Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-18-2016, 12:38 AM | #1 |
Drives: white frs
CNT, ARM or OBX UEL header?
any you have experience on any of this 3 headers?
CNT, ARM or OBX. what header will you recommend for me i am on a budget . i searched the forum but no reviews so far for this 3 headers |
08-18-2016, 03:27 AM | #2 |
Drives: FT86
Gruppe -s is likely the best bang for buck well made good fitment for less tha $500
those other headers are a bit ordinary in fitment and quality link http://www.ft86club.com/forums/showthread.php?t=81839 maybe read the basic bolt on mods guide link below |
08-18-2016, 08:40 AM | #3 |
Drives: frs
08-18-2016, 09:40 AM | #4 |
Drives: 15 BRZ LTD, 05 FXT
Used.
08-18-2016, 09:58 AM | #5 |
Drives: Whiteout FRS
I'd go with Gruppe-S very good quality header for the money.
08-18-2016, 01:57 PM | #6 |
Drives: 2013 FR-S Base, 1997 Jeep Wrangler
Stay away from CNT. Mine started leaking at the flange (engine side) about a week after I installed it. This was with brand new OEM gaskets.
08-18-2016, 02:03 PM | #7 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Save more and get gruppe-s/ofh/rev works used. The others are garbage
08-18-2016, 02:53 PM | #8 |
Drives: white frs
ah ok thanks will oft will remove the CEL for o2 sensor? and is it safe to run without an actual dyno tune
08-18-2016, 03:17 PM | #9 |
Drives: 2016 Subaru BRZ WRB
The general rule is without a tune, you will get a CEL light and not get the full potential from the header swap.
08-18-2016, 07:01 PM | #10 |
Drives: white frs
ah ok how about the OFT out of the box tune will it remove the cel of a header?
08-18-2016, 07:17 PM | #11 | |
Drives: FT86
OFT comes with tunes for catless uel headers for 91/93/E85 fuels and oft tunes like all other tunes for catless headers will improve performance and disable P0420 cel code you can run catless header without tune but you miss out on a lot of the gains and you will get CEL code which will disable Cruise control. you can try o2 spacer in rear 02 sensor, but better option is tune OFT info see here http://www.ft86club.com/forums/showthread.php?t=71157 General basic bolt on mods guide http://www.ft86club.com/forums/showthread.php?t=81493 |
The Following User Says Thank You to steve99 For This Useful Post: | Teseo (08-18-2016) |
08-19-2016, 05:04 PM | #12 |
Drives: BRZ SWP Limited -6MT
ive got cnt and havent had much issue with it. had to beat it slightly with mallet to get one of the flanges on the engine studs on one side but i suspect that may occur with other brands as well. its been great for me being a budget piece. there is a thread or two with mostly positive reviews.
08-19-2016, 05:20 PM | #13 |
Time Traveller
Also have a CNT UEL which worked great with no issues whatsoever. I took it off the car for a smog and will probably be going EL so I'll sell it. I rather enjoyed it while it was on the car and have no regrets.
Similar Threads | ||||
JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 02:26 AM |
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
