01-12-2020, 02:35 PM | #239 | |
Drives: 2013 D4S BRZ
Problem solved. Looks like both bulbs but the dust I just figured that would’ve not been the case seeing as both are out. Oh well, that just means, upgrade time! Sent from my iPhone using Tapatalk |
01-12-2020, 03:44 PM | #240 |
A.K.A. Starlord
Drives: 2015 Series.Blue
One bulb going out can sometimes cause a small surge that can blow the other one which itself was just vary hanging on as well.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
01-12-2020, 03:46 PM | #241 | |
Oh interesting! Good to know! Thanks for the heads up. Much appreciated and I’ll keep that in mind for any future dx. Sent from my iPhone using Tapatalk |
01-13-2020, 08:02 AM | #242 | |
Drives: 2013 WRB BRZ Limited
Squadron Pros by baja designs are brighter than our headlights in raw lm's. the lenses are easily changeable as well so you can get the focus'd beam pattern you want. -B |
01-13-2020, 11:03 AM | #243 |
Drives: jrsc_brz
01-16-2020, 10:44 AM | #244 |
Drives: 86
Hello,
I have a Toyota 86 2013 automatic Japanese one which comes with winjet headlights. I am planning to get aftermarket vland headlights and would like to customize them with demon eyes (not halos) and I want the boomerang / led white strip to be sequentential + color change + switchback. As I have researched I got to know I need to get blueghozt controller with addressable led replacing the boomerang LEDs in vland. Is there any risk that you foresee doing such mod? Also how would I be able to connect both demon eyes + addressable strip to blueghozt controller? Is there any other similar mod available which would require less of wiring and customizing ? And would there be a problem fitting and installing the Vlands into Toyota 86 2013 model? |
01-16-2020, 10:47 AM | #245 | |
Just food for thought. -B |
01-27-2020, 04:09 PM | #246 |
Drives: Scion FR-S
I just had my headlights replaced after someone backed into the front of my car. I have a 2013 FRS. I purchased the Morimoto XB LED headlights with sequential turns. The body shop installed them, but did not hook up the DRL which I took care of. I do not have any turn signals other than the factory one below the headlight. Instructions are pretty bad, but it they do not seem to address the turn signal hookup. I can go start measuring the wires and figure out which ones need to be spliced for power, but these are suppose to be plug and play. Since my headlights did not have any turns built in the wiring would need to have a plug to go to the turns which I do not see. These are multiyear and have multiple extra plugs that are not utilized on my year. Any help would be appreciated. Thanks
01-27-2020, 04:46 PM | #247 | |
JDM Vaping Stance Nation
Drives: 2013 White
I spliced the turn signal from my Spec-D headlights into the turn signals below the lights. Worked for me. When I had side markers with turn signals I daisy chained it into it too with no problems.
Clueless
01-28-2020, 02:01 PM | #248 |
Drives: Scion FR-S
Thanks for the reply. I figured I could do that, but they were suppose to be plug and play
01-28-2020, 02:31 PM | #249 |
Drives: Firestorm FR-S '13
2013 Scion FR-S
I’ve searched and seen reviews for god light replacements. One bulb has burnt out and so I would like to replace both. I’m looking into doing a yellow type bulb. What is my best option that has longevity life span but also as strong as the oem bulbs? Thank you Sent from my iPhone using Tapatalk |
01-28-2020, 03:09 PM | #250 |
Drives: 2013 White
@89_Manny
I would go with a Sylvania brand yellow bulb. Don't recommend putting yellow HIDs in there as it scatters the light and is unusable.
Clueless
01-28-2020, 07:42 PM | #251 | |
Thank you. I was thinking of some LEDs but I wasn’t sure and I also thought of some Sylvania but I was one the fence about it. Thank you for the help! Sent from my iPhone using Tapatalk |
01-29-2020, 01:48 AM | #252 | |
Drives: Q5 + BRZ + M796
I swapped to 5500k bulbs on my car, and I bought some D3S Morimoto bulbs for the wife's car. The 5500k bulbs look more white when looking at my car than the 6500k, which looked a little bluish. The light that illuminates the road from the 5500k looks more amber/white up close like against a building or the back of a car and white/blue at distance; the 6500k was more white/blue up close and blue/purple at distance, which was too much for me. The 5500k is better. I was expecting improvements for my wife's Audi, and we do prefer the light color of the 5500k Morimotos when looking at the bumper and with how it illuminates the road. There is a subtle improvement in light output over the stock bulbs, even though the kelvin is higher. What I was expecting was the output to be transformed. Little did I realize was that my wife's Audi has distortion built into her projector lenses. I don't know if the stock BRZ's headlights have some opaqueness to the lenses, but the Vland's are definitely clear, and because of it, the cut off line is very sharp and the illumination is more intense. My guess is that a clear projector lens retrofit would vastly improve the light output. The caveat to that is that the cut off line can be so defining that if the car is bouncing over road bumps, the headlight beam can flick up and blind people. This isn't really an issue because her car has auto-leveling headlights. I don't know why they don't make have the lens clear or something to get better light output. I don't think we will be cracking open the headlights anytime in order to swap lenses. Another thought that came to mind was the nature of our cars. I feel like I said this before, but having a low car is kind of a pain for illuminating the road. If the goal is to have a drop over some distance, so that light is not pointed up, as that would blind people far down the road, then that means that our cars are barely shining very high above the ground. A big truck can have his lights slightly pointed to the ground and be illuminating much more of the traffic ahead. He can have his lights hitting below the side mirrors of the car ahead of him and still hit the next car. On the other hand, my light are barely striking the tires or bumper of the car driving in front of me, and they don't even touch the next car down the road. If pedestrians are walking on the side of the road at night then the truck is illuminating them from the waist down, and I am illuminating them from the shin down. I can correct this by pointing my headlight up at a slight angle, but the HIDs penetrate so far down road that I can see that I am lighting up an entire person way down road. I suppose that is just the reality of low life; we either can't see or we blind someone.
Similar Threads | ||||
OEM foglight install question | DarkSideFRS | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 06-12-2017 03:21 PM |
FS Winjet Headlight/Foglight Kit - Beat sonic antenna- clear sides | Verge | Exterior Parts (Aero, Lighting, Etc.) | 12 | 11-21-2014 08:56 PM |
Automation Lighting offers HID xenon headlight + foglight kits | jjdrivesajazz | Exterior Parts - Lighting | 138 | 01-13-2014 01:19 AM |
