11-11-2021, 04:00 PM | #267 |
Drives: Blue 2015 FR-S
11-11-2021, 05:53 PM | #268 | |
11-11-2021, 06:03 PM | #269 |
TRACKBREAD
Discovery on STi JDM axleback and perhaps others
11-11-2021, 06:26 PM | #270 | |
Drives: 2016 BRZ Series.HyperBlue
I did the floor, sides and some of the fender wells (what I could reach) of the trunk. It was my first time doing it, so I doubt I did it correctly, but hey it worked out. I was reading that 5-6 db drop is what other people have experienced. Sent from my iPhone using Tapatalk
💻 Openflash Tablet v2 Stage 2+ v4 ❄ Jackson Racing Track Engine Oil Cooler Kit 💨 ProSpeed Racing Unequal Length Performance Headers Suit 💨 Invidia N2 70mm Cat Back Exhaust 🦶 Rays Gram Lights 57CR 17x9 +38 5x100 Ceramic White Pearl Wheels 👟 Hankook Ventus RS4 245/40R17 📉 Pedders SportsRyder EziFit Kit 🎢 Pedders SportsRyder Sway Bar Kit
The Following User Says Thank You to calibr8 For This Useful Post: | gpvecchi (11-12-2021) |
11-17-2021, 06:14 PM | #271 |
11-17-2021, 07:27 PM | #272 |
Drives: 2014 Ultramarine FR-S
Odd...stock image of the FRS/BRZ GReddy Evolution GT shows 5 hangers...
The Following User Says Thank You to NLSP For This Useful Post: | DQR (11-18-2021) |
03-02-2022, 01:42 AM | #273 |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
I put all 5 poly exhaust hangers on when I put my CSG MXP on last year. Liked how poly bushings don't rot or move around like rubber mounts was my thinking at the time. I still ended up with 1/2" ring clamps to stop the exhaust tail pipes from shifting too much in the back hangers. Car has stock exhaust system to the CSG MXP cat back. Engine has an HKS supercharger. Exhaust is louder than stock, but not terrible. But I do have more cabin noise than I used to.
Anyone do something similar with just the two rear hangers with polys elsewhere? Just curious, but think that's where I'm starting. Worth a try for 52 dollar order from Nengun for all five. I'll start with just the back two. I'm pretty sure my Torque Solutions motor mounts will still dominate. Especially at parking lot speeds. Wish I could find a softer bushing for those, but that's a crossover thread. Actually, I may not notice at all due to the motor mounts. Feedback too good and fix too cheap not to give a shot. I had the hangers and exhaust on before the SC and motor mounts. Cab was louder, so going to try it out to see if I get anything back. Last edited by jeepmor; 03-02-2022 at 01:56 AM. |
03-02-2022, 02:11 AM | #274 |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
I have the STi axleback with the recommended two rear hanger upgrade and I like it just the way it is. It's quiet to 2600 RPM, low rumble 2800-3400, and over 5000 it sings.
03-05-2022, 09:00 PM | #275 |
I will have 2 available since I moved to a track pipe.
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
04-09-2022, 07:42 PM | #276 |
Just got these picked up from USPS and installed today. Quite a bit quieter in regards to cabin noise versus my poly mounts. Much better at lower RPM and transfers a lot less noise into the cab. My Torque Solution motor mounts still rule the roost there.
I know they have those special pliers to make removal easier, especially poly hangers. These are tough by hand, have to grease them. But I found a tierod pickle fork to work great. These new ones went on by hand easily. Way more movement with these than the poly mounts too. From a solid feel to an inch or so of movement yanking exhaust back and forth. I replaced all five mounts for reference. Didn't try the first two then revisit, just changed them all while I was under there. |
04-11-2022, 03:24 PM | #277 |
The Fail Boat
Drives: CWP S.B.
Had these on for a while, I just drive with my rear chair flattened now. not much drones & My OEM AUDIO + finally isn't rattling the rear deck cuz i flatten my chair....LOL
Thanks my guy |
06-22-2022, 09:19 AM | #278 |
Drives: 86 GT
Coming back to this - I was hearing clunks when going fast over bumps and holes, which I initially thought it was due to my end links. Turns out the overpipe was knocking about on the subframe, to the point of denting the heatshields. Then I realized I started hearing them right after I swapped from the stock hangers to the STI ones...
Will change the front 3 hangers back to the originals and report back.
DIY stuff at Compelica Works
06-22-2022, 12:30 PM | #279 | |
06-22-2022, 01:03 PM | #280 | |
Drives: 86 GT
The engine mounts as well are likely the culprit too, but swapping hangers is a far cheaper option for now. edit: just caught that post that you mentioned the STI ones are stiffer than the stock ones?
Similar Threads | ||||
Ecutek discovery | solidsnake11 | Software Tuning | 7 | 08-25-2020 07:38 AM |
Submitting For EDC Discovery Project | quiksiv | Off-Topic Lounge [WARNING: NO POLITICS] | 16 | 04-26-2016 10:58 AM |
ROM Table Discovery & Definitions | Kodename47 | Software Tuning | 21 | 01-28-2016 03:30 PM |
Oil? Strange discovery under glove compartment | Seungify | Issues | Warranty | Recalls / TSB | 11 | 10-21-2013 06:58 PM |
Front Suspension 'discovery'? | Dimman | BRZ First-Gen (2012+) -- General Topics | 13 | 07-23-2011 08:22 PM |
