Old 04-02-2014, 12:59 AM   #1
Squido3J
Squido3J's Avatar
Drives: Scion FRS
Exclamation RASP noise after Header install ANYONE??
If you know a solution to this problem please feel free to let us know,thank you <3
Squido3J is offline   Reply With Quote
Old 04-02-2014, 01:14 AM   #2
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
If you install a header, you're getting rid of your primary cat so there's going to be a certain amount of "rasp" that comes with the territory. I don't know what you're running for the rest of your exhaust, but if it's too raspy, you might want to add a resonator.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 04-02-2014, 01:19 AM   #3
Squido3J
Squido3J's Avatar
Drives: Scion FRS
And I am also running these headers
Let me know what you think!
Old 04-02-2014, 02:19 AM   #4
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
Any sound clips?
Jolaessss is offline   Reply With Quote
Old 04-02-2014, 02:24 AM   #5
Squido3J
Squido3J's Avatar
Drives: Scion FRS
Originally Posted by Jolaessss View Post
Any sound clips?
[ame="https://www.youtube.com/watch?v=BzweGYpU3Eo"]FRS/BRZ Borla uel header noise - YouTube[/ame]
Old 04-02-2014, 06:46 AM   #6
FR-S Matt
Depends on how the rest of your exhaust is set up. What does the rest of the setup look like after the headers? My UEL has 0 rasp with an N1 and I have a catted front pipe. Granted the N1 is resonated as well.
Nevermind: I just read the couple links above.
A) EL header = more raspy, especially catless.
B) That exhaust is a cheap ripoff of an N1 and the resonator looks a lot smaller. You may want to go with something a bit more muffled to combat the rasp.
Something like the Q300 is much quieter, but will be much less raspier. Sound is a difficult one depending on the header. EL can be raspy on one exhaust then turn around and use a UEL header on the same exhaust and the rasp goes away. So much goes into acoustics. My advice, keep a catted front pipe, or resonated, and have a resonated catback. Removing any of those components will introduce rasp most likely. Going loud and not raspy is a balancing act.... Trust me, I know. It took me a year of swapping exhausts till I found the combo I love.
Raspy header and weird noise Scalzo Engine, Exhaust, Transmission 39 08-24-2020 07:40 PM
Borla Header Rattle Noise tonytduc Issues | Warranty | Recalls / TSB 40 05-09-2014 01:28 PM
Borla UEL Header noise? frslee Engine, Exhaust, Transmission 22 04-04-2014 11:37 PM
Aftermarket Header Dying Cricket Noise Squido3J Engine, Exhaust, Transmission 6 03-31-2014 06:07 AM
Noise after KW V3 install? Blizzard Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-28-2013 03:08 PM
