, 11:00 AM   #727
DustinS
DustinS's Avatar
Not much of an update, but vibrations in the car have been getting worst. I have one starting at 45mph now, and the one at 2500 RPM is getting really bad. Still waiting for some good enough weather to get room made in the garage to get the engine/transmission out. Plan is to replace the oil pump, radiator, and possibly the clutch kit. If it looks alright, I'll have the current one balanced. Have the transmission gone through and checked to make sure the vibration isn't coming from the trans, as well as try and figure out the leak.
Wife bought me a 3d Printer for Christmas so I have been playing with that. Designed some 1 7/8" mockup parts to design my own header. Need to print a crap ton of them so I have enough to mock up the headers haha. Hopefully finish those up before spring time.
Had to change the design from what the rendering shows to what the blue parts are. Made the locating marks larger and easier to see. I also made the snap system a little easier to remove as I broke the original two trying to take them apart. Have those 4, printing another 8 currently. Should be done by the time I get off work.
I plan on making some fiberglass molds to make a better intake box and some covers for the grill. In the future I want to see if I can design some flares and print it in pieces to use as a mold.
Got the renderings of a new set of LS3 ITBs my old boss is making as well. Not sure it will fit under the hood, but we will just have to see.
The Following 2 Users Say Thank You to DustinS For This Useful Post:
eastendraceshop (01-30-2019), Zer0 (01-01-2019)
Old 01-07-2019, 11:37 AM   #728
DustinS
DustinS's Avatar
New Shifter design. Currently Printing a test part to make sure my measurements are correct.
The reason I'm always broke - Dustin's Supercharged 86 Dustin Member's Car Journals 211 11-08-2015 10:57 AM
Help! New Car Engine Blew Up. What are my rights? Obsidiank Scion FR-S / Toyota 86 GT86 General Forum 53 12-11-2014 11:43 AM
Midwest Modified - Auto Photography by Dustin Faulkner (aka Fancy) Kuzuri Great Lakes 20 02-16-2014 05:23 PM
Engine Warm-up Time Chad86 Scion FR-S / Toyota 86 GT86 General Forum 44 01-10-2014 12:03 AM
So my engine blew up.... alliedcam1 Engine, Exhaust, Transmission 57 12-28-2013 02:50 PM
