timurrrr
Old 08-10-2022, 01:15 PM   #603
strat61caster
strat61caster's Avatar
Drives: '13 FRS
Originally Posted by OkieSnuffBox View Post
The car has a warranty. National attention has been brought to the issue.
I'm not worried about my '23 that should be here in a few weeks, neither should the rest of you. I'm just baffled that so many are still losing their minds over this.
Are you new to car forums?
ineedyourdiddly
soundman98 (08-11-2022)
Old 08-10-2022, 02:42 PM   #604
Dake
Is it really that baffling? That people go out and buy a brand new car and it appears there's a reasonable possibility of major issues?
Originally Posted by Spektyr View Post
But that can happen to every car.
Not really? I don't think unexpected catastrophic engine failure is super common in this day and age, especially on a brand new car from a "trusted" manufacturer.
Yes, the interwebs blows everything out of proportion, but as a representative sample, it does seem there are a few examples out there now.
Dake is offline   Reply With Quote
The Following 2 Users Say Thank You to Dake For This Useful Post:
DocWalt (08-10-2022), timurrrr (08-10-2022)
Old 08-10-2022, 02:49 PM   #605
OkieSnuffBox
Drives: It has 4 wheels
Yes, I am. I have never used a car forum on the internet before this one.
A "few" examples vs thousands sold. That's the point. Give up your deposit, call your senator, call the FBI. It's a very small percentage.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following 3 Users Say Thank You to OkieSnuffBox For This Useful Post:
Opie (08-16-2022), soundman98 (08-11-2022), strat61caster (08-10-2022)
Old 08-10-2022, 02:58 PM   #606
Dake
A few examples that we know of; that would be the "representative sample" part. You don't have to check 100% of something if 100% of those checked all appear to have it.
The Following User Says Thank You to Dake For This Useful Post:
Old 08-10-2022, 03:06 PM   #607
OkieSnuffBox
How many confirmed examples are there? You don't know, you're just feeding into the useless speculation.
Don't like the risk, don't buy the car. If you have one and you're that worried, sell it.
Old 08-10-2022, 03:13 PM   #608
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
But then you'd tell us we're a fool!
Old 08-10-2022, 03:17 PM   #609
OkieSnuffBox
Yep, I think it's overblown. You don't have to agree with my opinion. I could be wrong. I'm ok to admit I might be wrong.
I'm seeing stuff on Facebook groups where guys are calling for recalls.
Old 08-10-2022, 03:22 PM   #610
OkieSnuffBox
I'm just saying we should all chill out and see what happens.
Old 08-10-2022, 03:31 PM   #611
strat61caster
Drives: '13 FRS
I mean a recall would go a long way to restore faith, it would be like 2 hours of labor to pull the pan, remove debris and reseal. $150x2x10,000 cars = $3m
Better marketing to enthusiasts then a super bowl ad.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
Dake (08-10-2022), DocWalt (08-10-2022), timurrrr (08-11-2022)
Old 08-10-2022, 03:34 PM   #612
gen3v8
Boost is Best
gen3v8's Avatar
Drives: My18 wrxsti My19 brzts
Just a random inspection
https://www.tiktok.com/@pvs_tuning/v...39799763127554
If you see where you came from in your drivers window. It`s definitely RWD!
Old 08-10-2022, 03:37 PM   #613
Subito
Drives: 2023 Subaru BRZ Limited
As another forum member noted, correlation does not equal causation. 100% of the cars with engine failures may have RTV in their oil strainers, but that doesn’t prove that RTV caused the engine failures. Given that Toyota is fitting special baffled oil pans on their GR Cup race cars, I’m more inclined to believe the recent engine failures are due to unbaffled oil in the pan sloshing around during high-g cornering and starving the oil pickup. But at this point that’s just speculation too.
Subito is offline   Reply With Quote
The Following User Says Thank You to Subito For This Useful Post:
Opie (08-16-2022)
Old 08-10-2022, 03:37 PM   #614
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Originally Posted by gen3v8 View Post
and another, lol
https://www.facebook.com/groups/3908...=recently_seen
Old 08-10-2022, 03:40 PM   #615
Spektyr
Drives: GR86
Catastrophic engine failure isn't super common on this model just yet.
But what I'm pointing out isn't that this specific cause can happen to any car, but rather that "something" can cause a engine to stop working on any car. It ultimately doesn't matter if it's a simple fix or a 2 month repair when you're 1000 miles from home - the issue is that most people don't find themselves a day's drive away with nowhere to be and no time to be there. The towing, schedule disruption, etc. are the bigger issue than whether it's because the engine went boom or because a sensor convinced the ECU to shut everything down for no good reason. If you can't fix it then and there on the side of the road the immediate inconvenience is equal regardless.
I have a 2001 S-10 that I'd drive coast to coast without a moment's hesitation - not because it's bulletproof, but because it runs well right now and has for a long time. Statistically, every car has a non-zero chance to quit on you every minute.
Best you can do is to have a plan for if/when that happens. Ideally Plans A, B, and C.
I'll continue to drive my GR86 hundreds of miles for work without concern. It'd suck if it broke down for any reason at any point between home and anywhere else, but every other car I might drive could do that too and it's just a matter of getting a tow, getting a rental, and getting on with the tasks at hand.
Spektyr is offline   Reply With Quote
Old 08-10-2022, 04:00 PM   #616
IEatRice4Dinner
Drives: 2013 Hyundai Veloster Turbo
In the words of Aaron Rodgers, "R.E.L.A.X."
If there are only three or four confirmed cases of engines blowing, this is being blown WAY out of proportion. My current car is a 2013 Veloster Turbo and in the first year of production there were well over FIFTY documented cases of engines blowing up from low speed pre ignition. What did Hyundai do? They revised internal components several times in 2014, 2015, and finally figured it out how to stop them from blowing up in 2016. After five years and hundreds of blown engines they finally issued a recall... Just an ECU flash/bandage.
Every manufacturer has issues especially with early production models. My money is on them replacing engines as needed and if yours gets past the warrantee period you're probably fine. Is the 2.4 in the WRX having these issues?
IEatRice4Dinner is offline   Reply With Quote
The Following User Says Thank You to IEatRice4Dinner For This Useful Post:
Opie (08-16-2022)
oh no not again
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! steel86gt GR86 General Topics (2nd Gen 2022+ Toyota 86) 14 03-09-2022 01:15 AM
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Is my engine blown? dallenj Engine, Exhaust, Transmission 39 01-30-2017 04:18 PM
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 02:33 AM
Subaru BRZ complete engine gasket & seal kit 2.0L JPxM0Dz Engine, Exhaust, Transmission 0 12-18-2012 11:11 AM
Copyright ©2000 - 2022, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
