#1625 | |
Drives: Crapcan
Have you tried playing around with rounding the edges? There is a radius tool in tinkercad.
#1626 |
No I don't race or speed
The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (05-24-2022) |
#1627 |
Site Moderator
Drives: ichi 86 Project
I would… except it’s at its limit. Of course, top part is kinda still have an option… but I use that spot to loop the key ring
#1628 | |
Drives: Crapcan
Oh yeah, I see. You’d have to increase size to be able to radius those edges. May be worth trying. Kind of the reason I don’t carry my ridge wallet anymore. It’s too square and makes it awkward in my pocket.
#1629 |
Site Moderator
Right, make it wider to soften the edge. I might update the compact ver for more softer edge.
#1630 |
Just the tip
Drives: 2017 DGM BRZ
I'd imagine this is an easy fix for your cabinet guy though? Usually cabinet boxes are just built in modules, so in theory they can just shrink that module up to make it right. Unless they've already built things... but that's on them at this point.
#1631 |
Titty titty pew pew
Drives: Costco boxer briefs
The Following User Says Thank You to Sapphireho For This Useful Post: | soundman98 (05-24-2022) |
#1632 |
Well that is no ordinary rabbit
#1633 | |
The Dictater
Drives: '13 Red Scion FRS
You could always design a more compact PCB, have someone print it, and transfer all the important bits over to the new one. Or cut the current PCB in half, add jumper cables between the two halves, then just have buttons on both faces. |
The Following 2 Users Say Thank You to Spuds For This Useful Post: | ichitaka05 (05-24-2022), NoHaveMSG (05-24-2022) |
#1634 | |
Drives: Crapcan
He needs to remake it. I called him this morning and told him I’d buy the correct one. I should have caught it when I verified the layout. He gives me a great deal and I can reuse the full 30” in my utility room above the washer and dryer so no harm, no foul.
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
#1635 | |
Site Moderator
The Following User Says Thank You to ichitaka05 For This Useful Post: | Spuds (05-24-2022) |
#1636 | |
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | NoHaveMSG (05-24-2022), soundman98 (05-24-2022) |
#1637 |
alternative member
You tit! I soiled my armor, I was so scared!
The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (05-24-2022) |
#1638 | |
alternative member
The Following User Says Thank You to Ultramaroon For This Useful Post: | Spuds (05-24-2022) |
Tags |
baby kitty, have you turned it off/on, i heart my boxer, i still hate you all, kiss me, multipass, next one is a prequel, ow my balls, the search for more money |
Random Thoughts - Part Deux [NO POLITICS] | Ultramaroon | Off-Topic Lounge [WARNING: NO POLITICS] | 84004 | 03-07-2022 11:00 AM |
OEM BRZ spark plug part number? | qqzj | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 05-26-2017 11:33 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random search on bing | sdwagonjp | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 11-19-2014 07:35 PM |
