Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB > Technical Topics > Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Old 03-12-2019, 06:19 PM   #1
rawbeanz
Drives: 2015 Subaru BRZ
Differences between Rear Lower Control Arms (SPC vs SPL, etc.)
Hello very sorry if this has been asked before. Not sure why we can't search for words with 3 letters in the search considering half the aftermarket brands are only 3 letters abbreviated.
Anyways, I'm considering buying a set of coilovers and I'm assuming with a bit of a drop, I'll need new LCAs to adjust camber in the rear.
Is there a difference between the LCAs out there? Will the SPL LCA work just as well as the SPL LCA?
Thank you!
rawbeanz is offline   Reply With Quote
Old 03-12-2019, 06:31 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Drives: 13' FR-S, 07' MDX, 06' Ridgeline,
Have you looked at pics of each brand LCA? They are both functional. One is "aftermarket" looking (nice!) and the other is OEM (stock) looking.
IIRC, the SPL has more adjustment then the SPC.
Yes, LCA are needed to dial in rear camber after lowering. I would suggest a bump steer kit too. like this... http://www.ft86club.com/forums/showthread.php?t=130715
If the coils you are getting have tophats with camber adjustment in the front; cool. If not, you will want camber bolts at a minimum, possibly camber plates.
Pro Tip: Use google to search. Type in what you are looking for and then add "ft86club". It makes finding things easier.
I LIKE TIRES!
Old 03-12-2019, 06:49 PM   #3
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Thank you!
What is your intended goal? On the budget, SPC. Legit setup with quite a bit of adjustable range, SPL. We sell both and suggest accordingly based on application. Heavy users slip the SPC out in this region, but the rest of the nation seem to have a different experience.
CounterSpace Garage is offline   Reply With Quote
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
Leonardo (03-12-2019)
Old 03-12-2019, 08:27 PM   #4
rawbeanz
I go to maybe 3-8 track days a year, but I'm not sure whether I want to go with a budget single adjustable(Tien flex a, hks hypermax, ohlins r&t) or something in the double adjustable range(jrz or act) for the coils.
I honestly don't really care about looks but Im just wondering if the SPLs are really necessary with the additional adjustability.
Old 03-12-2019, 08:51 PM   #5
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
How sticky of a tire are you planning to run?
What track/s?
Old 03-12-2019, 08:53 PM   #6
rawbeanz
I run with 86DC so I'm using GT Radal SX-2 and tracks would be Thunder Hill, Button Willow, Laguna and Sonoma.
Old 03-12-2019, 09:14 PM   #7
ZDan
ZDan's Avatar
Drives: '17 BRZ PP
Probably not...
LCAs are hugely overprescribed IMO.
I would lower the car first and see what you get, bearing in mind that -2 degrees and even more is perfectly streetable camber.
FWIW I'm 1.25" lowered at -2.5 degrees rear camber and zero rear toe with factory arms. No problem...
wparsons (03-13-2019)
Old 03-12-2019, 10:08 PM   #8
strat61caster
Thread Killer
strat61caster's Avatar
Drives: '13 FRS
Originally Posted by ZDan View Post
Probably not...
Fine for street use, not fine for OP headed to the track, you got lucky, most cars don't have even camber in the rear,reason enough to pay the $250 for alignment parts even on stock coilovers.
ineedyourdiddly
Old 03-13-2019, 04:04 AM   #9
CounterSpace Garage
Our CSG FLA setup + recommended settings gets you pretty close to our alignment specifications. We generally prefer SPL for its reliability and consistency, but it is not absolutely required. It certainly helps give you the desired camber. SPC is a lower cost option that many have purchased from us as well.
Old 03-13-2019, 11:05 AM   #10
ZDan
ZDan's Avatar
Drives: '17 BRZ PP
Stock LCAs are *totally* fine for track use, I did 13 track days on them last year, won my time-trialing class (over other 86s and a slew of Hoosiered NA and NB Miatae) and overall championship with COMSCC
I doubt many FT86s will have more than ~0.5 degrees rear camber difference left vs. right, which IMO is not that big a deal. Honestly I wouldn't bother with aftermarket LCAs if I had something like -2.2 on one side and -2.7 on the other, but as it turns out I'm at -2.4/-2.6, which is of course totally fine.
Old 03-13-2019, 03:15 PM   #11
Racecomp Engineering
I would recommend against using LCAs with exposed spherical bearings for anyone that drives on roads that are salted. I use Cusco LCAs on my own personal car because of the rubber booty that protects a high quality bearing. Exposed bearings would not last very long on a street driven car in this area and I'd have to replace the ends more than I'd like.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
wparsons (03-26-2019)
Old 03-13-2019, 03:24 PM   #12
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I do 25+ track days a year. I have -2.5 degrees of camber with the SPC LCAs. I paint marked them when I installed them and they haven't budged. Don't waste ur money on the fancy ones.
- Spec13 Motorsports #813 2013 Scion FRS Build Thread
- MFactory/YCW Suspension/SWIFT Springs Coilover thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
rawbeanz (03-13-2019)
Old 03-13-2019, 03:28 PM   #13
rawbeanz
Sweet, thanks! I'm probably just going to use the SPC ones, I got a killer deal on a set.
The Following User Says Thank You to rawbeanz For This Useful Post:
Takumi788 (03-13-2019)
Old 03-26-2019, 03:53 AM   #14
Turbo
Drives: FR-S Turbo
I'm wondering if CSG and RaceComp can offer any feedback on the Blox Racing rear lower control arms?
They seem VERY beefy and decently made. Probably not as light as an all-aluminum machined arm but also50-60% less $$$.
Turbo is offline   Reply With Quote
Search this Thread:
Advanced Search
Need to buy: stock rear lower control arms/toe arms and intake elbow CoolHandMoss Want-To-Buy Requests 6 07-12-2018 09:44 AM
ISC rear lower control arms DavidBob Brakes, Suspension, Chassis 13 03-30-2017 08:26 PM
FS: ISC rear lower control arms DavidBob NY / NJ / CT / PA 4 03-30-2017 06:55 PM
Megan racing rear lower control arms , toe arms, rear traction arm fcdrifter20 Brakes, Suspension, Chassis 11 01-03-2016 09:11 PM
Copyright ©2000 - 2020, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
