Old 03-20-2015, 09:06 PM   #6175
Chrisbrz14
Chrisbrz14's Avatar
Drives: Subaru Brz
Originally Posted by Chad86 View Post
How many owners installed the kit themselves? I am not a mechanic by trade but am good with my hands. I don't like the idea of having to pay for something that seems so bolt on and the satisfaction of doing it myself would be great! How difficult is the install really?
I found it pretty easy, I am no mechanic but i am good with my hands. The directions worked for me. You will need someone to help set it. Also make sure you route all the hoses and connectors to places so you can get them after you set the supercharger. I forgot the fuel line and had to take it back off.
Chrisbrz14 is offline   Reply With Quote
Old 03-20-2015, 10:17 PM   #6176
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Lightbulb
Originally Posted by R3NIK View Post
@Chad86
Here's some quick install tips.
Remove all the under panels. You WILL drop bolts and this will save you countless time.
The coolant does not need to be drained, if you clamp the two coolant lines to the throttle body.
Make sure you have grease, I used white lithium grease to get all the hoses to slide on. You do not need to replace the back plastic hose couplers with brass, just be careful to not use too much force on them. It can be tricky to find the brass fittings with the proper pitch, and this blower is made in Australia and standard American/Imperial bolts won't work.
Use a torque wrench! Follow all torque guidelines. You'll have to convert Nm to Ft-Lb, I did this with my phone. The bolts on the FRS are soft, everywhere. I sheered one intake manifold bolt, and two underpanel bolts. And this was w/o much force.
Get an extra hand when placing the new intake manifold / supercharger. You'll want an extra set of hands to pull back cables and hoses so everything fits flush. And you'll do this a few times, as you check clearance against the alternator when filing it.
Make sure the fuel line is placed underneath the supercharger before bolting it down. You will not be able to fish it through after the fact. Just ask me how I know...
Fuel injector clips can be tricky, take your time and don't break them. They slide right off when you pinch the clip, you should not be using any force on them.
I'll add more notes as I think of them.
And don't forget, I linked the latest install guide a few posts above.
This is starting to sound a bit tricky. I will make my final decision whether I install myself or go to a shop after I have a look at the kit and all the parts when it arrives Monday.
Chad86 is offline   Reply With Quote
Old 03-22-2015, 08:05 AM   #6177
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
I noticed sometimes on a hot day or when I've had a few hard pulls the area around the oil fill screw is moist as if oil was misting/sprayed/boiled out or something. Anyone have this happen to this?
I'm running non-IC, so I think it's safe to assume the oil is just getting too hot? Maybe a different oil or getting a new gasket for the oil fill screw will fix it (other than getting an IC)? I'm using the recommended redline.
EDIT: I'm talking about the supercharger oil fill plug
Books is offline   Reply With Quote
Old 03-22-2015, 11:55 AM   #6178
nmastereal
Are you running a oil cooler?
nmastereal is offline   Reply With Quote
Old 03-22-2015, 12:38 PM   #6179
SpeedWi
SpeedWi's Avatar
Drives: 2014 BRZ (SOLD)
@DarrenDriven add to the list please.
SN S5-210-261213-0005
Supercharged 2014 DGM Limited
SpeedWi is offline   Reply With Quote
Old 03-22-2015, 02:40 PM   #6180
Books
Books's Avatar
Yes, I'm running a mishimoto oil cooler.
Old 03-22-2015, 06:30 PM   #6181
asphaltkyle
asphaltkyle's Avatar
Drives: 2013 BRZ, 2011 M3 Competition
Just installed my supercharger on Thursday. Stage 2 with the intercooler. I am using Delicious Tuning for my tune, and I have flashed the ECU and followed the instructions word for word. Initially, the car cranks and idles at 1500, somewhat fluctuating from 1400-1600 from the direct injectors. When the port injectors kick in, the engine dies and the car turns off. When I try to crank it again, the car immediately dies after a second from cranking. I have already troubleshooted it with Zach from Delicious and made sure the injectors were in firmly with the o-rings from the stock manifold, but I still can't get my car to be driveable. Anyone have this problem?
asphaltkyle is offline   Reply With Quote
Old 03-22-2015, 06:37 PM   #6182
mikalem
mikalem's Avatar
Drives: 2013 WRB BRZ Limited
Perhaps a short due to the coolant pump? For grins, will the car run if you unplug the injector harness pass-through for the coolant pump and wire it up like stock? (Don't go running it down the street like that, just see if this resolves the start and idle issue to isolate the problem)
mikalem is offline   Reply With Quote
Old 03-23-2015, 04:03 PM   #6183
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Originally Posted by dpgfunk View Post
My car is having some hesitation during cold start ups...almost as if it's struggling to get started. Anyone else encounter this issue after installing their kits?
Are you running E85?
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 03-23-2015, 04:06 PM   #6184
dpgfunk
Drives: 2012 E92 M3, 2013 BRZ
91 oct
dpgfunk is offline   Reply With Quote
Old 03-23-2015, 09:42 PM   #6185
brianhj
Drives: 2017 Camaro 1SS
Mine did that every now and then on 93
brianhj is offline   Reply With Quote
Old 03-24-2015, 06:01 PM   #6186
R3NIK
R3NIK's Avatar
Drives: 2013 FR-S/C
@moto-mike and others:
I really don't care about numbers, I like noticeable results. Those I definitely got with my current setup and I love it. Sadly, everyone outside of the FRS/BRZ scene is obsessed with wanting to know peak hp/tq on my setup. What results are you getting with the 210 non-IC, 70mm, and E85? Specifically, stock vs your tune? As you may recall, I only have a catback so other completely stock exhaust systems would have very similar results.
My answer for now has been "let's go for a ride and I'll show you"
R3NIK is offline   Reply With Quote
The Following 4 Users Say Thank You to R3NIK For This Useful Post:
Chad86 (03-28-2015), CK_Bladesmith (03-24-2015), DeliciousTuning (03-24-2015), Dream20b (03-25-2015)
Old 03-25-2015, 01:55 PM   #6187
SpeedWi
SpeedWi's Avatar
What catch can are you folks running? I did a search, but you know how that goes. I'm looking at some and would like to get an ideal on what works with this SC. Also Dual cans really necessary or is PVC side good enough?
Old 03-25-2015, 01:56 PM   #6188
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Innovate (Sprintex) Supercharger Owners Topic
I have dual radium catch cans on my innovate setup and both cans catch oil/water/fuel. I highly recommend them
Edit: here's a pic of both cans. Left is pcv, right is breather side.
Attachment 105478
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
