Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
07-13-2018, 01:35 PM | #1 |
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
2017+ Vertical JDM/STI DRL Install Help
About a year ago I saw a post here about the Japanese instructions for these daytime running lights but I can't seem to find it now.
So I need help finding where to connect parts of the provided harnesses. The first harness I can't seem to find where it connects is the one coming from on/off button. Here is a close up of the connector Where does this 2nd harness connect to I'm not really finding a proper place for them under the drivers side dash shown here Finally there is a Y shaped harness that connects the 2 lights in the bumper to somewhere in the engine bay... where is that somewhere located? Here is the that harness and here a close up of the connector Last edited by TachyonBomb; 07-13-2018 at 07:25 PM. |
07-16-2018, 02:51 PM | #2 |
Drives: '14 981CS, '99 NB1
USDM cars have different body harnesses, you won't find the right connectors.
The only harness I used from that kit is the one that plugs into the two lights. I cut the connector off that you are holding in that last picture and crimped on female spade connectors. I then used T tap connectors on the OEM boomerang wires on the driver side headlight. Worked great. You'll have to use a multimeter to figure out which wires are which. I don't have my BRZ anymore so I can't look for you. |
The Following 2 Users Say Thank You to johan For This Useful Post: | Busybee (06-19-2019), TachyonBomb (07-16-2018) |
07-16-2018, 03:45 PM | #3 | |
Aw man, what happened to it?
Instagram: @spike.brz
07-16-2018, 06:52 PM | #4 |
The Following 4 Users Say Thank You to johan For This Useful Post: |
07-17-2018, 01:12 AM | #5 |
Drives: Q5 + BRZ + M796
Sad but awesome at the same time.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | johan (07-17-2018) |
04-25-2019, 12:57 PM | #6 |
Guys I'm in the same boat. No clue where the hell that connector plugs into.
I have the instructions from japan if anyone wants to help |
The Following User Says Thank You to csol For This Useful Post: | Busybee (06-19-2019) |
04-25-2019, 01:00 PM | #7 |
04-25-2019, 10:25 PM | #8 |
I did some of my own research with a multimeter and test pen
Going to run 2 cables throught drivers side grommet on the firewall. (RHD) those two wires then connect to one of the plugs. The rest is plug and play it seems. Will post an update for anyone in the future that wants to do it the proper way. |
The Following User Says Thank You to csol For This Useful Post: | Busybee (11-29-2019) |
04-29-2019, 07:34 PM | #9 |
Forget the harness, I just used the on/off switch and connected it to an unused fuse under the dash which connect to the lights. it was a lot easier that way.
On 8/20/19 Works Motorsport have sent me their first payment of $450. Only 5 more payments to go.
Follow what happened here: http://www.ft86club.com/forums/showt...96#post3213496 |
06-19-2019, 11:27 AM | #10 | |
Drives: BRZ limited
Di you cut or customize any of the original harness? Please, can you share some pictures or an update how to properly install it? Thanks |
06-23-2019, 05:24 PM | #11 | |
Shame on @ft86speedfactory for not going to any effort to get the install instructions. Got access to the Subaru jap internal accessory install manual. |
The Following User Says Thank You to csol For This Useful Post: | Busybee (06-26-2019) |
06-26-2019, 01:31 AM | #12 | |
Drives: BRZ limited
Great! Appreciate it? Do you have more pictures or a write up That you can share? I sent you a message with some questions? Would be also great if you can share the installation guide. Thanks Sent from my iPad using Tapatalk |
11-29-2019, 07:13 PM | #13 | |
Drives: BRZ limited
Thanks |
Similar Threads | ||||
2017+ Bumper Vertical DRLs | Irace86.2.0 | Cosmetic Modification (Interior/Exterior/Lighting) | 33 | 11-29-2019 07:17 PM |
DIY - Vertical Door Install 2013 FRS | UF Key Master | DIY (Do-It-Yourself) Guides | 69 | 08-11-2018 01:52 AM |
Any guide for install this Badge in a new 86 2017? | reynierpm | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 08-30-2017 02:05 PM |
2017 BRZ Install Kenwood DNX893S | 007BRZ | Electronics | Audio | NAV | Infotainment | 1 | 08-10-2017 03:40 AM |
2017 BRZ and Perrin Oil Cooler Install | JSube | Tracking / Autocross / HPDE / Drifting | 18 | 04-29-2017 07:49 AM |
