Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
06-03-2019, 10:32 AM | #1 |
Drives: 2013 Subaru BRZ
Main journal size mark on block
Hello,
I've been trying to make sense of what this means in the service manual, but haven't found a definite answer: Can someone help me understand? Thanks!! |
06-03-2019, 11:17 AM | #2 |
Drives: Toyota Supra 2JZGTE VVTi
If its how Toyota does it there is a also numbers stamped on the crank. You add the number on the crank to the one stamped on the block and you get the bearing shell size used when the engine was built. I think there are about a half dozen different sizes. The rod bearing have one stamped on the rod end and the other on the crank.
The Following User Says Thank You to Silvermk2 For This Useful Post: | maslin (06-03-2019) |
06-03-2019, 12:06 PM | #3 | |
Benz Tech
Drives: 2017 BRZ Premium
06-03-2019, 12:31 PM | #4 |
All the markings on the 2 blocks I have are 2's for the main bearing sizes.. Anyway, I've found a few threads that help explain a bit more. When I ordered bearings this didn't come into play, and as long as you're measuring the bore, the bearing thickness and the crank diameter and/or using plastiguage, you should be OK if you put them within spec.
https://forums.nasioc.com/forums/sho....php?t=2052088 https://www.ft86club.com/forums/show...?t=5778&page=2 According to Jeff, the largest difference (between 0 & 5) is 0.0005". |
07-24-2021, 01:13 AM | #5 |
Drives: 2013 Scion FRS
From my research the "Main Journal Size" stamp on the block is for manufacturing purposes only and is not a determining factor for selecting engine bearings sizes. The marking is a Subaru trait and used on older Subaru engines as well, there is some info on this on the NASIOC forum.
Similar Threads | ||||
Header to Block bolt size? | jnmxcvi | Engine, Exhaust, Transmission | 7 | 09-23-2019 10:58 PM |
WTB: FA20 Long Block/Short Block blown/running | The Racers Line | Engine, Exhaust, Bolt-Ons | 7 | 07-29-2014 01:26 AM |
WTB: FA20 Short Block or Blown Long Block | The Racers Line | Want-To-Buy Requests | 1 | 06-29-2014 05:21 PM |
WTB: short block or long block | DOTman05 | Engine, Exhaust, Bolt-Ons | 2 | 07-14-2013 06:48 AM |
WTB Main Body ECU | Acree | Interior Parts (Incl. Lighting) | 2 | 03-05-2013 05:31 PM |
