Old 09-02-2019, 06:46 PM   #1
Mr_Hann
Mr_Hann's Avatar
Drives: 2015 Steel FR-S
Component speaker installer?
So I'm looking for an installer to run my component speakers - would prefer someone who has worked on this car before (or someone with extensive audio installation experience).
I tried to run the wires myself, but failed miserably...I couldn't get the wires from the door into the top of the dash
Mr_Hann is offline   Reply With Quote
Old 09-02-2019, 08:10 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
which Department of Motor Vehicles are you located at?
Hyper4mance2k (09-24-2019)
Old 09-02-2019, 10:43 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Wait wut?
Why would you.......? Never mind.
Good thing you tapped out. No one runs wires back up to the dash.
As for a car audio install, google any car audio shop. These cars are are nothing special to work on. Any joe blow that has acces to YouTube can install car audio. Well, besides you apparently.
Old 09-03-2019, 12:42 AM   #4
soundman98
soundman98's Avatar
He's installing the passive crossovers in the doors.
No matter, it's impossible to get wire through the oem door boots, you just need to zip tie to it.
Old 09-03-2019, 08:01 PM   #5
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
I've heard really good things about Safe & Sound in Manassas VA
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
Old 09-04-2019, 10:46 AM   #6
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
It's really not hard to get speaker wires through the doors. A couple of things you need to do it: a long (2 ft) zip tie and silicone lubricant spray (or whatever kind you prefer). Spray the lube on the zip tie and fish it through the loom. Attach the wire to the zip tie (i used duck tape), spray it again and pull it through. If you have trouble doing this then just pop the loom off on the door side and the wire should go through easier.
If you prefer taking it to a shpo, I recommend Driven Mobile Electronics in Chantilly. Ask for Chris.
kmbkk is offline   Reply With Quote
Old 09-04-2019, 09:24 PM   #7
soundman98
soundman98's Avatar
what size wire did you fish through?
between the taped loom on both ends, and the overall size, i can tell you definitively that a 12 gauge 2 conductor doesn't fit.
Old 09-04-2019, 09:26 PM   #8
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
I can’t speak for that size wire. I used 16 garage wire. Not sure why you’d need 12 gauge in the door, though, seems like overkill
Old 09-04-2019, 09:34 PM   #9
soundman98
soundman98's Avatar
16 is for wimps. i don't use smaller than 14 in any of my builds.
i ran 8ga for my sub. that was fun to fish through the interior.
anything over 14 is slightly overkill, but after comparing 18 and 14 side-by-side on the same speakers, i could hear a difference in the clarity of the bass, so i do 12 to ensure that i'm not loosing anything.
Old 09-04-2019, 09:42 PM   #10
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Fair enough. I can imagine doing 8 gauge for a sub. It was fun running 0 gauge to the trunk for my system
Component installation tips Mr_Hann Electronics | Audio | NAV | Infotainment 0 08-25-2016 01:08 PM
VIDEO GUIDE - Build your own door speaker mounts using the factory speaker shells. The Sentinel DIY (Do-It-Yourself) Guides 3 01-28-2016 05:39 PM
FRS Component Out help Votlon Electronics | Audio | NAV | Infotainment 0 09-16-2015 10:14 PM
Differential Strength Component slicktop Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 10-13-2013 06:50 AM
Component question Gen Electronics | Audio | NAV | Infotainment 1 11-07-2012 12:55 PM
