Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
02-10-2015, 02:36 PM | #1 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
Keep throwing P0463 codes on low gas
So last week I threw a P0463 code (Fuel Level Sensor Circuit High Input) a little after my low gas light turned on. I didn't think much of it as I read on forums it doesn't seem like a big deal. I filled gas and cleared the code and everything was fine. Today, I threw the code again, ALSO a little after my low gas light turned on. Does anyone know what is happening? Is there a problem with the sensor, electrical system or ECU?
Also I am OFT tuned with an aftermarket battery but probably unrelated. Possibly bad gas? Loose cap? It's strange since my fuel readings are fine.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
02-10-2015, 04:14 PM | #2 |
Addicted
Just cleared the code (still low on gas). It hasn't turned on yet. THe intermittent-ness of this is pretty annoying.
02-10-2015, 05:17 PM | #3 |
Drives: 2013 Asphalt Fr-S
At risk of making this over complicated, the OFT could actually assist in this, though the tune itself is possibly unrelated. If are looking at or logging, please let me know what your RPM, Throttle %, FLKC, FBKC, IAM, STFT and LTFT are.
This will tell us if you are having knock, your fuel trims for short term and long term, What throttle percentage, and RPM you're at. On the other had, usually if you were knocking bad enough, you'd be having other CEL, so it could be the sensor itself.
02-10-2015, 05:58 PM | #4 | |
Addicted
02-10-2015, 06:06 PM | #5 | |
I don't know this is causing the issue you're having either. This would just help ensure your engine it's damaging itself. It could honestly be a bad sensor. I did research and found no other people reporting the issue though.
02-10-2015, 08:20 PM | #6 | |
Drives: 2013 subaru brz
09-16-2015, 02:45 PM | #7 |
Drives: 2013 BRZ, 2004 WRX
Did you ever find the cause of this?
I'm having this exact same issue, although I have a stock tune and an almost entirely stock 2013 BRZ Limited auto (save for a K&N drop in filter). The car has never been to the dealer for any reason (no recalls, etc). I had the chirping issue for 3-20k miles or so. Currently at 33k miles. My car has thrown this code twice. On both occasions, the sequence of events has been as follows: 1. Low fuel light comes on, as expected, during normal driving. Fuel gauge seems steady and accurate. I legitimately need gas. 2. I'll get to my original destination, thinking that I'll get gas afterwords. I'll park the car for over an hour. 3. Car seems to struggle a tiny bit to start, almost like the battery not fully charged. 4. Shortly or immediately after starting the car, the CEL will come on. I'm not sure when it comes on because I might just not be noticing it immediately, due to the other orange lights already on my dashboard (low fuel, etc). Car runs fine, otherwise. 5. I'll stop for fuel, turn the car off, fill the tank, check and clear the CEL. P0463. 6. Again, the car seems to struggle a tiny bit to start, almost like the battery not fully charged. 7. Many driving cycles follow without a Low Fuel light, without any noticeable trouble starting, without any unexpected fuel behavior from the fuel gauge, and without a CEL. Perhaps coincidentally, this has happened on two consecutive tanks of gas from different gas station brands in different parts of town. Last edited by dolph; 09-16-2015 at 03:00 PM. |
09-20-2015, 04:39 PM | #8 | |
Drives: 2013 Raven Fr-s
09-21-2015, 02:29 PM | #9 |
Drives: Raven Manual FRS
Quit letting your gas light come on. Problem solved.
The Following 2 Users Say Thank You to Freetime For This Useful Post: | guybo (03-01-2017), SlammedSilly (09-22-2015) |
09-21-2015, 03:04 PM | #10 |
Drives: 15 BRZ LTD, 05 FXT
It doesn't cost you much more to keep the tank full, than it does empty...
The Following User Says Thank You to JazzleSAURUS For This Useful Post: | SlammedSilly (09-22-2015) |
09-21-2015, 05:31 PM | #11 | |
Drives: '13 FRS - STX
That's almost like saying "My car won't turn left" and your answer being "Well just make 3 rights". It doesn't sound like these guys are driving deep into empty territory (I have with no issues, I've filled over 12 gallons twice now and over 11.5 ~20x (13.2 gallon tank) without issue), considering check engine lights can put the car in limp mode (likely to happen with a fueling code) this can cause legitimate problems. |
The Following 2 Users Say Thank You to strat61caster For This Useful Post: | FRSBRZGT86FAN (04-26-2016), Harvie1031 (04-26-2016) |
09-22-2015, 01:48 AM | #12 |
Addicted
Just a short update. I have not thrown the code since I first posted back in Feb (I think). The culprit IMO was using Torco Accelerator (concentrated race fuel for octane boosting). Since I stopped using that I have not thrown codes.
Also, back when I was throwing codes there was no effect on the car as far as I could tell. Besides temporarily losing cruise control lol.
10-07-2015, 08:49 AM | #13 |
Drives: 2013 Subaru BRZ
This issue has started to occur on my stock 13 BRZ, for the past 3 tanks. I have since been trying to keep the fuel level higher. but still would like to find a solution. Anybody?
04-19-2016, 06:41 PM | #14 |
Drives: 14 BRZ Limited
I also had this issue about 6 months ago but it seemed to clear up on its own so I let it go. Other than a single fill up that I put 11.5 gallons in when the tank showed just over 1/4 before I haven't had any issues until yesterday. The check engine light is back on and the gauge seems to be in a different spot every time I start the car. I have an appointment with the local Subaru dealer on Monday and I will post what they find.
The Following User Says Thank You to angadam For This Useful Post: | zc06_kisstherain (04-25-2016) |
Similar Threads | ||||
p0463,P013f and c1237 codes? | feldy | Engine, Exhaust, Transmission | 28 | 12-14-2015 11:02 PM |
Unichip throwing p0102 code ?? | jdubz13frs | Software Tuning | 3 | 07-10-2014 03:27 PM |
OBDII Bluetooth and Torque app, throwing CEL | BRZPDX | Issues | Warranty | Recalls / TSB | 11 | 03-03-2014 02:03 PM |
Throwing the gauntlet down. Gran Turismo or Forza? | Sully | Off-Topic Lounge [WARNING: NO POLITICS] | 153 | 01-03-2014 01:27 PM |
Throwing around an idea | DrDuquette | BRZ First-Gen (2012+) -- General Topics | 18 | 08-04-2012 08:27 AM |
