Software Tuning Discuss all software tuning topics. |
08-09-2021, 07:42 PM | #1 |
Drives: 2013 FRS
Ecutek MAP value editing
dumb question
we removed a JRSC kit but the car has a 2.5 bar OMNI MAP sensor. I have opened the proper stock bin file. "saved as" separate file... file isn't read only... how do you change/view the values for selected in the application? ok for 2.5 Bar OMNI MAP sensor ECUTEK scaling in BAR Manifold Pressure Sensor multiplier in bar per volt. = 0.500 Manifold pressure sensor offset. Value is measured in bar. = 0.100 MAP Sensor voltage max = 5.0v MAP sensor Voltage min = 0.0v You may also have to disable CEL codes P0068 and maybe P0103 |
08-09-2021, 10:14 PM | #2 |
Drives: 2013 FRS
sorry but if I have to pay to change these values... ecutek sucks...do i have to upgrade the suit? i can pay for a tuner or a stock MAP.. im just trying to get'er done
08-10-2021, 12:59 AM | #3 | |
no gou can edit stock maps with base ecutek kit no problem Just make the map sceen above not take up entire screen ie shrink it to say half screen, then when you tick the map you want to oen you will see it and be avle to edit |
The Following User Says Thank You to steve99 For This Useful Post: | Longuy (08-29-2021) |
08-10-2021, 07:59 AM | #4 |
Drives: 2013 FRS
the problem was.. floating windows hiding behind the main app window instead of a "tree" file system which I was expecting.
An issue between the chair and keyboard. It was a long day yesterday, Race ROM added to file... updated ECU OMNI sensor installed all good.. damn I know enough to be dangerous Last edited by Longuy; 08-10-2021 at 10:55 AM. Reason: update |
The Following User Says Thank You to Longuy For This Useful Post: | steve99 (08-12-2021) |
Similar Threads | ||||
editing posts | midnight23 | Site Announcements / Questions / Issues | 3 | 06-17-2014 01:06 PM |
video editing | jb0y3 | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 03-15-2014 10:44 PM |
DIY Editing for EcuTek users is here December 20th! AND FREE! | Xero-Limit | Software Tuning | 53 | 01-09-2014 01:14 PM |
Video editing | Turkish | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 09-06-2013 01:01 AM |
