Old 06-17-2021, 11:32 AM   #15
churchx
churchx's Avatar
Drives: 2014 GT86
makinen: interesting video. Except cause for for rocker arm bearing failure over rev was mentioned. Can we blame part for failing then?
Old 06-18-2021, 02:03 PM   #16
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Does this happen with our FA20s?
Old 06-19-2021, 10:25 AM   #17
ML
ML's Avatar
Drives: 13 White MT FR-S
https://www.ft86club.com/forums/show....php?p=3361654
Build Thread
The Following User Says Thank You to ML For This Useful Post:
blsfrs (06-19-2021)
Old 06-20-2021, 10:54 AM   #18
makinen
makinen's Avatar
Drives: Toyota 86
Over-revving and valve float could be occurred first. But our rocker arms are floating design, therefore it is inevitable to be ejected when not enough force acts on valve stems.
If rocker arms have rigid shafts through them like e46 m3 or similar designs, we don't have to worry about time bomb.
When I experienced the ejections I was in normal RPM range. The time I actually did over-revving (over the stock red line) was several crankings before.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
HKS GT EL header, 17MY intake manifold */
makinen is offline   Reply With Quote
The Following User Says Thank You to makinen For This Useful Post:
blsfrs (06-20-2021)
Old 06-21-2021, 09:31 PM   #19
blsfrs
blsfrs's Avatar
Here's what we need.
Old 06-30-2021, 12:46 PM   #20
blsfrs
blsfrs's Avatar
Probable cause
#3, where I lost my intake rockers showed signs of something being sucked in to the engine. There was some damage to the piston, cylinder wall, and valve seats. About a month before this started, I installed an oil catch can. I could have possibly introduced a small metal fragment then. Still 3-4 weeks from getting my engine back.
Old 06-30-2021, 03:40 PM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Received a package from Australia. Now waiting on some 1217H. And time, could really use a few more hours in the day.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
blsfrs (06-30-2021), jrhudson (06-30-2021)
Old 06-30-2021, 08:18 PM   #22
blsfrs
blsfrs's Avatar
I read a couple of articles talking about oem iron valve guides with stainless steel valve causing galling. Mine had the oem guides but no evidence of problems there. Being rebuild with bronze alloy guides.
Old 07-01-2021, 01:29 PM   #23
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I hadn't heard that before. I could see improper reaming creating galling. Or improper heat treat on the SS part would also do it.
Old 07-02-2021, 09:18 AM   #24
blsfrs
blsfrs's Avatar
From Enginebuildersmag.com "
Valve guides can be generally classified into two groups: cast iron and manganese bronze, which covers a wide range of applications.
Cast iron guides are used mostly by OEMs due to its wear characteristics that result in longevity for high mileage applications. Cast iron is used with chrome valve stem applications as well. Cast iron cannot be used with stainless steel because of its tendency to gall.
That’s why high performance applications do not warrant the use of cast guides due to the fact the material can’t handle the high loads associated with higher spring pressures. Under high stress, cast iron guides tend to crack and fracture, which can result in engine failure altogether. Cast iron is inexpensive and works best with daily drivers and high mileage applications.
For any kind of performance application, the choice is manganese bronze. The way to pronounce this correctly is MAN-GA-NESE. I often hear this as magnesium, which is not correct. Manganese bronze is ideal for performance because it is more compatible with titanium and stainless steel.
https://www.calverst.com/technical-i...als-and-usage/
Just for reference.
Old 07-02-2021, 11:29 AM   #25
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Thatís why high performance applications do not warrant the use of cast guides due to the fact the material canít handle the high loads associated with higher spring pressures. Under high stress, cast iron guides tend to crack and fracture, which can result in engine failure altogether. Cast iron is inexpensive and works best with daily drivers and high mileage applications.
Just for reference.
Granted 99% of my engine building experience comes from motorcycles/atv's, I know of at least one instance where I used SS valves with OEM iron guides. It was a heavily modified air cooled engine. It was in the raw, no coating on the stem. Never had any issues
We liked to use copper beryllium seats with either bronze or copper guides depending on application for built engines.
blsfrs (07-02-2021)
Old 07-09-2021, 04:34 PM   #26
Trdfrssx
Trdfrssx's Avatar
Drives: 2013 Scion FRS
Are those from denstoj? How long did it take to ship?
Trdfrssx is offline   Reply With Quote
Old 07-09-2021, 05:09 PM   #27
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yes they are. Had them in about a week.
Old 07-09-2021, 05:14 PM   #28
Trdfrssx
Trdfrssx's Avatar
Nice! Looks like the price just went down a couple hundred dollars, might have to order a set.
Rocker arm ticking? Xman17 Issues | Warranty | Recalls / TSB 15 10-22-2019 02:56 PM
Rocker Arm Failure Worstenemy453 Issues | Warranty | Recalls / TSB 65 10-12-2019 08:50 AM
Rocker arm failed displacedTexan Issues | Warranty | Recalls / TSB 77 08-22-2018 06:16 PM
Rocker Panel Damage Repaint Question kzale1249 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 02-06-2017 02:37 AM
Rusty Rocker Nassty Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 04-01-2014 07:47 PM
Copyright ©2000 - 2022, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
