Old 11-24-2020, 12:22 AM   #379
strat61caster
strat61caster's Avatar
Originally Posted by Autoenthusiastasm View Post
The tire rack TR motor sports are +45. They are fairly light 19,8 and dirt cheap at $120. I would probably need a spacer (guessing 5mm). Would I have to extend the lug bolts? Not really interested in the hassle, I don’t have an impact wrench
Assuming you're not using 90mm springs the +45s only rub at full lock, no issue if you're aware when parking the car.
I have the trs and rpf1s in +45 and recently did an event with no spacer and no issues.
ineedyourdiddly
Old 11-24-2020, 02:56 PM   #380
PointDSM
PointDSM's Avatar
Drives: 2013 Subaru BRZ
I can confirm as well, that +45 17x9 will work as long as you're not running ton's of camber (-4), and even at that they will only rub at full lock. 10mm spacers with extended studs corrected that issue entirely.
PointDSM is offline   Reply With Quote
Old 11-24-2020, 03:47 PM   #381
strat61caster
You only need 5mm spacers to clear at -4° so you can get away with the shorter extended studs rather then the super long ones.
But having 10mm spacers also available for tuning is worth the extra $50 or whatever.
ineedyourdiddly
Old 11-24-2020, 04:17 PM   #382
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
I have the TR Motorsport wheels. 17x9 +45, 3mm spacers, stock lugs, stock struts, no camber, 245 tire. No rubbing. Its really close!
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 11-24-2020, 04:24 PM   #383
ka-t_240
I got really excited looking at FastTrack today. I thought I saw that spherical were going to be legal for Street Touring. I read it 3 times, until I scrolled up a bit and saw it changed from ST to SP.
ka-t_240 is offline   Reply With Quote
Old 11-24-2020, 04:30 PM   #384
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Originally Posted by Breezio View Post
You might clear with that setup and no spacer, but I don't have a lot of knowledge in the area.
I'm lowered a fair bit on my coilovers, running 17x9 +40mm wheels, 255/40 tires and -3.8 camber in front. I rub when turning the wheel to lock either direction, but otherwise it's good.
im running same setup except im -3.7 and running a 5mm spacer. my 255s dont touch at all
Breadman is offline   Reply With Quote
The Following User Says Thank You to Breadman For This Useful Post:
Breezio (11-24-2020)
Old 11-24-2020, 04:51 PM   #385
Westen86
Purist
Westen86's Avatar
I would need strut mounts or coilovers to get any camber.
Old 11-25-2020, 06:25 PM   #386
Autoenthusiastasm
Drives: 2013 BRZ Limited - stock
What length studs would you recommend. Have coilovers near stock height, camber plates. Hoping for -4 front, -2.5 rear (white line LCA). I figure I won’t need spacers in the rear, 5 mm front. , 17x9 45 with 245/40 tires
Autoenthusiastasm is offline   Reply With Quote
Old 11-25-2020, 09:01 PM   #387
strat61caster
ARP sells OE length, +0.2" and +0.75" length studs. Sounds like the 0.2" longer ones would be a good fit for you. Make sure the lugs aren't bottoming out, might want to consider aftermarket lugs since the ARP's have a little nipple on the end.
https://arp-bolts.com/kits/make.php?...&_EngModelID=*
and if you're swapping wheels every event, you might want to pick up a set for the back anyway so you can replace those if/when they give up
ineedyourdiddly
Old 11-28-2020, 11:15 PM   #388
Autoenthusiastasm
After pricing out studs and spacers and difference in wheels, I decided on buying 6ULs at $199 each . Lighter wheel , no need for further modifications. I appreciate everyone’s input. Thank you
The Following User Says Thank You to Autoenthusiastasm For This Useful Post:
Breezio (11-29-2020)
Old 11-29-2020, 04:58 PM   #389
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
No regrets on the 6UL's.
Breezio is offline   Reply With Quote
The Following User Says Thank You to Breezio For This Useful Post:
Racecomp Engineering (11-30-2020)
Old 12-29-2020, 01:40 PM   #390
sifl
sifl's Avatar
Drives: 2013 Subaru BRZ Premium MT
Are we going to be starting an STX setup and sharing thread for 2021?
I'm hopeful for 2021.
Sent from my SM-G973U using Tapatalk
sifl is offline   Reply With Quote
The Following User Says Thank You to sifl For This Useful Post:
smg1138 (12-30-2020)
SSC setup thread conehead Tracking / Autocross / HPDE / Drifting 26 06-06-2023 02:21 PM
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 12:44 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 110 02-17-2020 11:27 AM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 11:30 AM
Official Roll Cage/Bar Thread **Show off your setup!** slava Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-02-2015 10:05 PM
