Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
04-15-2020, 11:32 PM | #1 |
Drives: 2014 frs. Asphalt grey
Need help. Shifter prob
So I just installed a short throw from ft86 (their version.) and it has a sort of “swivel” or “rotation” in it. Everything is fine it just had that weird thing that’s makes it feel off. I added video of the problem. Any advice on fixing the issue ?
04-15-2020, 11:32 PM | #2 |
I lied this the link to a yt vid of the issue
04-16-2020, 08:47 AM | #3 |
Drives: 2014 Subaru Forester
https://www.ft86club.com/forums/showthread.php?t=125248
This has been an issue since they released this product. I linked a thread above. There is a set screw that is supposed to keep arm and ball secured, but in your case it has either backed out or is stripped. The other issue with this shifter is the reverse lockout will strike the bolts securing the plate. FT86 Speed factory should not be selling this product. You are better off getting a refund and buying the STi part. Last edited by tehShirt; 04-16-2020 at 08:54 AM. Reason: added link |
Similar Threads | ||||
Intermittent fuel pressure/signal drop (Fuel regulator prob?) | Decimus | Issues | Warranty | Recalls / TSB | 6 | 03-27-2019 07:38 PM |
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing | bergy | Transmission and Driveline | 8 | 10-20-2016 09:57 PM |
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? | soulstice | Cosmetic Modification (Interior/Exterior/Lighting) | 52 | 01-24-2016 08:20 PM |
kartboy short shifter and rear shifter bushing install and review. FR-S | UMB FR-S | DIY (Do-It-Yourself) Guides | 21 | 10-18-2014 01:41 AM |
