Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
07-29-2017, 03:07 AM | #15 |
Don't think that head unit is garbage but it definitely looks aftermarket. Particularly those controls... It looks like it mounts on the left side and protrudes out from the wheel, which (if so) seems like it would make for some awkward spirited driving and a weird way of actually adjusting/using the controls.
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
07-30-2017, 02:42 AM | #16 |
U can use one of these. It costs 10 bucks and controls ur phone Sent from my iPhone using Tapatalk |
07-30-2017, 11:14 AM | #17 |
demariners
Drives: 2015 Blue Subaru BRZ
I appreciate the post. However the thread was not about other ideas how to control the radio. It was about swapping steering wheels and anyone that has been successful in doing so.
11-01-2017, 01:35 PM | #18 |
Drives: Frs
So whats the final verdict on the comparability of the steering wheel on MY13-MY16?
11-01-2017, 08:44 PM | #19 |
demariners
It can be done, however LOTs of parts needed and the biggest issue is the clock spring. If you can get the correct clock spring you then need to run the correct wires to the clock spring back to the radio. I decided not to do it.
11-22-2017, 09:00 PM | #20 |
Drives: Frs
What’s the part number for the correct clock spring?
11-22-2017, 09:02 PM | #21 |
demariners
Not sure.
It’s whatever comes in the 17+. However you also need the wiring harnesses |
03-21-2019, 06:44 PM | #22 |
Drives: 2016 Subaru BRZ Series Hyper-Blue
I think the best bet for this swap while not spending too much money would be to find a junkyard steering column that is intact for the swap. Good luck though.
05-01-2019, 11:19 PM | #23 |
demariners
And COMPLETE. After lots of research I was able to do this!
Was able to re-pin the factory clock spring. Adding 5 wires to it. Running then my own wiring to the radio with a Maestro SW kit. Then programming the Maestro SW kit for the correct resistance on the wheel and including the illumination. What was required to do this was the wheel and airbag with all the wiring and the Maestro SW kit. So I own a 2015 BRZ and now have a 2017 Steering wheel with OEM buttons. Works like a champ! |
05-02-2019, 10:26 AM | #24 |
Drives: 14 BSP Edelbrock BRZ
How can you say this with a straight face when you have the stock head unit? It is one of the worst sounding things I have ever come across in a car. I could find a JVC unit that would be an upgrade over the stocker.
Edit: Ah, after reading this again you must be talking about the clip-on steering wheel control. Yes, agreed. Carry on. |
05-02-2019, 10:49 AM | #25 |
demariners
Yea the clip on.
I have a Pioneer NEX W44000. I replaced my OEM 2015 steering wheel with a OEM 2017 steering wheel with controls. |
05-02-2019, 11:14 AM | #26 | |
Just the tip
Drives: 2017 DGM BRZ
Being able to retain the original clockspring and save the money may sway a lot of people to go ahead with this mod if it's not too difficult. |
05-02-2019, 11:29 AM | #27 |
demariners
Well re-pinning the clock spring is completely up to the installation. You can re pin it however you wish. The 2015 clock spring is only using 2 pins for the cruise control but the plug supports 12 pins. So you choose which ones you want to pin.
The steering wheel buttons have 5 wires (so you would choose 5 pins). Thy are typically parallel to the bottom of the clock spring. The 5 wires are Illumination -, illumination +, SW1 (Vol and Seek), SW2 (Phone, Source, Center Button), and SWG (feed). I do not know what wire is what as they are different depending on what button kit you get. Other items you will need is the Airbag and all the parts that make up the steering wheel. I have posted below the part numbers I used. Also again you have to make a custom SW file with resistances. Vol +/Phone Disconnect 1000ohm Vol -/Center Button 3000ohm Seek-/Source 330ohm Seek+/Phone Connect 1ohm Parts: 98211CA130VH - Airbag 34312CA150RG - Steering Wheel 34317CA040 - Steering Wheel Lower Piece 34318CA020 - Cap Cover Right 34318CA000 - Cap Cover Left 34327CA010 - Steering Wheel Damper 83154CA050 - Steering Wheel Trim/Buttons |
05-02-2019, 11:35 AM | #28 |
demariners
Also, you will need some custom wiring harnesses. There are a couple companies out there that make them.
What I ended up doing is purchasing a 2017 Dash complete wiring harness on ebay for $50. I stole the pins and wiring harnesses from it to make this. The 2015 clock spring does not have the wires or the pins so you have to get the custom pins for the connectors. I just stole them from the 2017 harness. You could also just purchase a 2017 clock spring as well which might be easier since the harness and pins are there already. |
Similar Threads | ||||
2013-2016 vs 2017 front pipe | Var | Engine, Exhaust, Transmission | 2 | 10-09-2018 03:19 PM |
2016 BRZ vs 2017 BRZ | CBR600RR | FR-S / BRZ vs.... | 175 | 11-16-2016 02:47 PM |
Trading in 2016 BRZ for 2017 BRZ? | acethebrz | BRZ First-Gen (2012+) -- General Topics | 27 | 10-13-2016 10:02 PM |
2017 Tails on 2013-2016? | djsyndrome | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 09-04-2016 05:51 PM |
Replacing steering wheel and seats | mclevin | AUSTRALIA | 11 | 06-23-2012 07:53 PM |
