Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) -- General Topics
BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ
Old 11-29-2021, 04:50 PM   #1
nevermore_
Drives: '22 BRZ
Sound System quality is bad?
Hey everyone - I'm a new member here and got my new BRZ (Limited) recently. I love everything about it, except the speaker quality which I found to be cheap sounding at best. Is this just me? I have the limited variant as well, with the 'premium' speakers. Cant imagine how the base version sounds.
My other vehicle is a MK7 GTI with the non-premium speakers and they sound
much better in comparison.
Maybe its the additional road noise that's affecting my perception.
nevermore_ is offline   Reply With Quote
Old 11-29-2021, 05:04 PM   #2
Rustyoid
Drives: 2022 GR86
Congrats!
i could be wrong, but as far as i have seen it DOES NOT say ""premium" speakers" in any specifications, just that the PREMIUM trim comes with 8 speakers instead of 6.
are you listening on spotify (or another streaming service?) ;P because spotify is TERRIBLE especially thru mobile data.
using bluetooth VS a hardwired connection will also effect the quality
Rustyoid is offline   Reply With Quote
Old 11-29-2021, 05:13 PM   #3
StE92ve
StE92ve's Avatar
Drives: 2014 Mazda CX-5
Originally Posted by Rustyoid View Post
Congrats!
https://www.subaru.com/vehicles/brz/...-wrapper-modal
Unless the specs from Subaru are wrong, both versions get 8 speakers. It's the GR86 that the higher trim gets 8 speakers vs 6 for the base.
StE92ve is offline   Reply With Quote
Old 11-29-2021, 05:17 PM   #4
mazeroni
Drives: 2013 Scion FR-S Series 10
I had a MK6 GTI with the base 8 speaker system and it was really good.
First thing I noticed with the FRS is how hollow everything sounded.
The 1st gen had 8 speakers standard. But whether it is 8, 6, or 4, there is only so much you can do.
It is mostly the lack of insulation, but then you are also dealing with a small cabin and the placement of the speakers firing either at your feet or directly up into the windshield. I think some people find that a sub and replacing all of the speakers can overcome some of that, but I don't think it will ever exceed "just okay."
mazeroni is offline   Reply With Quote
Old 11-29-2021, 05:18 PM   #5
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I also didn't like how the sound system sounds with the default sound settings, but having spent just a couple of minutes with it I found the quality to improve slightly after I reduced treble a bit in the EQ and moved the "fade" slightly towards the rear.
The Following User Says Thank You to timurrrr For This Useful Post:
Blighty (12-08-2021)
Old 11-29-2021, 05:19 PM   #6
Dylans47
Drives: Scion FR-S
Its been confirmed the specs from subaru are wrong. Both base models are 6 speakers. Caused a lot of confusion.
Dylans47 is offline   Reply With Quote
The Following 2 Users Say Thank You to Dylans47 For This Useful Post:
Rustyoid (11-29-2021), timurrrr (11-29-2021)
Old 11-29-2021, 05:19 PM   #7
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Stereo is ok at best. it has no subwoofer (unless you add one) which does help sound clarity with crossovers and all that.
Will it match a Miata Bose, or a GTI Harman Karman sound system: No.
SpectreRT is offline   Reply With Quote
Old 11-29-2021, 05:21 PM   #8
nevermore_
Drives: '22 BRZ
Thanks!
The monroney label does specify them as 'premium speakers' in the features list. Maybe its just an 8 vs 6 speaker setup like the GR86 variants.
And I do use Spotify (over BT or Android Auto). Will test w/ an aux wire to see if that makes any difference.
Old 11-29-2021, 05:22 PM   #9
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Which "quality" do you use in Spotify settings?
Old 11-29-2021, 05:23 PM   #10
nevermore_
Drives: '22 BRZ
Probably this. The sub-woofer makes a big difference I think.
Old 11-29-2021, 05:24 PM   #11
nevermore_
Drives: '22 BRZ
I've set it to 'High' and the auto-adjust feature is off.
Old 11-29-2021, 05:52 PM   #12
Rustyoid
Drives: 2022 GR86
What and where is this monroney label you speak of? Not trying to attack you or anything, just saying I really don't think it actually specified "Premium" speakers, so we shouldn't expect anything ground breaking. Just curious if its actually being advertised as premium audio anywhere or if its just additional speakners.. I originally wasn't going to get the premium until i saw 8 speakers vs 6 but the additional speakers was enough to push me to the premium considering everything else
If you really care about audio quality first thing you should do is delete spotify :P its really quite bad
Old 11-29-2021, 05:54 PM   #13
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
The moroney label is the window sticker.
Old 11-29-2021, 06:03 PM   #14
Pete
Pete's Avatar
Drives: 22 BRZ
We were discussing that in another thread when I came across this:
https://www.whathifi.com/us/advice/s...nd-latest-news
Looks like spotify will have a lossless streaming option soon.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
Speakers For Better Sound Quality Kaotic Lazagna Electronics | Audio | NAV | Infotainment 24 01-17-2019 10:24 PM
Why Processing is ESSENTIAL To Sound Quality TOOSTUBBORN2FAIL Electronics | Audio | NAV | Infotainment 38 06-03-2016 03:17 PM
Help with Sound Quality otterpop Electronics | Audio | NAV | Infotainment 5 02-01-2015 01:43 PM
HD Radio - sound quality? ('14 BRZ) MysteryMachine Electronics | Audio | NAV | Infotainment 21 02-13-2014 02:34 PM
The quality of the stock sound system?? Jruex22 Electronics | Audio | NAV | Infotainment 15 08-13-2012 04:59 AM
