Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
01-30-2016, 09:36 PM | #15 |
Drives:
UPDATE: Got a new steering assembly, steering feels more consistent between turning left and right now. The alignment shop this time double checked and verified that the steering wheel is centered as least on the machine. Car is still drifting to the right. If the steering wheel is tilted slightly to the left it no longer drifts right as quickly or just does not drift altogether. I'm thinking this may be the coilover's problem as the previous set of Buddy Club Racing Spec coilovers did not encounter this issue ever.
01-30-2016, 09:44 PM | #16 | |
Drives: 2013 FRS
01-30-2016, 09:50 PM | #17 | |
Drives:
Neither Tein nor fteightysix got back to my emails. |
01-30-2016, 10:32 PM | #18 | |
Drives: 2013 FRS
01-31-2016, 09:34 AM | #19 |
Drives: 13' BRZ
swap wheel/tires side to side? see if it follows?
02-01-2016, 04:40 PM | #20 |
1337
Drives: 2013 BRZ WRB S/C
Sounds like a dumb question but have you checked your tire pressures?
02-01-2016, 07:26 PM | #21 | |
Drives:
Done. Still pulling to the right.
I'm currently waiting on my insurance company to get back to me to see if they can approve of it being checked by one of those laser frame machines. Meantime fteightysix and Tein both got back to me, and nobody thinks it's the actual coilovers having the problems. The lower control arm was not replaced post-accident, so that could be another problem region. |
02-01-2016, 07:42 PM | #22 | |
02-01-2016, 07:43 PM | #23 |
Drives:
02-01-2016, 07:44 PM | #24 |
Then lca is next on the list
02-01-2016, 09:50 PM | #25 | |
Drives: 2005 Toyota Camry
-alex |
02-01-2016, 09:52 PM | #26 |
Drives:
Great point. The car was bone stock in terms of suspension and I never received the alignment printout after the accident. I suspect that the alignment shop at the time may have did a bad alignment just to balance out the pulling to one side.
02-13-2016, 06:47 PM | #27 |
Drives:
Update 2:
Got new front passenger lower control arms and bushings and had the car realigned. Alignment specs will be attached below. The car is STILL pulling/drifting to the right. I pretty much narrowed down the following options or steps to continue figuring this out: -Could be coilovers, but Tein is of absolutely no help so far and refuse to acknowledge it may be a faulty part. -The bolt on the subframe mount connecting to the sway bars was hard to put back in, and it could be the subframe slightly tweaked since the car had damage primarily on the wheel, front of the fender, and the bumper from the side to where the crash beam starts since I believe the subframe sits right behind that intersection of fender and bumper? The insurance company refused to pay for a laser frame machine setup for diagnosis of frame damage due to the damage being impossible to have subframe damage, or so they say. -More steering assembly issues, or some kind of steering sensor/positioning needs to be reset, as the steering wheel tilted slightly to the left will cause the car to drive mostly straight. I'm getting tired of paying out of pockets for alignments constantly, and a lifetime alignment at Firestone isn't going to solve the problem since I do have to get it to other shops to get a second opinion or to verify it is not a machine calibration issue at these alignment shops. If anyone has any other good ideas please feel free to contribute. Alignment specs: |
02-15-2016, 01:59 AM | #28 |
The difference in the front end camber/caster is unusual, I think that may be a symptom of your underlying issue. Most alignment sheets I've seen (mine included) are dead even left/right across the fronts unless an adjustable element is added and out of whack. Not sure if you already got that lifetime alignment deal but swapping back to OE struts and top mounts in the front would imo eliminate the front (and if you feel like doing the rears too) Teins as a potential cause. Then you'd be looking at the knuckle/hub, lower control arm, steering rack and rods, and subframe.
Again, good luck. |
Similar Threads | ||||
Sway Bar Creaking | smg1138 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 11-16-2015 01:28 PM |
Creaking during turning after coilovers? | Rifle | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 11-10-2015 12:51 PM |
Bc racing v1 coilovers (track spec edition) knocking sounds | Tsumari | Brakes, Suspension, Chassis | 3 | 08-06-2014 07:44 PM |
Seats creaking | Wes | Issues | Warranty | Recalls / TSB | 28 | 06-15-2014 06:19 PM |
BEST of Start Up sounds!! More than 70 Exhaust Sounds! | JPxM0Dz | Other Vehicles & General Automotive Discussions | 5 | 01-08-2014 02:24 PM |
