Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-11-2021, 06:13 PM | #1 |
Drives: Widebody 86/F56 Mini Cooper S
Tips for a Newbie?
Hey so I'll be changing my headers, overpipe, and frontpipe soon. It's my first time working under the car and would love any tips anyone might have!
I've heard the overpipe is hard to do, but in what sense exactly? Getting it out or in? And what order should I do it in, headers, then overpipe then front. Or drop everything out first and do the overpipe first? Any help is greatly appreciated |
05-11-2021, 06:30 PM | #2 | |
Certified Wumbologist
Drives: 2015 Scion FR-S
Make sure you have all the necessary tools before starting the install. Take your time and make sure everything is seated properly. The OP is somewhat of a pain to take off/put on. To make it easier, drop everything out and install the OP first. If you need more room, you may need to loosen the engine mounts and lift the motor. I believe there are some tutorials on here on how to do it. If you are not comfortable doing this, have someone with experience do it or bring it to a professional.
05-11-2021, 06:38 PM | #3 |
First and foremost is to have a SAFE way to get it off the ground. I am sure there are some very tiny skinny people that do it on the ground but most just won't do it.
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Hamza (05-13-2021), soundman98 (05-11-2021) |
05-11-2021, 08:53 PM | #4 |
Drives: 86
Front pipe is just 2 bolts on either end and one bolt mounted to the chassis (if I remember correctly). Pretty much the easiest pipe on the exhaust to swap. Disassemble that first and see where it gets you.
There are also plenty of header swapping vids to study. Words only go so far, for me at least. Much more educational to watch video of the swap. |
The Following 2 Users Say Thank You to Celica00 For This Useful Post: | Hamza (05-13-2021), soundman98 (05-11-2021) |
05-12-2021, 10:24 AM | #5 |
JDM Vaping Stance Nation
Drives: 2013 White
Get you some penetrating oil like PB Blaster. Soak that bad boy up before you break the bolts loose.
Clueless
The Following 3 Users Say Thank You to YamahaR86 For This Useful Post: |
05-12-2021, 10:30 AM | #6 |
Drives: 17 Asphalt 86
Header off, then overpipe. New overpipe on then the header.
Make sure you have new gaskets for everything. Chasing exhaust leaks is a PITA. Unbolt the passenger engine mount, and lift the engine via the oil pan to get the overpipe out. 5 minutes of effort and it comes out. Make sure to use a piece of wood or a hockey puck between the jack and oil pan as a cushion |
The Following User Says Thank You to RToyo86 For This Useful Post: | Hamza (05-13-2021) |
05-12-2021, 10:45 AM | #7 | |
05-12-2021, 10:56 AM | #9 |
Rust bucket enthusiast
When assembling everything together, don't torque anything down, leave it hand tight at most. This gives you actual wiggle room if sealing surfaces aren't lining up perfectly. Don't bother putting the gaskets on until everything is figured out and ready to be tightened down for good- last thing you want to do is ruin gaskets.
Also, lay towels down to keep falling hardware from bouncing far (if you're on a hard surface like pavement or concrete)
05-12-2021, 11:58 AM | #10 | |
05-13-2021, 07:55 AM | #11 | |
05-13-2021, 07:56 AM | #12 |
Last time I had the car lifted obviously had the jack stands, then stacks of bricks under each wheel. This time will take the wheels off and use them as a worst case scenario. Rather a set of new wheels than a new upper half body. I'm a skinny dude so clearance isn't too big an issue
The Following User Says Thank You to Hamza For This Useful Post: | Tcoat (05-13-2021) |
05-13-2021, 07:57 AM | #13 |
05-13-2021, 08:01 AM | #14 | |
Not gonna lie I've never seen one anywhere (but I've never specifically gone to look for them). I'm sure of a few sports shops would have them, but it being such a niche thing for this part of the world they'd probably be like $15 each. I have a few beams of wood I'll just chop one to size. I'm a bit worried tho because that wood is about half as thick as the blocks I see others use, is the wood prone to exploding under weight?
Similar Threads | ||||
WTB - Dual Titanium Tips Exhaust (Burnt Tips) | DeuxLaSole | Canada Classifieds | 0 | 04-01-2018 08:39 PM |
*Groupbuy: Invidia N1 and Q300 Cat-Back Exhausts (SS tips, T.I. tips) -fteightysix* | 86SPEED | Groupbuys | 74 | 11-09-2016 01:45 PM |
Newbie needs... | Salemate | Canada Classifieds | 10 | 12-23-2015 03:07 PM |
Newbie! | randomthoughts | CANADA | 2 | 07-14-2014 01:41 PM |
Newbie | KiRiMa | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 01-07-2010 05:39 AM |
