Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
04-26-2021, 06:19 AM | #1 |
Drives: '18 WRB BRZ Limited w/ PP
DIY-ability for oil coolers and labor cost for installation
Hi friends,
Excited to start my second season of HPDE after sitting 2020 out due to the pandemic. My BRZ survived 5 track days in 2019 with no oil cooler and just 5w30 oil. Playing with fire, I know. I don't have my own garage. Instead, I have a shared garage in the apartment building. The building managers are somewhat chill about me working on my cars, but they probably won't appreciate it if my cars are on jacks for days on end (although I suspect OCs wont require putting the car up, but you get my point). Are oil coolers fairly simple to do with the help of a buddy? I am not the greatest mechanic and take a long time just doing brake pads and brake fluids ( i go super slowly to make sure i don't tmess anything up) I have been eyeing the Jackron Racing Dual because i think it fits my usage case the best, but it also looks like the hardest to install... Should I do it myself? If I don't, what's a reason range for cost of labor? |
04-26-2021, 07:05 AM | #3 |
It's not very hard at all. Everything just kinda bolts together
Sent from my ONEPLUS A5010 using Tapatalk |
04-26-2021, 07:40 AM | #4 |
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
The Jackson Racing Dual Radiator/Oil Cooler install is time consuming but no particular part of the install is very difficult. If you're just an average wrencher, I'd recommend taking a whole day to do it just in case you hit any snags. The only hangup I hit was that my 27mm socket to undo the oil filter mount was too thick (cheap HF impact socket), but after some passes on the belt sander it was small enough to undo the bolt.
04-26-2021, 09:06 AM | #5 |
friendly
Drives: 17' 86
You have to remove bumper which is easier if you jack the front up. I would plan for a day. As stated it's not really hard. I would imagine a shop could get it done in 3ish or so hours so whatever labor is per hour.
Seek comfort in discomfort.
04-26-2021, 09:12 AM | #6 |
Drives: 2013 frs base
I'm happy with my Jackson dual rad. The clearance between the air box and hose connections is tight. It fits close to the oil filler cap too. I bent the ac lines so nothing would rub. Highest temps that I've seen were at VIR a couple of years ago. 100+ ambient temps and 235-240 oil temps during afternoon sessions. 50/50 antifreeze mix. n/a engine. I installed mine with engine install but I can see it would take most of a day.
04-27-2021, 09:02 PM | #7 |
Drives: 2017 toyota 86
You don’t “need” to jack up front to take bumper off but it helps.
You could always drop back down once bumper on so to not “leave” it on stands for days. First time took me about 3h to get bumper off, each time I was almost twice as fast as before until now its an easy sub 30min job. Oil cooler is pretty easy and straightforward after bumper is off. JR dual rad is about the same amount of work, but you also need to drain and fill the coolant after. |
04-27-2021, 09:55 PM | #8 |
Thanks everyone. Bit the bullet and am excited to put it on this weekend.
Did you all use thread sealants on the M22 threads? It looks like the sandwitch plate itself has four M22 ports: two of them are for the AN fittings that go to the oil cooler and back (thus the male AN-10 to M22 adapters), and two of them are to be plugged up with M22 threads plugs (these are for aftermarket sensors, i am guessing?) I am reading that the AN fittings themselves won't need thread sealants, but I am wondering if I can get away without them for the M22 threads too. I don't want to make a mess and leave a little bit of sealant in the lines... Any general advise for a no-leak installation? I don't see anything about torque specs for the line fittings in the official manual |
04-27-2021, 10:07 PM | #9 |
AN fittings when torqued precisely shouldn’t technically need it.
But Ive used Permatex 59214 High Temperature Thread Sealant, on all fittings on 2 oil coolers and 2 trans coolers, totaling 20 fittings, with zero issues or leaks on any. Just don’t goop it on and don’t put any on the last 1 1/2 threads at the tip end, assemble per instructions And let it fully cure and dry before adding fluid and using it. |
04-27-2021, 11:21 PM | #10 | |
The Following User Says Thank You to Ashikabi For This Useful Post: | DarkPira7e (04-28-2021) |
04-28-2021, 12:06 AM | #11 | |
Re: I will forgo sealant on the ANs, and put sealant on the M22, as per instruction. Suppose I mess up and some sealant did get in the line, does anyone know if the oil lines are upstream or downstream of the oil filter? |
04-28-2021, 07:05 AM | #12 | |
04-28-2021, 06:25 PM | #13 | |
Similar Threads | ||||
Realistic labor and fabrication cost for 2JZ GTE FRS swap | ZoomZoom1 | Engine Swaps | 12 | 03-15-2019 11:55 PM |
Lowering Springs Installation Cost | xlid007 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 30 | 03-23-2016 05:38 PM |
Cost of Supercharger or Turbo and installation. | Wishbone32 | Forced Induction | 11 | 04-15-2015 08:21 AM |
Installation cost for a crank pulley? | Readytoxplod | Engine, Exhaust, Transmission | 21 | 09-18-2013 05:54 PM |
Cost of labor to installing lowering spring | jshum | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 06-09-2013 10:37 AM |
