Old 09-12-2021, 01:44 PM   #15
Akatzu
Drives: 2014 Scion FRS
@churchx I did google it an play around with the idea however it just didn't look that good to me, may have to go out and see one in person. @Yoshoobaroo what would be the setup if in the future I do go bbk? I'm between titan7 TS-5 and volk racing te37. Hoping to not run spacers.
Akatzu is offline   Reply With Quote
Old 09-12-2021, 06:36 PM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
Akatzu: having BBK may have their drawbacks too on daily only driven car. While painting may enhance looks only partially, it will still be WAAAY cheaper then BBK. And you retain compatibility with stock parts like pads & OE wheel clearance. I saw painted calipers on vw sirocco of my collegue, and apart from color choice (imho blue was not fitting his white car) it seemed better then stock-ish dirty brushed aluminum calipers.
Old 09-13-2021, 12:19 PM   #17
fminicooper
Drives: FRS Hot Lava
Originally Posted by DarkSunrise View Post
I'd say it's the opposite with the Wilwoods, they're more of a track oriented setup. I'm using RR's stage 2 kit (Superlite forged 6r caliper) and it can be difficult finding a pad that won't squeal on the street. I think the caliper is so light that there's just not a lot of mass to dampen the squeal. Combined with the lack of dust boots and it's not a friendly street setup IMO, more of a budget track setup.
On the plus side, I've had zero issues with mine on the track and this is probably the cheapest BBK from a consumables standpoint ($80 trackable/progressive Wilwood pads + $80 Centric blanks).
Agreed with DarkSunrise, I have a good experience at track with RR's kit but, big but, noisy for DD. I cannot delete the noise yet, try 2 pad, add shims...I manage to reduce the noise thou to an acceptable level.
fminicooper is offline   Reply With Quote
Old 09-13-2021, 09:26 PM   #18
Akatzu
@churchx I may give this idea a go but will definately upgrade in the future since I'm not looking into the gen 2 for another 5-6 years I will be getting different set of wheels for mine. May try to find a totaled 86 with the performance package that include the brembos. @fminicooper dang is it a rotor more so or as DarkSunrise said not enough mass to dampen the squeal? Wondering how they got it down on the performance package 86 and brz ith brembos.
https://www.ft86club.com/forums/showthread.php?t=135328 guessing this thread would help with clearence without spacers?
Old 09-18-2021, 12:58 AM   #19
jflogerzi
jflogerzi's Avatar
Look at carbotech 1521 pads and some wilwood shim. Works perfectly on my rr bbk street and rear bbk. Then I use carbotech xp10/8s at track and allows me to use the same rotors
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
fminicooper (09-21-2021)
Old 09-20-2021, 08:26 AM   #20
saltywetman
Drives: 2020 Toyota 86 GT 6M
if u plan on going teal, might as well go project mu
saltywetman is offline   Reply With Quote
Old 09-21-2021, 03:02 PM   #21
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
How about... Rockauto POWER STOP S7084 Red Powder Coated
kevaughan is offline   Reply With Quote
The Following User Says Thank You to kevaughan For This Useful Post:
Teseo (10-10-2021)
Knives’s Aftermarket & OEM Parts Hoard: Camber Bolts, Calipers, Shocks & More knives Brakes, Suspension, Chassis 4 01-21-2021 04:30 PM
dual calipers vs big brake calipers Docmattic Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 05-30-2017 04:51 PM
(Close)WTB:Aus GT Black interior(Close) Ry.ruzn Want-To-Buy Requests 0 04-20-2016 01:55 AM
How close is too close?: Gap between tire & spring perch kodyo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 09-20-2015 01:32 PM
Aftermarket Calipers and Stock Rotors Anorexic 86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 12-27-2013 01:08 AM
