Old 03-03-2021, 04:27 PM   #183
wywern209
Drives: 2014 BRZ Limited
Originally Posted by timurrrr View Post
If the only thing in the suspension you're changing is the lowering springs, the wheel will have the same range of motion as with original springs, and will hit the same spots (or will not hit the same spots).
However, changing from original springs to lowering springs can affect how frequently something rubs and how hard something rubs if it does rub with original springs.
So if it doesn't rub with the stock springs then it shouldn't rub with the lowering springs. Good to know. I had heard that lowering can change the min/max offset that the car can handle but your explanation makes a lot more sense.
wywern209 is offline   Reply With Quote
Old 03-03-2021, 04:35 PM   #184
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
The extremes are typically dictated by the geometry of the dampers and bump stops, not springs. When you press the wheel into the car with a few tons of force, or pull it out, the spring doesn't really matter anymore
timurrrr is offline   Reply With Quote
Old 03-15-2021, 01:02 AM   #185
jflogerzi
jflogerzi's Avatar
Anyone have a silver car with the station bronze. I am eyeing these wheels and want to go bold but not sure it's gonna work. Next choice I know will look good is the anthracite color. But it's not bold.
2013 Series 10 FRS #553
Old 03-19-2021, 02:14 PM   #186
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
anyone have pictures of the newer ARC-8 17x9 +35 fitment? All the pics are of the +42 offsets
DuMa is offline   Reply With Quote
Old 03-23-2021, 04:59 PM   #187
APEX Race Parts
FT86Club Official Vendor
APEX Race Parts's Avatar
Drives: Launch-Year Whiteout FR-S
This is the first production run for the new 17x9" ET35, so there aren't any in the wild just yet. The wheels will look exactly the same as the existing 17x9" ET42 ARC-8, only they will sit 7mm closer to the front and rear fenders resulting in a slightly more aggressive fitment with added front strut clearance. Both being 9" wheels, tires will be supported exactly the same.
We look forward to sharing images once available
- Ryan
Phone: 925.245.0773 | experts@apexwheels.com | Website | Instagram | Facebook | Blog
APEX Race Parts is offline   Reply With Quote
The Following 2 Users Say Thank You to APEX Race Parts For This Useful Post:
jflogerzi (03-23-2021), timurrrr (03-24-2021)
Old 03-24-2021, 08:52 PM   #188
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
So they look exactly the same as et42's with a 7mm spacer?
Whispering: Not concave?
The Following User Says Thank You to timurrrr For This Useful Post:
Clark20 (03-25-2021)
Old 03-25-2021, 02:56 PM   #189
APEX Race Parts
That is correct. Unfortunately the ARC-8 cannot have a concave face profile in these 86/BRZ specs and still clear brakes.
Our forged EC-7R has a good amount of concavity to it while still clearing the PP Brembo brakes as well as many other aftermakret BBK's.
- Ryan
Old 03-25-2021, 08:58 PM   #190
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Curious if it was possible to utilize those extra 7 mm of brake clearance and get the face profile slightly concave?
Naively, a rectangle spoke could be turned into a bit of a parallelogram...
But I understand that it's not that simple to design wheels that are still light and strong.
Either way, it's great to see that ARC-8s are now available with two different offsets!
Old 03-25-2021, 09:01 PM   #191
jflogerzi
jflogerzi's Avatar
I switched my offset today to the 35mm offset just to give myself some extra clearance
Old 06-06-2021, 12:30 PM   #192
DarkSunrise
DarkSunrise's Avatar
Still enjoying my OG dual drill pattern Arc-8’s! A friend spun my car at the track and we went sideways through some dirt/rocks but the wheels held up great with just a few deep scratches on one. I just mounted up a new set of tires (Champiro SX2 in 235/40/17) and no problems with the wheel.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
APEX Race Parts (06-08-2021)
Old 06-06-2021, 12:34 PM   #193
jflogerzi
jflogerzi's Avatar
What made you go 235 vs 245? Just curious
Old 06-06-2021, 04:52 PM   #194
DarkSunrise
For the shorter gearing in the canyons (more fun) and also because these SX2’s weigh so much to begin with.
2022 BRZ Build
2013 FR-S Build
jflogerzi (06-06-2021)
Wheel Directory: Volk Racing TE37 17x9.0 +36 03Z33 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 04-11-2018 01:58 AM
Wheel Directory: Volk Racing TE37 17x9.5 +40 B L U E S L A T E Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 06-03-2017 11:29 PM
Wheel Directory: Volk Racing CE28 17x9.0 +38 Dpark27 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 03-14-2015 07:34 PM
Wheel Directory: Volk Racing TE37 17x8.0 +36 / 17x9.0 +36 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 46 05-06-2014 12:19 AM
Wheel Directory: Volk Racing TE37 17x9.5 +40 / 18x10.0 +44 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 04-16-2013 07:28 PM
