Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
10-05-2021, 03:39 PM | #1 |
Drives: 2013 Scion FRS 10 Series
Overfenders didn't come with hardware?
Hello all,
Basically, I just bought an Ebay overfender kit (I know, boo) and it didn't come with rivets or any hardware. I can't seem to find an answer to this question so I figured this would be a good place to ask. What kind of hardware do I need to mount these overfenders? Will any rivets work? Any other info I should know before beginning? |
10-06-2021, 03:35 AM | #2 |
LMGTFY
Drives: 13 FRS, 91 Miata
10-06-2021, 07:09 AM | #3 |
Be Kind
Drives: 2020 86
Rivnuts (Threaded Rivet Nut) and stainless bolts seem to be what everyone does so it's removable and easier to work with.
This is one of those: if you have to ask, I hope your car is salvaged or a project car. Cutting fenders, seam sealing, creating new fender liners.... none of this is for the faint of heart. Good luck!
10-06-2021, 07:32 AM | #4 |
Drives: 17 Asphalt 86
Not only that, you should really know what you are doing when cutting up fenders. You need to cut and weld them up, and seal them properly so it doesn't rust.
The Following User Says Thank You to RToyo86 For This Useful Post: | Wally86 (10-06-2021) |
10-06-2021, 07:38 AM | #5 |
Be Kind
Drives: 2020 86
Without context you never know. Maybe they TIG weld on the regular and this'll be an easy project for them but if they're asking about rivets, I have doubts.
10-07-2021, 09:53 AM | #6 | |
I've read there are alternative rust prevention methods to welding? Are they not as good as welding? |
10-07-2021, 10:22 AM | #7 | |
Be Kind
Drives: 2020 86
Since you're doing something crazy and looking for views on YT, why not mount the rivnuts to the overfender and drill holes in the fender and bolt it in from behind? Then you can bondo over the fiberglass spots for mounting and have a super clean look. Might be more of a pain for removal but it'd look slick. My .02
10-07-2021, 12:17 PM | #8 |
Drives: 2014 Subaru BRZ
The guy who did my car suggested we use regular rivets over rivnuts because they tend to shake loose, you have to go around a re-tighten them periodically
for a home garage job it'd just get a rivet gun and forget about all those rivnuts Its honesty easy to drill out the rivets if you ever have to remove the kit |
10-07-2021, 12:23 PM | #9 | |
1st86 Driver!
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
10-07-2021, 01:49 PM | #10 |
The Following User Says Thank You to VIP BRZ For This Useful Post: | Dadhawk (10-07-2021) |
10-07-2021, 03:20 PM | #11 | |
TRACKBREAD
Has your guy never heard of thread locker? |
10-07-2021, 03:39 PM | #12 |
1st86 Driver!
Yea, definitely easy to drill out. Done it plenty of times. Solid rivets are a little more difficult but not too bad.
10-07-2021, 04:28 PM | #13 |
What's the point of having them being removable hardware if your just gonna lock them up?
Its probably easier to drill out rivet then it is to wedge loose 75 thread locked rivnuts also like a said.. rivnuts cost like a $1 a piece + all that thread lock rivets are like 100 for $10 |
10-07-2021, 05:04 PM | #14 | |
TRACKBREAD
Thread locker prevents the screws from backing out, but they still come out easily with a screwdriver. Every single important bolt on your car is thread locked. You just apply a drop of blue loctite to the threads and you’re good. Rivnuts are cheap, literally $0.28 a piece: https://www.mcmaster.com/95105A127 If I was cutting my fenders up I would sure want to be able to get back in there to check on rust. |
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post: | NoHaveMSG (10-08-2021), x808drifter (10-09-2021) |
Tags |
overfenders, widebody |
Similar Threads | ||||
Front widebody/overfenders only | DanFRSh*tbox | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 08-23-2019 07:45 PM |
Molding rocket bunny overfenders | Raves614 | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 12-04-2015 11:28 PM |
WTB: Rocket Bunny Overfenders | Brndn704 | Want-To-Buy Requests | 1 | 09-17-2015 01:04 PM |
Chargespeed overfenders / widebody | Khorne | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 10-15-2014 01:29 PM |
Origin Labo Overfenders | ZC6BRZ | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 01-26-2013 09:37 PM |
