DIY (Do-It-Yourself) Guides For all DIYs. |
03-28-2020, 08:28 PM | #1 |
Drives: Reddy Whip
Camshaft Position Sensor Or VVT ?
Ok, I've searched the forum, but don't see this particular issue anywhere. My 13 FRS has thrown a po366 code, which my code reader says is "camshaft position sensor B circuit range/ performance bank 1". It would seem to me that the CPS and VVT are working in tandem...replace one and you should also replace the other. Just looking for some clarification....Thanx
06-05-2020, 02:12 PM | #2 | |
Drives: WRB 14 BRZ
06-07-2020, 11:11 AM | #3 |
Drives: 2015 Subaru BRZ Limited DGM
Did you change the oil? I had P0365. Start with an oil change. The cam geometry (for valve timing) works by pumping oil in and out and if it's low or dirty it can get messed up.
Are you still under warranty? If so, and the oil change doesn't fix it, the dealer will replace the sensor. |
06-07-2020, 12:29 PM | #4 | |
Drives: brz
Your problem could be the actuator, sensor, phaser, or out of timing. |
10-28-2020, 08:38 AM | #5 | |
Drives: 2013 Toyota GT86
I'm getting a P0341 and everything around VVT in TechStream software is set to 0 (VVT OCV, Target VVT angles, etc..) https://www.ft86club.com/forums/showthread.php?t=142891 |
Similar Threads | ||||
How to Access Camshaft Position B Sensor? | exittoexist | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 01-26-2020 10:11 AM |
P0021 OBD-II Trouble Code: Camshaft Position A - Timing Over-Advanced | kingaron06 | Engine, Exhaust, Transmission | 4 | 12-11-2018 03:08 AM |
P0021 OBD-II Trouble Code: Camshaft Position A - Timing Over-Advanced | kingaron06 | Issues | Warranty | Recalls / TSB | 2 | 12-11-2018 12:40 AM |
Replacement camshaft sensor plug? | execute1902 | Issues | Warranty | Recalls / TSB | 4 | 06-09-2017 01:52 AM |
New TSB for camshaft sensor | whitefrs | Issues | Warranty | Recalls / TSB | 13 | 03-11-2014 02:54 PM |
