Old 09-27-2020, 01:33 PM   #1
yzf219
Drives: 2013 FRS GTX3076R
Flashing back to stock Ecutek, no deskey dongle
Hello friends,
I've searched and searched but I cannot find a clear answer.
I bought my car used off a friend. It has an Ecutek tune on the ecu right now. He gave me the Ecutek cable but he doesn't have the deskey dongle. I wish to return the car back to the stock tune. Is it possible to do this WITHOUT the deskey dongle?
I also have a tactrix cable, from my research I can't simply overwrite the Ecutek tune with tactrix as it's locked. Is my understanding correct?
Thank you in advance.
Sent from my SM-G950W using Tapatalk
yzf219 is offline   Reply With Quote
Old 09-27-2020, 05:30 PM   #2
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
Ideally you want to borrow an Ecutek usb so you can flash a stock tune and keep the license on the ECU. Someone local should let you borrow one, takes just a minute to do the flash.
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8
the new guy is offline   Reply With Quote
The Following User Says Thank You to the new guy For This Useful Post:
yzf219 (09-27-2020)
Old 09-27-2020, 05:34 PM   #3
yzf219
Thanks. Looks like I'll have to find someone local.
Old 09-27-2020, 08:49 PM   #4
jflogerzi
jflogerzi's Avatar
Don't you need a key match to the ecu? Or only for custom tunes?
2013 Series 10 FRS #553
Old 09-29-2020, 10:42 AM   #5
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I *think* only for the tunes. Once the license gets transferred to the ECU then any DESKey should work for reading/wwriting to it/etc. We've read random coparts cars ECUs with any available DESKey before and it worked.
Have never tried to write any tune to one of those cars though, including stock, however since you can download the stock tunes it shouldn't require any specific dongle. That will also remove the lock. If the car gets tuned by anything after that the ECUTek license is lost though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
yzf219 (10-09-2020)
P0341 after flashing back to stock from ecutek thecarfilmer Issues | Warranty | Recalls / TSB 1 04-02-2019 06:10 AM
[GA] Ecutek DesKey (dongle) Kojiap1 Engine, Exhaust, Bolt-Ons 0 03-01-2019 11:09 AM
Flashing back to stock, why? bzdont Software Tuning 6 09-06-2017 02:36 AM
LOST OFT, need help flashing back to stock. Hachi86Roku Software Tuning 13 12-10-2015 11:41 PM
ecutek deskey problem!! ahk Engine, Exhaust, Transmission 17 03-07-2013 03:54 PM
