Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
03-27-2023, 03:00 PM | #1 |
Drives: GR86
Six piston caliper / 340mm+ BBK recommendations
Besides the Radi-Cal AP Racing kits (6 piston/355 and 372mm disks), are there any other kits with similar specs for the Gen2 cars? And do they require a BBK for the rear as well?
The Brembo GT Front 2-Piece Drilled Brake Kit 1M1.8047A1 comes with 6 piston calipers and 355mm rotors. Just need to know if I can keep the stock rears. The website where I found them doesn’t specify. Lastly, do any of the 340mm+ kits fit 17x9 wheels? I’d prefer not to have to buy new wheels and tires since I already have a nearly new set of 17x9 6UL wheels, but this is not a show stopper. |
03-27-2023, 04:01 PM | #2 |
Brembo Pista, GT, GTS, GTR kits.
6UL will not clear any of the large kits. You will need 18" or very, very specific 17" wheels. Barrel clearance is a challenge when your BBK is serious. I can get you set up with a complete solution. |
03-27-2023, 04:46 PM | #3 |
The GRMN japanese 345 mm 6 pots brake kit fits under Rays ZE40 7.5x17 rims.
03-27-2023, 11:12 PM | #4 |
Drives: 2022 BRZ
You do not need Uber huge brakes for the car. I read the other thread. I swapped to the Brembo BM4 from CSG and optionally the rear Brembo GT kit. You don’t need the rears but I prefer fixed calipers. Fits my 6UL, though I wouldn’t run those wheels on track. They are my beater street wheels and they are kinda ridiculous thin.
You’ll barely be exercising the BM4 kit. Don’t even bother thinking about ducts. See my build thread for more details. Current street setup |
03-29-2023, 12:43 AM | #5 | |
Drives: GR86
Did you do any track days with your stock brakes? If so, how did it go? I threw some RS4s on and went on track with the stock brakes. Got 2-3 laps before significant fade. Upgraded to Carbotech XP-10 pads and race fluids while keeping all else the same. Got 4ish laps before significant fade. A lot of people seem to do well with just better pads. I definitely did not. I ran the Miata on stock brakes and $80 pads for over 15 track days without issues. I sold the car with more than half the pads still left. I’m not doing anything differently with the 86 in terms of warming up and cooling down. In short, I think I’m just rougher on brakes than most people on track in the 86. The BM4 will probably be sufficient, but not too much. It might be better to go big big and never worry about it again. Don’t know ☹️ What tracks do you run at? |
03-29-2023, 02:09 AM | #6 |
Drives: 2022 BRZ
I didn’t run my car on stock brakes. BM4 before the event. Sadly I won’t get out til May8.
Just Summit and VIR these days. Usually with Trackdaze, Audi club, and maybe some private events. |
03-29-2023, 08:03 AM | #7 |
Drives: 2018 BRZ
03-29-2023, 08:20 AM | #8 |
Drives: GR86
I ran stock calipers/rotors with the XP-10s and ATE Typ 200 at Dominion which is much shorter and slower than Mid-Ohio and Pitt Race and overheated in about 4 laps. Did not have the issue in a Miata with stock brakes, $80 StopTech pads, and ATE Typ 200 fluid at the same track, but I was ~6 secs slower at that track.
03-29-2023, 08:26 AM | #9 |
Drives: Subaru BRZ
I ran 6UL's for years, never had a problem with them. Early generations (1-3?) could crack but never heard of a gen 4 wheel cracking. Gen 4 has lug holes that line up symmetrically with the valve hole centerline.
03-29-2023, 09:23 AM | #10 |
Drives: 2018 BRZ
03-29-2023, 10:28 AM | #11 |
Drives: GR86
Exactly what I understood when I bought the 6ULs. And good experience with them so far.
03-29-2023, 10:29 AM | #12 |
Drives: GR86
03-29-2023, 10:34 AM | #13 |
Drives: 2018 BRZ
Another thing that was not brought here yet - are you running with stability control fully off? Long press on the left button. Otherwise you'd get traction and stability actuation of the brakes that will quickly overheat them.
03-29-2023, 10:58 AM | #14 |
Drives: Crapcan
XP-10's aren't that great. I melted down a set even with BBK. I noticed they put a lot of heat into the rest of the system too.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | DocWalt (03-29-2023) |
Similar Threads | ||||
Sumitomo 4 Piston WRX caliper upgrade | GC GTS Aero Kit | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 12-06-2020 09:55 AM |
OEM Brake Caliper Piston Size | Butterballz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 08-12-2019 10:07 PM |
Caliper paint recommendations? | Brink | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 03-16-2018 12:14 PM |
Front Brake Caliper Piston Rebuild? | smbstyle | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 0 | 10-17-2013 05:18 PM |
BRZ Piston Pictures | AVOturboworld | Engine, Exhaust, Transmission | 12 | 07-06-2012 06:16 PM |
