12-11-2012, 05:08 PM | #2339 |
Drives: 6MT Whiteout
That was quick. Car already returned with new ECU.
The Following User Says Thank You to arucard77 For This Useful Post: | eurospeed (12-17-2012) |
12-11-2012, 08:09 PM | #2340 |
Drives: 2013 WRB BRZ
BRZ, 4715 miles on the clock, 6029xx.
Just started the car and waited for it to warm up and the idle stuck at 1k rpm and then began rough idle - blipped throttle and it went away. I just left work less than half a mile - idling at a U turn it popped the CEL. We will see what they do. Update: They are going to replace the ECU so a few days wait for the replacement ECU and testing. Update 2: ECU replaced and picked up car a week after dropping it off. Running smooth so far. Last edited by Squishy; 12-18-2012 at 08:53 PM. |
The Following User Says Thank You to Squishy For This Useful Post: | eurospeed (12-17-2012) |
12-11-2012, 08:40 PM | #2341 |
Drives: 2013 FR-S Hot Lava
Been watching car closely after the repair. Fast forward 3600 miles.
The strange idle behavior I've been noticing is related to the AC compressor. When the AC is off, my car idles steadily at around 650 when fully warmed up. Rock solid. Very happy. What I would like Toyota/Subaru to do is to provide an ECU update to allow me to decouple the fucking AC compression from the windshield defroster function.
Live to drive another day
12-14-2012, 11:05 AM | #2342 |
Drives: FRS 6MT
E_br4ke, FRS, ~2860mi when it happened, will reply back with VIN, will drop it off this weekend, TX, USA
both CEL and Limited Slip lights are on. Turned off and turned back on, still on. Will be reading the last few pages of this thread but hopefully they have found root cause and it should be a quick fix. I dont really want to part with my baby. |
The Following User Says Thank You to E_br4ke For This Useful Post: | eurospeed (12-17-2012) |
12-15-2012, 01:36 AM | #2343 | |
Drives: 2013 Toyota 86 Silver
12-15-2012, 02:57 AM | #2344 |
Because Racecar
Drives: 2013 Asphalt FRS
thought id contribute to this thread since im frustrated with the CEL issues..
asphalt FR-S purchased in October 2012 have since put on 6,000 miles had first CEL around 5,800 miles threw the p0011 code for the cam shaft positioning/timing the first time I had it cleared and decided to wait and see if I would throw the code again. 120 miles later I had a CEL for the same code p0011 drove to the local dealer where I purchased the car. they ended up keeping it for a week and a half and could not recreate the code thus leaving me with a car that had a CEL issue with no one wiling to try to fix something and was given back to me without anything being done to it other than the tech driving the shit out of it. Had the vehicle back for all of 12hrs and threw the p0011 code again don't understand how the dealer couldn't recreate the issue but I managed it no problem. cleared the code at a buddies shop to take the car for a run and ended up throwing the code within 10 minutes of clearing it. Took it back to the dealer an told them I want something done its no longer my problem fucking fix, that its total bullshit I was told everything was fine and threw the code again without anything being worked on or fixed. I was also informed the car had thrown codes before the dealer took possession of the car and had it delivered to me. thus ticking me off further. the most recent up date consists of the dealer having the car for the last 2 1/2 weeks and parts due for delivery this coming Tuesday 12/18/2012 the parts that I am waiting on are new right cam shaft gears even though everything is mechanically functioning and leading me to believe that it is an electronic issue and am need of a reflash/new ecu not mechanical parts. im hoping for the sake of the service department that the issue is resolved and that I no longer throw codes after the new camshaft gear is put in. im located in San Antonio/Boerne Texas have 6,xxx miles on the vehicle and will supply the vin when I get the car back as well as an update also it as the auto/triptronic transmission in it. I drive the vehicle like it was designed to be driven and followed the break in procedures to the t. Toyota of Boerne is handling the work on the car. I drive the shit out of this car.. as much of a pain in the ass it is the positive is that im not paying a damn dime for any of this. hopefully will have an update for yall soon if I can be added to the list id appreciate it sorry for the long post just hoping to further inform yall as well as anyone else in my position |
12-15-2012, 07:10 AM | #2345 | |
@tuckdaddy when my dash lit up, i hooked it up with dash command app on iphone. Got error code p0017 concerning crank sensor and it gave the option to delete the code. I decided to not to delete the code to prevent the dealer from saying that all is well and nothing is wrong with the car.
2013 Toyota 86 (Sold it and regretting)
12-15-2012, 09:34 AM | #2346 | |
Drives: BRZ DGM Limited
Did you have any idle issues with the car? How was it running when the code came on?? So are you saying the first time you took it in the dealer just reset to code and sent you on your way? Crazy. And you are right, no reason to pay for the repair and you should expect to have a new car that is CEL free..nothing less..or call Toyota for a refund!!!! |
12-15-2012, 10:48 AM | #2347 | |
Drives: 2013 FR-S Argento
Hope it's not a sign of problems to come. I'm kind of dreading my first oil change. |
12-15-2012, 12:14 PM | #2348 | |
Because Racecar
rant over |
12-15-2012, 12:17 PM | #2349 | |
Because Racecar
12-15-2012, 01:27 PM | #2350 |
yeah it is a good app, I use the kiwi PLX OBDII connecter to wifi. You can then connect to it through the phones wifi.
The Following User Says Thank You to FT86Dubai For This Useful Post: | tuckdaddy (12-15-2012) |
12-15-2012, 05:48 PM | #2351 |
Because Racecar
thanks for the info on that!
also this is my 86th post! |
The Following User Says Thank You to tuckdaddy For This Useful Post: | FT86Dubai (12-16-2012) |
12-16-2012, 12:22 AM | #2352 |
Drives: FR-S, NA8, S13
have had the hunting idle issue for a while now.
have had the car stutter and instantly stall twice. car stuttered today after spirited driving. once it was turned back on the CEL was on with the slip light on as well. ebphoto, FR-S, ~7700mi, FL code p0017 Last edited by ebphoto; 12-16-2012 at 11:34 AM. |
The Following User Says Thank You to ebphoto For This Useful Post: | eurospeed (12-17-2012) |
Similar Threads | ||||
NW Owner List & Event Archive | DarrenDriven | Northwest | 1643 | 08-05-2016 06:48 PM |
Idle issue? | yayforaddison | Issues | Warranty | Recalls / TSB | 892 | 07-14-2016 10:42 AM |
Idle issue | scioneric | CANADA | 23 | 08-24-2012 01:40 AM |
Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 12:00 PM |
An unofficial message from TMCA | Courtz1074 | AUSTRALIA | 25 | 05-17-2012 10:00 AM |
