11-08-2023, 12:56 AM | #24501 | |
Back in the day, I would have just nursed it along for another year and just push started the car if necessary. Today, I couldn't push start a lawnmower. can one push start these cars if they have a dead battery? |
The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (11-08-2023) |
11-08-2023, 12:28 PM | #24502 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Couldn't count on bump starting my x386 game computer.
That only dented the corners on the case.
"I gotta rock." -- Charley Brown |
11-08-2023, 12:43 PM | #24503 |
Drives: 2013 FR-S 6 spd in Halo
After leaving the key on and the radiator fans going during the lunch break at a track day, I can definitively say that you can push start these things. Granted, I had to think through the process since it has been at least 30 years since I last push started a car.
Go fast, take chances. |
The Following 3 Users Say Thank You to Spairo For This Useful Post: |
11-08-2023, 01:04 PM | #24504 | |
義理チョコ
The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (11-08-2023) |
11-12-2023, 09:42 PM | #24505 |
Drives: 17 Asphalt 86
Pulled trans today. New exedy OEM clutch+flywheel, battle garage TOB, verus fork+pivot, and front bearing cover.
The Following 5 Users Say Thank You to RToyo86 For This Useful Post: | Bonburner (11-26-2023), Jdmjunkie (11-13-2023), MJones_RB (11-14-2023), Ultramaroon (11-14-2023), Wally86 (11-14-2023) |
11-14-2023, 09:34 AM | #24506 |
Be Kind
Drives: 2020 86
Did the strap trick help to make installing the trans easier?
11-14-2023, 11:52 AM | #24507 |
I haven't tried without it to compare, but it certainly went together pretty easily. Wiggled it for about 2-3 minutes and it slide in most of the way. Was able to snug it to the block by gently tightening bell housing bolts cross pattern a little bit at a time.
Gently rotated the output shaft at the back of the trans to help line it up better to the clutch. Last edited by RToyo86; 11-14-2023 at 12:22 PM. |
11-14-2023, 01:15 PM | #24508 |
義理チョコ
Be careful about tweaking that AC hardline! Just noticed it.
The Following User Says Thank You to Ultramaroon For This Useful Post: | RToyo86 (11-14-2023) |
11-14-2023, 02:07 PM | #24509 | |
Drives: Scion FR-S Series 10 #2462
Great job! |
11-14-2023, 02:49 PM | #24510 | |
I borrowed a friend's lift which didn't leave me many options for supporting the engine. He had a tall spinny arm jack that I used to help support the transmission while we wiggled it in and out. |
The Following 3 Users Say Thank You to RToyo86 For This Useful Post: |
11-19-2023, 08:42 PM | #24511 |
Drives: 2013 frs base
I removed my Verus front wheel air deflectors and reinstalled the oem ones. I couldn't hardly drive anywhere without finding something to scrape.
And how about that 1/4" composite aluminum piece between the splitter and engine cover and wheel wells? I bet it gets me 0.0000002% less drag and lift. I dropped her off at a tire shop for a set of Conti Extremecontact dws. Can't wait to get her back. |
The Following User Says Thank You to blsfrs For This Useful Post: | Wally86 (11-27-2023) |
11-26-2023, 03:42 PM | #24512 |
Meow
Drives: GT86, Volvo 996
Had it PDR'd completely following some light hail damage, and took the opportunity to correct the 50+ door dings and small impacts the car had gotten in its first life.
All are gone save for one on the wheel arch. It looks like a new car. They also polished it a little bit and corrected some small paint repairs that had been done approximately. Also, installed the updated facelift door stoppers (sooo much better), and a knock-off MC brace. |
The Following 4 Users Say Thank You to alex87f For This Useful Post: |
11-26-2023, 08:46 PM | #24513 | |
6/22/12-2/6/24
They're pretty pricey too, and I'm kind of expecting it to have only a 20% longer life time than oem's throwout bearing .. but who knows.
11-27-2023, 07:25 AM | #24514 | |
So far I'm happy with how everything is feeling. For added context I also have the forester slave cylinder and Mtec clutch assist spring, so pedal feel is probably going to vary a bit. Only gripe/adjustment is that pedal feels like it engages last 20% of pedal travel. Adjusted the pedal but overall just feels like there's less modulation overall. I don't think that's nessesarily TOB related probably the OEM exedy clutch. Fairy certain OEM setup didn't bite that low on the pedal. I have 1000km on it now, waiting to see if anything Changes after 1500km or so which is what exedy says is typically break in cycle with highway driving. |
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
